Rear shackle? Exhaust cut?
Discussion in '2.5 Gen Tundras (2014-2021)' started by herd, May 9, 2025.
  1. May 9, 2025 at 7:16 AM
    herd
    herd [OP] New Member
    Need some help from some experienced folks. I installed Bilstein 6100s to level the front and its a small amount higher than the front, just enough that it irritates me but not likely noticeable to others. I thought about a minimum rear shackle 3/4" to the back to bring the back up a smidge. I'm also thinking of cutting the exhaust past the hanger to allow me to fit my 33" spare underneath. Will I need to do anything other than cut the exhaust and change out the shackles? Will these two problems work out okay with my plan and will it ride okay, be louder than my current TRD dual exhaust which my kids already complain about when they're in the truck? Thanks for the help guys.
  2. May 9, 2025 at 8:03 AM
    Has the alignment been done already? The height can be affected if it hasn't been done yet. If you have stock rear shackles, I am not aware of anything smaller that will allow the rear end to lower.
  3. May 9, 2025 at 9:48 AM
    herd
    I've already done an alignment and it's good, I just want to raise the back a little bit. I'm trying to get a feel from anyone if a small shackle lift in the rear will alter my ride much or any negative effects it may have. That and if it will require any additional changes.
  4. May 9, 2025 at 9:54 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    How many miles are on the truck? If the mileage is north of say 150k and you plan to tow or haul heavy loads frequently you may want to consider RAS instead of the shackles. You can dial in RAS to provide anywhere from 0.25-1.0" of rear lift in most cases and many report improved ride quality
  5. May 9, 2025 at 11:21 AM
    herd
    I wish dropping $600 was feasible for the RAS, but alas it isn't. Currently 64k on the truck and its see mostly groceries and umpire gear in the back with the occasional load of mulch or camping gear.
  6. May 9, 2025 at 11:30 AM
    Mountainmanjh
    Mountainmanjh New Member
    Northern Utah
    2012 Black Crewmax
    Eibach Protruck coilovers and shocks Total Chaos UCAs, bed stiffeners Deaver U748 leaf springs with Camburg shackles TRD sway bars, front and rear Gear Dominator wheels (18x9 18+) Cooper AT3 XLT (275/70r18) RCI engine, trans, and A-arm skids Transferflow 46-gal fuel tank Yakima Outpost bed rack Curt front hitch receiver SumoSprings (yellow) StartX remote start *coming soon* Auburn rear LSD RCI sliders, diff skid, cat guards Coastal offroad front bumper Badlands apex winch Kenwood DNX577S head unit
    You shouldn't need to cut exhaust to fit a 33". I have a 35 under mine with just the brackets removed.
    EDIT*
    I didn't realize you have the dual exhaust. My experience is irrelevant.
    AZBoatHauler likes this.
  7. May 9, 2025 at 11:36 AM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I have CB's +2 shackles on the rear along with a full size spare(295/70/18) and did not have to modify anything (except remove spare alignment guides). I just push the spare forward when tightening it up. I also put a roll of packing tape sideways between the spare and inside of hitch to help keep the spare forward. Sorry for the lousy photo. I do have factory rear exhaust.
  8. May 9, 2025 at 11:36 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Understandable. Might be worth saving towards RAS, as shackles and blocks typically shorten the life of leaf springs (they'll flatten out and start causing issues with ride quality sooner), and RAS works to prevent negative arch in the leafs, so it would very likely to prolong the life of the leafs (or at least not shorten it).
