Broken radiator
Discussion in '1st Gen Tundras (2000-2006)' started by rustbeltwarrior69, May 9, 2025.
  1. May 9, 2025 at 10:23 AM
    rustbeltwarrior69
    rustbeltwarrior69 [OP] New Member
    2004 Black Tundra SR5 AC (V8 4WD)
    frame replacement
    So I was pulling onto the highway and heard a squealing noise. Made it home and decided to check all the pulleys. In doing this I guess I put too much pressure on the radiator hose with my arm and the spot at the top of the radiator where the rubber hose connects broke off. Any way to fix this without replacing the radiator? I’m on a huge time crunch. Thanks
  2. May 9, 2025 at 10:24 AM
    rustbeltwarrior69
    frame replacement
  3. May 9, 2025 at 10:26 AM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Could try some jb weld or equivalent for a quick temporary fix if you don't need to go far
  4. May 9, 2025 at 10:37 AM
    I think you might be due for a replacement radiator from Denso. That plastic already appears brittle from what you described. I wouldn’t chance it with your cooling system by using a temporary fix, but that’s me.
    Thankfully, they’re super easy to replace.
  5. May 9, 2025 at 10:39 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    There's no way you're ever going to get a good seal and expect to hold pressure, and I don't think JB Weld is the answer. Look at the color of that radiator plastic. It's done. Just be thankful you don't have the dreaded "strawberry milkshake". Replace the radiator.
  6. May 9, 2025 at 10:40 AM
    That brown color is indicative of the aging plastic. Time to replace.
  7. May 9, 2025 at 10:44 AM
    Nicklovin
    Nicklovin Yap Yap
    Agreed on replacing it asap, figured he's asking for a help I need to get this home fix
    Sirfive likes this.
  8. May 9, 2025 at 11:08 AM
    Dude. That radiator is brown from age, it's supposed to be black. It's probably about 5yr/50k miles overdue for replacement, if not double that. You should be proactively replacing it at every timing belt change, if I'm being honest.
    Don't jury-rig your shit. Replace the radiator as it should've been done. If that part cracked, the transmission pass-thru line is probably not far away and you DO NOT want pink milkshake and a dead transmission!
    It shouldn't take more than 30 minutes to replace the radiator if you bust a hustle.
  9. May 9, 2025 at 2:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    All the above….
    G_unit3000, Sirfive and FrenchToasty like this.
  10. May 9, 2025 at 3:08 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Summit racing has denso for $160-190, can’t recall. Use the factory side rails, they fit better than what comes with it. Personally I wouldn’t recommend a repair unless it’s just to get to your work area. Mine split right on top of shroud, smelled coolant, but had to pressurize system to see the crack. The hoses should be good though.
    Jack McCarthy likes this.
  11. May 9, 2025 at 3:15 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Super glue & baking soda.
    G_unit3000 likes this.
  12. May 9, 2025 at 3:41 PM
  13. May 9, 2025 at 4:30 PM
    Mr Badwrench
    Mr Badwrench New Member
    Call around town. Someone is bound to have a radiator for it. You can probably change it out in an hour, there's not much in the way.
  14. May 9, 2025 at 4:38 PM
    rouxster70
    04ac2wdv65spd
    Please dispose of old coolant properly, it kills animals very painfully.
    shifty` likes this.
  15. May 9, 2025 at 4:44 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Just doing a +1 on what others have said. That brown color means it's done for.
    You're actually fortunate it's broken there. This particular design has the transmission fluid flow along lines inside the radiator. Those connections break when it gets old and brittle. Then you have coolant mixed in with the transmission fluid. Look up 'pink milkshake'.
    A new radiator is less than $200 plus obviously new coolant. Super easy job.
  16. May 19, 2025 at 4:23 AM
    rustbeltwarrior69
    frame replacement
    Yeah you guys were right. Took me about an hour from starting to driving out of my driveway.
  17. May 19, 2025 at 6:23 AM
    ATBAV8
    Tempe, AZ
    And now it's fixed right. Bet you feel pretty good about that. Well done.
