mud and debris INSIDE fender walls
Discussion in 'General Tundra Discussion' started by mikesTundra77, Aug 1, 2021.
  1. Aug 1, 2021 at 8:45 AM
    mikesTundra77
    mikesTundra77 [OP] BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    Anyone else had to remove some screws and fasteners on inside front fenders to remove mud, leaves and debris from inside it? I must have collected it in there while offloading otherwise it's just 3 years of dust buildup and perhaps the leaves got in there from up top on the sides of the hood where it meets the windshield. Either way I'm worried about Alkaline mud causing rust down the road if I left it so I dug it out. There was a LOT 20210801_093716.jpg
    dailet likes this.
  2. Aug 1, 2021 at 8:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is a known "feature". You are absolutely correct on the methods of accumulation. It's also possible to clear out this space by opening the front doors and pulling back the rubber gap filler at the bottom of the fenders near the front edge of the doors and the rear of the front fenders. You may need to dig the leaves out manually, but clearing out the dirt/mud can be done with a garden hose.
  3. Aug 1, 2021 at 12:43 PM
    mikesTundra77
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    Thanks! I'll check that out soon
  4. Aug 1, 2021 at 2:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've known dang fire ants to build "ant condos" in that crap. Keep it cleaned out boys.
    dailet and mikesTundra77[OP] like this.
  5. Aug 1, 2021 at 2:28 PM
    mikesTundra77
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
  6. Aug 1, 2021 at 3:52 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Man. I had no idea. Thanks for the post Mike. Driver side was nasty (that side is parked near a crape myrtle). Passenger side was empty.
  7. Aug 1, 2021 at 4:10 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If you've got mud there, then you should check your frame. The inside of the C channel frame is a mud hoarder:mudding:
    Sunnier and Uhhhh.... like this.
  8. Aug 1, 2021 at 8:06 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I read that first sentence in Boomhauers voice :rofl:
    classiccat and FrenchToasty like this.
  9. Aug 1, 2021 at 8:18 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Dang ol' fire ants building up them dang ol' ant condos man. :rofl:
    Sumo91[QUOTED] likes this.
  10. May 8, 2025 at 11:43 AM
    dailet
    dailet New Member
    tom
    2020 white tundra crewmax
    2020 tundra, 100k miles, each side packed with about 3 cups of wet mud/leaves at bottom, and a column of leaves as far as i can reach in the upper space. Do dirt & leaves enter from above, at hood/windshield corner? Could this be blocked to prevent leaves entering? Clean with compressed air from top and/or shop-vac?
