2026 Tundras...
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Mar 20, 2025.
  1. May 9, 2025 at 12:10 PM
    #151
    sudobash
    sudobash New Member
    We shall see who is right. Correction will be issued if the 2026 proves to have a some sort of refresh.
    woods, Breathing Borla and GODZILLA like this.
  2. May 9, 2025 at 1:36 PM
    #152
    Doofus
    Doofus New Member
    We could have different definitions of "refresh." It might not be a wholesale change but significant modifications could be made. For example, adding tow hooks on some trims, which may necessitate modest front end redesign, adding new colors and/or trim options, and fixing other issues such as the Qi charger, mirror whistling noise, etc.
    Would these qualify as a "refresh?" Perhaps not, but it could also be more significant than typical MY2MY changes.
  3. May 9, 2025 at 1:40 PM
    #153
    Breathing Borla
    Northern Illinois
    have to wonder how long they will run out TSS 2.5
    my guess is no refresh, beyond normal bs like colors and move some small things around.
    consumer reports just named it the most unreliable truck for 2025, you and I both know heads are going to roll when Japan sees that, so my guess is they will be focusing on improving what they have. Toyota usually does that anyways.
    https://pickuptrucktalk.com/2025/05/consumer-reports-least-reliable-2025-full-size-trucks/
    seems like cameras and infotainment is the main culprit here from what it says though.
    woods and Wallygator like this.
  4. May 9, 2025 at 1:41 PM
    #154
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Qi charger is refreshed in 2025
    Rear window switch also refreshed in 2025. It’s smaller than previous 22.
    sudobash likes this.
  5. May 9, 2025 at 1:42 PM
    #155
    sudobash
    sudobash New Member
    Wait.
    The rear window switch got SMALLER on the 2025.
    Kap1 and Breathing Borla like this.
  6. May 9, 2025 at 1:43 PM
    #156
    Breathing Borla
    Northern Illinois
    how? lol, its already small
    Kap1 and sudobash[QUOTED] like this.
  7. May 9, 2025 at 1:44 PM
    #157
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    No one discusses it but it is a tad smaller. Might be a 24 refresh when the dome lens changed idk
    woods and sudobash like this.
  8. May 9, 2025 at 1:46 PM
    #158
    sudobash
    sudobash New Member
    That it could very well be. Not something I ever thought to check. Now I'm really curious.
  9. May 9, 2025 at 1:49 PM
    #159
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    My favorite thing to do is the roll rear window down, when I first got the 25 I noticed it.
    Didn’t inspect any 2024 while I had the 22.
    Tundra Texan, woods and sudobash like this.
  10. May 9, 2025 at 1:49 PM
    #160
    Breathing Borla
    Northern Illinois
    snap a pic if you can Im curious , mine is fine but just like to see for grins
    oddhours, Siblue[QUOTED] and sudobash like this.
  11. May 9, 2025 at 2:53 PM
    #161
    Linuxrules
    Linuxrules New Member
    2024 Tundra
    I kind of want Colorado TJ to reply to this with his latest pictures
  12. May 9, 2025 at 4:17 PM
    #162
    Doofus
    Doofus New Member
    Good thought. TSS 3.0 should be on the refresh list as well
  13. May 9, 2025 at 8:16 PM
    #163
    aredub
    aredub Supply Chain Guru
    USA
    2001 Tundra SR5 AC 4.7 2WD
    King Coilovers, Pro Comp Wheels, BFG KO2s, Kenwood head unit
    Sure is … close
  14. May 9, 2025 at 10:28 PM
    #164
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Ok I sound crazy because the switch looks the same. I swear the new switch feels a bit smaller.
    Gray 2022
    Black 2025
    TucsonTundra1794 likes this.
  15. May 10, 2025 at 6:19 AM
    #165
    DRP
    DRP Old Member
    Dave
    Remember, black is a slimming color......;):thumbsup:
    75tranzam, sudobash, kirkb and 4 others like this.
  16. May 10, 2025 at 6:21 AM
    #166
    18" TRD Off Road Wheels
    We have seen very different porn. :eek2:
    drewpweinerMD, kirkb, AZBaldy and 2 others like this.
  17. May 10, 2025 at 6:32 AM
    #167
    PermaFrostTRD
    Northern NY
  18. May 10, 2025 at 8:26 AM
    #168
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    i don’t believe it will be a refresh or whatever the hell people want to call it, BUT there should be some small updates if toyota has been listening to their damn consumers :facepalm:
  19. May 10, 2025 at 8:29 AM
    #169
    Breathing Borla
    Northern Illinois
    like what?
  20. May 10, 2025 at 8:36 AM
    #170
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    front tow hooks, color match options on platinum/1794 trim levels, new factory accessories/add ons, etc.
  21. May 10, 2025 at 8:36 AM
    #171
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Tundra and Sequoia TRD pro deserve to get dual color Rigid fogs and some AUX switches standard.
  22. May 10, 2025 at 8:43 AM
    #172
    Breathing Borla
    Northern Illinois
    ok so just minor stuff , I see
  23. May 10, 2025 at 9:28 AM
    #173
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
  24. May 10, 2025 at 9:29 AM
    #174
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    damn.. i didn’t realize they don’t come with aux switches from the factory smh :facepalm:
  25. May 10, 2025 at 10:03 AM
    #175
    Don't hold your breath.
  26. May 10, 2025 at 10:28 AM
    #176
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    i never did in the first place, we all know how bad toyota is with fulfilling customer demands.
  27. May 12, 2025 at 4:42 AM
    #177
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    This is a list of least ugly girls hardly an endorsement or condemnation
  28. May 13, 2025 at 5:52 PM
    #178
    sudobash
    sudobash New Member
    Trial run of the new TRD Pro color for 2026 was performed on Friday, May 9, 2025. This leak was just posted anonymously in one of the Facebook groups.
    woods, astrength22 and chrisgibbs707 like this.
  29. May 13, 2025 at 5:54 PM
    #179
    Meh.
    woods, 75tranzam, BlackNBlu and 2 others like this.
  30. May 13, 2025 at 5:59 PM
    #180
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    is it a metallic or gloss color?
