Florida AF Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by Florida AF, Mar 24, 2023.
  1. Feb 18, 2025 at 7:21 AM
    #91
    Florida AF
    Florida AF [OP] Florida Outdoors... Heaven
    Logan
    North Florida
    Also, about a month ago....
    I made it to some pavement and was able to install my Secret Santa gift from one of our amazing forum members. Installed a set of road legal Rigid pods in the bumper. I will use the old lights on the OVS rack when I get bed power done.
    ToyoMafia and BlueRibbon4x4 like this.
  2. Feb 18, 2025 at 7:27 AM
    #92
    Florida AF
    Logan
    North Florida
    Took the wife and little one out for a Vday weekend camping trip. Averaged 8.5 mpg and spent a couple more stops than usual at its watering hole.
    Overall the truck handled great and the fam really enjoyed their time.
  3. Feb 21, 2025 at 6:22 PM
    #93
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Man, I thought I got away from hurricanes when I moved away from Florida in 2009. Nope, Helene had her way, and there's still tree debris at various places around town not picked up yet.
    Stay safe down there.
  4. Feb 28, 2025 at 12:56 PM
    #94
    Florida AF
    Logan
    North Florida
    Getting ready to head out of town for work.. had to renew all the tags because of a bday that happens while I am out of town. I decided to nuke the Ranger and transfer its tag the truck...
    Small, but I like it:
  5. Mar 30, 2025 at 8:04 PM
    #95
    Florida AF
    Logan
    North Florida
    Test drove this for the weekend... held and brought some smiles...
  6. Apr 3, 2025 at 8:55 AM
    #96
    Florida AF
    Logan
    North Florida
    Got super annoyed at the water intrusion on my bed during the last rain event, so randomly I emailed Retrax asking for a WTF update. I fully expected nothing to be said/done, but they just asked me for my shipping address and truck details. Fingers crossed!
    Other than that, the truck has been putting work in moving stuff around the property and is getting ready for a camping trip in the mountains. The Alcohol reset worked like a dream and I have had no problems since. So now I just need to get it in for an oil change, tire rotation and inspection before loading up for the mountains.
    Pictures to follow when something changes, but for now... nothing.
    BlueRibbon4x4 likes this.
  7. Apr 3, 2025 at 8:58 AM
    #97
    Florida AF
    Logan
    North Florida
    ok, so update... they are sending replacement parts out.... wow....
  8. Apr 15, 2025 at 5:27 PM
    #98
    Florida AF
    Logan
    North Florida
    The sent out a replacement drum and I had to use the previous rails and tie downs... forgot how much of a PITA/easy the install is... lol.... anyway, got the drums swapped and noticed two changes right away. 1) they have a new label on the cover that I will find a way to get off. It doesnt match the rails older stickers either. 2) the clear drain tubes have been replaced with black slinky lines.. They are much cheaper feeling and do not fit in the hole as previously, but this will be a problem for another day. Tonight its closed back up and I will water test it tomorrow.
  9. Apr 29, 2025 at 8:02 PM
    #99
    Florida AF
    Logan
    North Florida
    New bed cover is holding back water like I expected. So now I will work on sealing some gaps in the tailgate area. Couple major rain events and I had very little water inside the bed! So I am much happier on that front.
    Went for an awesome camping trip and did some exploring around the North GA area. We had a great time and the truck did great. She drank fuel, but the changes so far have truly paid off. Next up, it looks like I will be upgrading/adding sway bars to try to get a more planted feeling both on the roads and while towing. Other than that, going to focus on some other financial goals and try to avoid spending any more money on it for now... so the build thread may die off for a while. I do need to finish installing some already purchased things, so hopefully that happens here before too long.
    BreyTundy and BlueRibbon4x4 like this.
  10. May 7, 2025 at 1:33 PM
    #100
    Florida AF
    Logan
    North Florida
    Got the rack put back on... heading back out for two weeks and want the awning, water and rod holders ready for this trip.
  11. Jun 16, 2025 at 6:13 PM
    #101
    Florida AF
    Logan
    North Florida
    Back on pavement and finally installed my RAS.... I'll clean up this post and do more details when I'm back on a computer.
  12. Jun 16, 2025 at 6:14 PM
    #102
    Florida AF
    Logan
    North Florida
    Started installing my FRAC and am hitting a roadblock on the switch... Nothing like having your radio area torn apart and doing the searches on your phone lol
  13. Jun 16, 2025 at 6:17 PM
    #103
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    (gulp)
    Good luck sir
  14. Jun 16, 2025 at 7:34 PM
    #104
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    what is a FRAC ?
    Forgive my ignorance cause I know someone will be that guy
  15. Jun 16, 2025 at 9:54 PM
    #105
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Front Rear Anytime Camera
    Florida AF[OP] likes this.
  16. Jun 17, 2025 at 5:55 AM
    #106
    Florida AF
    Logan
    North Florida
    Thank you sir. Quit for the night but I'll try again later today.
    An amazing device that allows you to turn on your reverse cam anytime, as well as add a front cam. I will be using the front cam to make a bed view cam at some point.
    It does more but that's the part I am focused on.
  17. Jun 17, 2025 at 6:29 AM
    #107
    Tripleconpanna
    Did you get your switch issue figured out... I really wasn't sure if you were having a problem with wiring, location of the switch, etc.. :notsure:
  18. Jun 17, 2025 at 5:57 PM
    #108
    Florida AF
    Logan
    North Florida
    No not yet. Today was kid and wife day.
    The wiring diagrams I have are for the toggle not the OEM. So trying to figure out how to wire up the OEM. I'm skipping the vim switch and it's all wired and placed, just need to tie it in
  19. Jun 17, 2025 at 8:02 PM
    #109
    Tripleconpanna
    Kinda hard to tell what you've got going on w/the pics you posted. However, the red, white and blue bundle should go to your switch.... Usually red would go to the center pin of the switch, white would connect to the top pin (front camera) and blue to the bottom (rear camera)
  20. Jun 18, 2025 at 1:50 PM
    #110
    Florida AF
    Logan
    North Florida
    It's because I am using the OEM style switch with many oh colors. But I finally found the correct wire diagram and got it all figured out.... Sort of......
    It works and is buttoned back up, and now I have an airbag light I need to trace.
  21. Jun 20, 2025 at 5:15 PM
    #111
    Florida AF
    Logan
    North Florida
    Misc update. Driving the truck today. Airbag light is no longer illuminated and the wife did not even notice the ride difference in the suspension. I feel like it's more planted.
    Win and win!
