BATTERY CHANGE...
Discussion in '2.5 Gen Tundras (2014-2021)' started by BCB, Apr 27, 2025.
  1. Apr 27, 2025 at 12:14 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    RUNNING BOARDS & WINDOW VISORS
    Recently had to change the battery in my '21 Tundra...
    I contacted the service department where I purchased the truck and asked if disconnecting the battery would cause problems--They said "no"...(I heard it might)
    Well, all's well, EXCEPT, the "Range" in miles of gasoline in tank...
    When I fill the truck, it says I have a range of 590 miles--Ahhhhh, NO way...
    Usually it said 420 or there about after fill up, before battery change...
    Any thoughts--Is there a reset on it...
    Thanks...BCB
  2. Apr 27, 2025 at 12:16 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    It’s fine. It will recalibrate.
    coldcanuk, mtucker, bulldog93 and 4 others like this.
  3. Apr 27, 2025 at 12:19 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    @Tyman is correct, it will recalibrate.
    Might take 3 or 4 tankfuls of gas until the ECU figures your average MPG..
    How do you reset it?
    You reset it when you disconnected the battery..:thumbsup:
    You can also press and hold the ENTER button on the steering wheel to reset it.
  4. Apr 27, 2025 at 12:22 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    As stated, it will recalibrate, but if you'd like to change your battery seamlessly next time, if you have a jumper back or another battery you can connect the cable to the power and ground leads before disconnecting the battery and make sure they stay connected until the new battery is connected.
    BCB[OP] likes this.
  5. Apr 27, 2025 at 12:32 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    WoW, that was quick...
    I was hoping it would reset once it figured out what type of average mileage I get...
    Sure wish it got 590 miles from a full tank of gasoline...
    Thanks All Who Replied...
  6. Apr 27, 2025 at 12:34 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    My 26 gallon tank will read over 400 with a reset.
    It comes down to around 315 after a couple weeks..:mad:
  7. Apr 30, 2025 at 4:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    How many people even look at this? I did once out curiosity when I drove 2 different routes to and from hunting ranch.
  8. Apr 30, 2025 at 5:37 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Welcome to the forum @BCB. As noted the computer will recalibrate over a short period of time.
    However, for your awareness these trucks are sensitive to battery issues and can start doing weird things when the battery starts to go. Otherwise don’t be afraid to disconnect or connect the battery when needed.
    BCB[OP] likes this.
  9. May 3, 2025 at 7:22 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    Three tanks of gasoline and no re-calibration...
    Maybe takes more tanks of gasoline?
  10. May 3, 2025 at 7:39 AM
    EmergencyMaximum
    What happens is your previous average mpg gets cleared after removing power supply. Computer doesn't see what to base remaining miles off, so it defaults to programmed cruise range. It is most certainly possible to get that range if you immediately jump on the freeway and do 60mph on your way to...where ever.
    That's a 38gallon tank, yes?
  11. May 3, 2025 at 7:43 AM
    Ericsopa
    Ericsopa Old man and the sea
    My solution to being lied to repeatedly is to merely ignore the source.
  12. May 3, 2025 at 7:46 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
  13. May 3, 2025 at 7:49 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    I don't understand that statement...
    So, you must know the correct answer if you know I'm be lied to?
  14. May 3, 2025 at 10:38 AM
    Ericsopa
    Simple, dear Watson. If on fill-up, your instruments keep telling you that you can drive 200 miles farther than you know it'll really go, simply ignore the instrument.
    I refer you to the @Stumpjumper post above.
  15. May 3, 2025 at 11:27 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    Well, thank-you Sherlock…
    But I think I will research this issue a bit further as I have never taken the simple way out, that being—Just To Ignore Something…
    Also called “The-Ostrich’s-Head-In-The-Sand Philosophy”
    But I _Do_ appreciate your efforts to solve my concern…
  16. May 3, 2025 at 1:15 PM
    Ericsopa
    I tend to refer to it as obsessing over trivial matters, but .....
    Press on, young'un. :D
  17. May 3, 2025 at 1:26 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    OP, ECU computes that range value based on running fuel consumption average and fuel sender position. It’s giving accurate information based on what it knows.
    If you’re a math and science guy, think in terms of the statistical laws of small sample sizes versus large sample sizes. In the short term you may see greater volatility in range values if you do a lot of varied driving. It will get more consistent with more sampling data over time. For now, enjoy your awesome fuel economy.
  18. May 4, 2025 at 4:45 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    Yep, a science degree post-Uncle Sam over ½ century ago and with that went some math and a couple of statistics courses…
    I understand the representative samples to make the calculations worthwhile…
    I just thought the computer would use the mpg each fill-up and do the math. And, as more fill-ups occurred, the range per tankful would become more accurate. But apparently it doesn’t work that way…
    Yet, when I purchased this Tundra new, it had the range calculated to what was pretty darn accurate without many, likely only 1, tankful and < 75 miles on it or thereabout. Maybe that was preset at the factory as they know the gas mileage the vehicle is likely to get and that range changed with time and fill-ups and became more representative of my driving conditions and the way I drive…
    I still continue to think there may be something wrong with the computer or whatever does the calculations…
    I guess time will tell the tale…
  19. May 7, 2025 at 6:15 AM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    Well, 8 fill-ups and the "Range" has not adjusted--It's not going to...
    And now, the compass that used to circle as you changed directions is now stationery, and there is a little red needle that indicates the direction you are traveling. The needle is so small you can't even begin to see it...
    Moral of this tale--DON'T UNHOOK THE BATTERY WITHOUT SOME OTHER FORM OF CURRENT TO THE CABLES. JUMPER CABLES AND ANOTHER BATTERY (?)
    I suspect there will be other surprises as time goes on...
    I wonder if one of those "things" you plug into the vehicle would find where the problem might be located?
  20. May 7, 2025 at 6:24 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Not sure what’s going on with your truck but mine is also a ‘21 and have unhook the battery numerous times and have no issue like yours.. i’d try going into the menu on the cluster and reset the mpg calculation. See if that do anything.
  21. May 7, 2025 at 2:22 PM
    Dsptundra
    Austin TX Area
    If you mean the red compass arrow on the navigation? You can touch it and it should change the map from always pointing up for north to pointing the direction you are going.
    What is your display showing for current range? How low are you letting the tank get before filling it back up?
  22. May 7, 2025 at 2:55 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    I'm talking about the compass in the center of the screen in front of the steering wheel not on the navigation screen...
    When I fill up it shows over 500 miles range...
    I usually fill up before it is half empty--generally around 14 gallons...
  23. May 7, 2025 at 3:29 PM
    Dsptundra
    Austin TX Area
    This is what my compass looks like. Truck stays stationary while the letters representing the direction move around. Does yours look different? I have not found that there any settings to make it look different but maybe I missed them.
  24. May 7, 2025 at 3:34 PM
    Dsptundra
    Austin TX Area
    Also, I would run it down to like a quarter tank to see if that makes a difference. The computer may not be getting a big enough sample size if you are filling that early.
  25. May 7, 2025 at 3:41 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    That's the one I want. And I had one similar to that one before I disconnected the battery...
    The compass I have now has a little red needle that moves and north is always at the top--The red needle is so small I can't see it...
  26. May 7, 2025 at 3:41 PM
    Dsptundra
    Austin TX Area
    How about a picture?
  27. May 7, 2025 at 3:41 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    Yea, I'm gonna do that...
  28. May 7, 2025 at 3:47 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
  29. May 7, 2025 at 3:54 PM
    Dsptundra
    Austin TX Area
    A couple things:
    I was reviewing the manual and it appears you will need to run the fuel lower for it to register correctly.
    Also, the compass in the dash cluster is connected to the compass in the navigation. If you have navigation in your truck try touching the compass on that screen display and see if it changes the style shown on your dash cluster. I am not in my truck to test this myself but can test it later.
  30. May 7, 2025 at 4:04 PM
    BCB
    BCB [OP] New Member
    BRADLEY
    '21 TUNDRA SPORT
    Thanks...
    I'll try the navigation compass tomorrow and see what happens...
    And, I'll let the tank head towards the empty mark...
    Dsptundra[QUOTED] likes this.
