Black lug nut question
Discussion in 'Wheels & Tires' started by greggm, May 8, 2025.
  1. May 8, 2025 at 3:18 PM
    greggm
    greggm [OP] New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    Hi all since I went with the sexy bronze Method wheels, I had to do the matching black lug nuts. Being a PNW dweller, I'm on my third set due to rust. They just look really bad after a season or two and I end up replacing them. I believe they are only painted. Has anyone tried powder coating lug nuts? Would that be tougher? As soon as the first torque wrench scratch hits the new ones the process starts all over again and its getting old...
  2. May 8, 2025 at 3:26 PM
  3. May 8, 2025 at 3:28 PM
    greggm
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    No that appears to be a great solution! Thanks for sharing!
    Jim LE 1301 and RobertD like this.
  4. May 8, 2025 at 3:28 PM
    RobertD
    Robert
    DFW, Texas
    2nd the color lugs. They are also a good security measure cause without the removal tool (basically long tweezers with the tips bent) they would be really hard to remove.
    I've been running the blue for many years and have 0 complaints.
    Jim LE 1301 likes this.
  5. May 8, 2025 at 3:37 PM
    greggm
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    Set on order, thanks!:plane:
  6. May 8, 2025 at 4:28 PM
    :hattip:
  7. May 8, 2025 at 4:30 PM
    X2
    Order them directly from them not Amazon. They give you the tweezers and extra caps/wheel lock covers all for free.
  8. May 9, 2025 at 5:54 AM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
  9. May 9, 2025 at 6:29 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Does McGard make the style you need in black? I've had great luck with their chrome lugs over the years. They're not cheap but it's definitely a "but once, cry once" with them.
