What is this part called ? Toyota Tundra 2019
Discussion in 'Suspension' started by Tundra1794X, May 7, 2025.
  1. May 7, 2025 at 12:24 PM
    Tundra1794X
    Tundra1794X [OP] New Member
    2019 White Tundra 1794 Edition
    Pro Comp 6” suspension Mx6 shocks , Amp research power step boards, Rigid Grille Kit, FUEL Wheels
    IMG_0578.jpg I got a Toyota Tundra 2019 1794 edition with a 6” lift . Anyone know what these are called as I was checking the suspension and noticed one was missing and looks like it snapped off.
  2. May 7, 2025 at 12:28 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Those are your front bumpstops. You can buy better aftermarket ones. A few to choose from. Sumo and Timbren to name a couple.
  3. May 7, 2025 at 12:31 PM
    TacomaTRD4x402
    Southern California
    Wheelers also sells them...
    Tundra1794X[OP] likes this.
  4. May 7, 2025 at 12:39 PM
    Tundra1794X
    I appreciate the quick response ! I’ll do some research on those . Are they fairly easy to replace ? Looks like it’s just a bolt holding on to them
  5. May 7, 2025 at 12:56 PM
    TacomaTRD4x402
    Southern California
    Haven't done em myself but I'm a certified YouTube mechanic :rofl:and can confirm it's just a simple bolt that screws them in. I've seen that only 1 of the bumpstops per side for the front need to be replaced so you may be better off just getting upgraded ones but if your on a tight budget, I'd look at the junkyards or OfferUp n Marketplace for Tundra parts outs.
    Here's a really good review/install video on the Wheeler's bumpstops.
    https://www.youtube.com/watch?v=rmIzAZebm04
