Preventative Maintenance for a used Tundra purchase
Discussion in '2.5 Gen Tundras (2014-2021)' started by Eskew5, May 1, 2025.
  1. May 1, 2025 at 7:18 AM
    Eskew5
    Eskew5 [OP] New Member
    I recently took ownership of a 2016 4x4 1794 with 90k miles. It seems to be in great shape, but I'd like to do any preventive maintenance that might be needed to keep it running for a long time to come. Synthetic oil, cabin and engine air filter and new tires were taken care of pre-purchase. Toyota Owners service history shows that Oil changes were performed on time throughout its life and front pads / rotors turned taken care of at 69k. Other than that, I see no record of fluid changes etc. There was a note about rear brakes possibly having a stuck caliper pin but no other info or indication of fix or changing rears.
    I am thinking I should go ahead and have the following changed. Thoughts? Overkill? Am I missing anything?
    Coolant
    Front / Rear Differential fluid
    Transmission fluide
    Check brakes
  2. May 1, 2025 at 7:52 AM
    yakeng
    yakeng 3URFE Apologist
    Probably about time to replace the serpentine belt.
  3. May 1, 2025 at 8:04 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    As you said coolant changes seem to be very important to these engines.
  4. May 1, 2025 at 8:10 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The million mile guy didn't change his coolant :p
    Retired...finally likes this.
  5. May 1, 2025 at 8:12 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    I don't think your list is overkill at all. I'd add:
    - Brake Fluid flush
    - Transfer Case Fluid
    - Spark Plugs
    - Grease u-joints
  6. May 1, 2025 at 8:13 AM
    Eskew5
    Thank you for the great replies! I did not know about the serpentine belt and will add that to my list. I am not mechanically inclined at all and could have easily confused that with a timing belt which I know does not apply of the 5.7. I hope the coolant has been changed at least once and just not documented, but if not, I really hope it's not so acidic that it has damaged my head gaskets. After owning German cars the last few years, it's comforting having a Toyota again and not worrying about reliability and breakdowns.
  7. May 1, 2025 at 8:14 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I don't buy that. I think his dealer probably did multiple coolant flushes at various service intervals as part of larger "xxx,xxx mile service" packages and Mr. Shepard was simply unaware of exactly all those services entailed.
    AZBoatHauler and atc250r like this.
  8. May 1, 2025 at 8:14 AM
    Eskew5
    wow! I saw that article, insane that he did it on two trucks.
  9. May 1, 2025 at 9:06 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Guess we'll never know. I'll do my coolant changes though.
  10. May 1, 2025 at 11:26 AM
    blenton
    blenton New Member
    Yup. Same here.
    Add to the list: PCV valve, belt tensioner, and idler pulley. The tensioner and pulley may not be necessary, but I would do them while you are in there.
    Also, the transmission has a drain and fill plug that makes servicing it simple. I prefer a couple of drain and fills over a flush, but that topic can be hotly contested.
  11. May 1, 2025 at 11:38 AM
    MGMTundra18
    MGMTundra18 New Member
    Charlotte NC
    2018 MGM Tundra 4x4 TRD Sport
    I like this chart, it covers all the important bits.
    Eskew5[OP], HulkSmurf14 and blenton like this.
  12. May 1, 2025 at 11:52 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've done all of that and I'm barely over 108k
  13. May 2, 2025 at 2:19 PM
    Eskew5
    Very helpful, thank you for sharing!
    I went out and looked at my coolant today and it looks super clean, bright red/pink so I am hopeful that means it has been changed at least once since the truck was made. I will get her in for service very soon using the info in this thread.
    MGMTundra18[QUOTED] likes this.
  14. May 8, 2025 at 10:55 AM
    Eskew5
    Not to ask a dumb question - using the handy chart in this thread, am I asking for a flush or change (drain/fill) for transmission, front and rear differential when I go in for service? Coolant is definitely a flush, right?
  15. May 8, 2025 at 10:57 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Drain and fill for all but the coolant and brakes. Flush for coolant and brakes
    Eskew5[OP] likes this.
