Cutting hole in Skid Plate
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, May 8, 2025.
  1. May 8, 2025 at 9:03 AM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Anyone done this on the OEM to allow access to oil drain bolt?
    Tips? Angle grinder or hole saw?
    It would be great to see a photo esp. with where you did the cut.
    Thanks.
    Corndog123 likes this.
  2. May 8, 2025 at 10:01 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A step bit is what I would start with personally. I haven't done this on my truck FYI
  3. May 8, 2025 at 10:04 AM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    I’d get a Fumoto valve with the long nipple if it clears your plate. Use a step bit just wide enough for a small hose and maybe pliers to open the valve. Otherwise you have three 10mm bolts and 5, 13mm bolts and you’ll need an extension.
    Corndog123 and robabeatle[OP] like this.
  4. May 8, 2025 at 10:21 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  5. May 8, 2025 at 10:28 AM
    Now that right there is a winner.
    I prefer my Votex unit. Lower profile. Drains faster.
  6. May 8, 2025 at 10:55 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The drain plug isn't covered up with the factory skid plate is it? The oil filter is but I don't pull my skid plate to drain the oil.
    Corndog123, MT-Tundra and HulkSmurf14 like this.
  7. May 8, 2025 at 12:00 PM
    It is not. I do not remove my skid plate for oil changes. Drain bolt is easily accessible. Filter can be removed and replaced from the top. I place a piece of coated cardboard (oil or air filter box works great) under the oil filter to direct the oil out the back of the skid place.
    Corndog123 and Geezer like this.
  8. May 8, 2025 at 12:30 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I never even thought about trying to get to the filter from the top. I will try that next time.
  9. May 8, 2025 at 12:30 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Removing that skid plate is not difficult. It's 5 bolts. Takes all of about 30 seconds with my Milwaukee 18V impact. It's not even that heavy once the bolts are out. I don't like all the oil that gets in it when you try to change the filter from the top. Doesn't matter if you throw rags, pigmat, or are very fast. You're still going to get oil in there.
  10. May 8, 2025 at 12:38 PM
    robabeatle
    AZ
    Hmmm... How have I never noticed this??
    Corndog123 and FrenchToasty like this.
  11. May 8, 2025 at 12:39 PM
    robabeatle
    AZ
    If I can save a few minutes, it is worth it to me.
  12. May 8, 2025 at 12:39 PM
    robabeatle
    AZ
    Could you please send a link to that part?
    Corndog123 and Sirfive like this.
  13. May 8, 2025 at 12:40 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    To each their own….Given it’s every 5k miles for my schedule, I choose to take off skid plate. Gives me chance to check other things and take a little of the old oil on a rag and wipe the frame I can get to. Plus it gives me time while under there to work on a plan of how to get this ole body up.
  14. May 8, 2025 at 12:47 PM
    ATBAV8
    Tempe, AZ
    Ahh... You're one of those guys who doesn't even let the last drops come out of the quart. Git 'er dun!
    I prefer to have the skid plate off to: A) Keep it clean. B) Have the ability to inspect all of the other things hidden by the skid plate and marvel at the beauty of the underside of the 2UZ-FE.
    I've caught plenty of problems on vehicles over the years by spending an extra few minutes.
  15. May 8, 2025 at 12:52 PM
    robabeatle
    AZ
    Yup, too many other things to take care of.
    G_unit3000, Tamarack and FrenchToasty like this.
  16. May 8, 2025 at 1:02 PM
    I'm backwards. I leave my skid off, unless I'll be out doing something that may put my goods at risk. I think of the skid as an atheltic supporter. If you don't want to get cracked in the nads, you wear it. But nobody in their right mind would walk around with a jock strap to, say, the grocery store or movies. The damn things are uncomfortable af.
    Maybe that's why I get shit gas mileage, even on the interstate. But I can't imagine that skid plate provides that much relief from wind resistance.
  17. May 8, 2025 at 1:08 PM
    ATBAV8
    Tempe, AZ
    Not sure on the 1GT, but on my 4Runner I drove around a while without the stock skids while I was waiting for my RCI skids to show up. There was a noticeable 2-3 MPG decrease without the skids. Negated that when I installed the RCI skids. Now, I understand the 4Runner is like a brick on wheels, but there might be something to the aerodynamics of the skid plate on the 1GT.
  18. May 8, 2025 at 1:10 PM
    Well shit. I guess I need to clean mine out and bolt it back on this weekend, I gotta do a job 2hrs north of ATL, on the other side of Cleveland next week. It'll take the better part of a tank of gas to get there and back. I'm skeptical, but that would also explain why the fuck everyone else around here with similar lift/config gets 1-3 mpg better than me. I didn't see much change in mileage when I took it off. But I was doing mostly city driving back then.
  19. May 8, 2025 at 1:16 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Amen to that. While the oil is draining I take my light under the truck and inspect for anything amiss. Been doing that way for 25 years now. As soon as my OEM filters arrive I'll be doing it again. No fuss.
    BubbaW[QUOTED] and ATBAV8 like this.
  20. May 8, 2025 at 1:45 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I think i need a ball valve type. The drain hole in my skidrow plate is just a bit too smallto fit my hand through. I dont think i could reach this.
  21. May 8, 2025 at 1:46 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It's amazing what some of our country bumpkins wear into our Wal Mart worse than jock straps :facepalm:
  22. May 8, 2025 at 1:56 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    That is very Clean,
  23. May 8, 2025 at 4:46 PM
    bfunke
    bfunke Tundra Curmudgeon
    The 2.5Gen guys do this to access the cartridge filter housing.
  24. May 8, 2025 at 6:45 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I might cut the wing off the driver side portion to get to the filter. I want the skid on there to protect the rad
    whodatschrome likes this.
  25. May 9, 2025 at 9:12 PM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    I put a Fumoto valve on my 3.4, and the filter is accessible from the topside so I don't even jack the truck up to do oil changes.
  26. May 9, 2025 at 9:17 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    ^^^^this right here! My brother in law never bothered to reinstall the skid plate after he did his oil changes. A large tree branch ended up piercing his radiator.
  27. May 9, 2025 at 10:35 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    It takes like MAYBE 90 seconds to undo the 5 bolts for the skid plate with a cordless ratchet. Lets say another generous 90 to move it out the way. Reverse to reinstall. So o maybe, six minutes every 3k-5k miies.
    BTW, I did actually did an oil change just today. Yes, it was an extra step. Not exactly time consuming or difficult.
    Removing that skid plate helps you see more. For example. leaks you may not see as it's all caught and hiden by the skid plate. If you're trying to shave 6 minutes off an oil change, I really don't know that I'd want to ride in a vehicle you have wrenched on. Never mind how many oil changes it would take to get that the time back spent 'fixing' the problem.
    ETA - I also did not jack the vehicle when I did the oil change, it remained tires on the ground, and I am a 'husky' chap.
    NewImprovedRon likes this.
  28. May 10, 2025 at 2:17 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Added bonus: If you remove/replace the skid plate a couple of times per year then you don't have to use a drill/tap to do it. It doesn't take long for those bolts to rust in place.
  29. May 10, 2025 at 3:48 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Yep, that's my method as well. But I also have time that others may not so to each his own. I like being able to see the ender side of my engine and transfer. Along with axles/CV joints, hoses etc. It's always been fine but ...... doesn't hurt to check.
  30. May 10, 2025 at 8:50 AM
    Fragman
    Fragman New Member
    Actually, you bring up a good point. I don't have to struggle with rust where I am, so perhaps it's a little unfair of me to say 'it just takes 90 seconds' when I'm driving a truck that spent it's entire life in the Houston area. But you also bring up the point that removing and replacing those bolts helps prevent them rusting in place.
