What use for the mechanical key with smart key system?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyManFL, May 7, 2025 at 10:23 AM.
  1. May 7, 2025 at 10:23 AM
    TundyManFL
    TundyManFL [OP] New Member
    2021 MGM TRD Pro CrewMax
    I have a 2021 with smart key. When I purchased I got 2 FOBs and 1 mechanical key. (Edit: This post is specifically about that third and separate mechanical key, not the mechanical keys that are integrated into the FOB.)
    For a long time I thought it was a valet key and then actually tested it today. It opens the glove box which seems like a dead giveaway that its not a valet key. It also does not start the truck, error message is along the lines of touch key to ignition button, which does nothing so I assume there's no chip of any kind inside of it.
    I also double checked manual which didn't mention any valet key, but it did mention mechanical keys as an option for type C system (smart key).
    So then: what exactly is the mechanical key good for if it unlocks but can't start.
  2. May 7, 2025 at 10:24 AM
    When your battery dies and you need to unlock the truck to pop the hood. Just an easy scenario that it's good for.
    It's specifically for the physical locks. Let your imagination run wild.
  3. May 7, 2025 at 10:29 AM
    TundyManFL
    Alright, but in that situation my fob has the mechanical key as well, but point taken: it's basically a way to physically unlock the truck.
  4. May 7, 2025 at 1:33 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I leave mine in the truck so i can lock the tailgate if needed.
    You can unlock your truck with the key inside the fob too.
    TundyManFL[OP] likes this.
  5. May 7, 2025 at 1:46 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    I had a plain metal key cut at the local hardware store to allow me to leave my truck running while I run into a gas station, with my "smart key" still in the ignition, and I can lock the doors of the truck.
    The truck wouldn't allow me to use a spare "smart key" (on my 2018 that means a key and fob combo unit) to lock the truck while it was running. But the $3 key I had cut at True Value does work for that purpose. Guessing yours could work similarly
  6. May 7, 2025 at 4:38 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    Unlocking the tailgate with the FOB key can be challenging.
    For that you can use the mechanical key which gives you more leverage.
    Or FTW you can do what I did and install a power tailgate lock. :101010:
  7. May 8, 2025 at 7:35 AM
    seydou
    seydou Distinguished Member
    I put that key on a small ring with the keys to the tailgate/topper and trailer locks. It lives in my left pants pocket because it is frequently used. The fob lives in my right pocket along with a high speed lead dispenser, which is not accessed frequently.
