BATTERY CHANGE...
Discussion in '2.5 Gen Tundras (2014-2021)' started by BCB, Apr 27, 2025.
  1. May 7, 2025 at 5:08 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    It will eventually recalibrate, when I bought mine new 2020, it said like 500+ miles per take on the 38. But per my driving it’s more like 409.
  2. May 8, 2025 at 4:29 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I was able to check the compass issue. It will switch when you switch the compass/map mode in the navigation system.
  3. May 8, 2025 at 6:21 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    RUNNING BOARDS & WINDOW VISORS
    I went to the maps in navigation and touched the compass on the screen. It changed it in the cluster and now it is back to as before...
    One problem down, one to go...
    I will let the tank go to 1/4 or thereabout for a couple of tries and see if that solves the "Range" problem...
    Thanks...
