What do you have mounted on your bed rails and or Diamondback Cover?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bergy24, Apr 24, 2024.
  1. Apr 24, 2024 at 4:38 AM
    Bergy24
    Bergy24 [OP] New Member
    Now that I have a Diamondback cover and my bed is secure and pretty much watertight, I am interested in mounting some stuff to the bed rails and looking for ideas.
    If you have stuff mounted to the Diamondback cover, please share those ideas too.
    As always, this is worthless without pictures.
    I am thinking a Fire Extinguisher with quick release mount to start.
    Small Storage Bin for straps.
    First Aid Kit?
  2. Apr 24, 2024 at 5:02 PM
    seydou
    seydou Distinguished Member
    First of all, what does "pretty much watertight" mean. Sounds like you hope it will be watertight but don't really know yet.
    In any case, I would not mount anything in your bed that may get wet, like an FAK.
    And I also want my fire extinguisher in the cab for ease of access. Last thing in need to do if I have a fire , is to take the time to open my bed and access the fire extinguisher.
    Everything you mention can be stored under the rear seat. Secure, watertight and accessible.
    Bergy24[OP] likes this.
  3. Apr 24, 2024 at 10:45 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I just keep the adjustable cleats on the bed rails so I can secure loads.
    I got the DB crossbin, so anything I want to carry around goes in there.
    NewImprovedRon and Bergy24[OP] like this.
  4. Apr 25, 2024 at 1:40 AM
    Bergy24
    To date I have only had one very small spot of water in the bed, but I think I caused that when I opened the front panel.
    When I checked for water in the bed after other rain events (some were over 3" of rain), I opened the tailgate and found that the bed was bone dry.
    I have not drove with it in the rain a lot though.
    Your points about the fire extinguisher and other stuff are valid and I appreciate the information.
  5. Apr 25, 2024 at 1:42 AM
    Bergy24
    What size crossbin do you have? Any regrets getting the one you have?
    panicman[QUOTED] likes this.
  6. Apr 25, 2024 at 5:00 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I dislike my crossbin. Wast of a few hundred bucks. Can't fully use the bed length anymore and accessing the bin in any sort of usable way is nonexistent. To get into the middle portion is impossible without a step ladder or taking the diamondback off and walking into your bed
  7. Apr 25, 2024 at 5:07 AM
    Bergy24
    This is exactly what I was thinking as well. While the concept is a good idea, the usability of a deep bin is not. I think totes or storage bins would be a better idea.
  8. Apr 25, 2024 at 5:51 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Back to your original request..
    I installed a Hi lift and traction boards on the rails at the front of the bed. Then on the sides there are 2 gallon rotopax in front of dual swing cases. Everything has custom mounts that I built to specifically hold each item. If you want those pics I can get those too. IMG_7906.jpg
    equin, SD Surfer, HulkSmurf14 and 3 others like this.
  9. Apr 25, 2024 at 11:05 PM
    panicman
    Eric
    I can have the cover and bin off the truck in about :10, and it is infrequent I need all the room in the bed.
  10. Apr 26, 2024 at 2:00 AM
    Bergy24
    What mount is that for your jack? Please post pictures of the custom mounts when you get time?
    Thanks
  11. Apr 26, 2024 at 2:03 AM
    Bergy24
  12. Apr 26, 2024 at 3:09 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    why not just remove the existing bracket and slot a t-nut through? You’d need a little longer bolt I suppose but would accomplish the same thing.
    or mount the track to the rails using a couple t-slot nuts and bolts.
    Bergy24[QUOTED][OP] likes this.
  13. Apr 26, 2024 at 3:11 AM
    Bergy24
    That may be a good option.
  14. Apr 26, 2024 at 5:31 AM
    1UP
    1UP Truck Gang
    Unless you 8' tall that appears to be taken from a 4' step ladder? Do you keep it in the bed as well or just "climb" up yhe side of your truck when accessing it.
  15. Apr 26, 2024 at 5:56 AM
    shawn474
    MoCo, Maryland
    I am easily able to access my cross bin by standing on the tire or the step rails. I can reach the middle and lean over fine. But I am 6’2”….shorter people may have a problem reaching
    NewImprovedRon likes this.
  16. Apr 26, 2024 at 7:58 AM
    panicman
    Eric
    I am 8' tall.
    1UP and NewImprovedRon like this.
  17. Apr 26, 2024 at 8:02 AM
    panicman
    Eric
    Hardee har. I'm 6'. I think I held the phone up to get that pic.
    I can nearly reach the center of the bin standing at the side of the bed. The items that would typically go in the center well of the bin are big enough to grab- tire chains, back pack, rifle, bright red Costco bag...
    I wouldn't put anything small in there.
    equin, 1UP and Bergy24[OP] like this.
  18. May 2, 2024 at 1:03 PM
    trj
    trj New Member
    Tom
    2020 Tundra SR5 TSS Quicksand
    Re rails. These work well for tie downs.
    https://www.macscustomtiedowns.com/search.aspx?ss=versatie tundra track kit
    Holes are pre-drilled, installs w/screwdriver. Compliments diamondback great.
    I have the short bin too up next to cab.
    Yes the middle is hard to reach but it’s great for stuff you don’t access much (backpack), and I just stand on wheel (I’m 5-10”) and step bar (nerf bar? Where that name come from?). Also I purchased bins from HD that slide under it perfectly.
  19. May 2, 2024 at 2:00 PM
    Bergy24
    I’ve found some E Track adapters on Amazon that allow me to add bins to the rails. I could have installed T nuts directly to the bins, but this way allows me to remove them quickly and easily if needed. About $86 total for all 4 bins and all the adapters, as well as 8 E Track rings. I did have to cut a little off the backing but to allow to fit in the vertical position.
    ForceV4 and Muddydog1996 like this.
  20. May 8, 2025 at 10:41 AM
    Muddydog1996
    Muddydog1996 New Member
    2021 CM SR5 Trail Edition Army Green
    This is the solution I'm looking for to add some shallow storage under my Diamondback. Can you point me to E Track adapters for Tundra bed rails?
  21. May 9, 2025 at 4:37 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    link to bins and adapters?
  22. May 9, 2025 at 7:57 AM
    Muddydog1996
    I see the bins at my local Lowes/HD stores. Just wondered how you're attaching the E-Tracks to the Tundra's T-Slots? Are you just bolting E-Tracks on with T-slot bolts/nuts?
    panicman likes this.
  23. May 10, 2025 at 9:44 AM
    panicman
    Eric
    IMG_0197.jpg Looks like he may be using a threaded plate type adapter. I have T-slot adapters and I bet they'd work too.
    Muddydog1996 likes this.
  24. May 10, 2025 at 10:19 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
  25. May 10, 2025 at 10:25 AM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Nice setup!
  26. May 10, 2025 at 6:01 PM
    SD Surfer
    Bruce
    So Cal
    Thank you sir!
  27. May 13, 2025 at 3:47 AM
    Bergy24
    Sorry. I was on vacation for 2 weeks.
    This is what I used to attach the bins to the tundra bed rails.
    https://www.amazon.com/dp/B0CLY641DB?ref=ppx_yo2ov_dt_b_fed_asin_title
    Muddydog1996[QUOTED] likes this.
  28. May 13, 2025 at 10:30 AM
    Muddydog1996
    Did you pull the power for your power adapter directly from battery or did you tap into something closer to the bed?
  29. May 13, 2025 at 10:38 AM
    SD Surfer
    Bruce
    So Cal
    Straight to the battery.
    I wanted constant hot without having to futz with key, running lights, any other switches to energize.
    I mostly use the 12V to plug in my portable shower to rinse off after surfing so I'm dripping wet, don't wanna' be messing with my keys.
  30. May 13, 2025 at 12:12 PM
    Muddydog1996
    That's great. I would have loved something like that during my (younger) surfing days. In fact, I frequently have to work these days on the beach and hate it when I don't have a way to clean the sand off my feet/legs.
