What have you done to your NOT 3rd Gen Tundra today?
Discussion in '3rd Gen Tundras (2022+)' started by GODZILLA, Jan 8, 2025.
Why don't you have a 3rd Gen Tundra?
  1. Too expensive
    45.3%
  2. Don't like the exterior
    21.1%
  3. Don't trust the little TTV6
    62.1%
  4. Needed more capability than it offers
    10.5%
  5. Had to have a V8
    15.8%
  6. Too many issues in the early years
    35.8%
  7. Needed something that wasn't a truck
    5.3%
  8. Didn't like the interior
    12.6%
Multiple votes are allowed.
  1. May 7, 2025 at 8:56 AM
    #241
    Fastest color too.
  2. May 7, 2025 at 9:46 AM
    #242
    Azblue
    The Dirty T ( ^_^)_且
    I think the auto correct on your phone is screwed up, it changed the word slowest to fastest.
  3. May 7, 2025 at 10:20 AM
    #243
    I think you drink too much at work.
    kirkb, Corndog123, NWPirate and 3 others like this.
  4. May 7, 2025 at 10:25 AM
    #244
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    White is the color for rental cars
  5. May 7, 2025 at 10:27 AM
    #245
    GODZILLA [OP] New Member
    18" TRD Off Road Wheels
    First choice was silver.
    Second was windchill pearl.
    Third was red.
    Fourth was white.
    Fifth was lunar rock.
    No others were acceptable.
    kirkb, Corndog123, NWPirate and 2 others like this.
  6. May 7, 2025 at 10:31 AM
    #246
    Azblue
    And cable companies, plumbers, construction, etc.
  7. May 7, 2025 at 10:32 AM
    #247
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Rental car
    Rental car
    Nice
    Rental car
    Nice
    j-utah, blenton, Corndog123 and 4 others like this.
  8. May 7, 2025 at 11:05 AM
    #248
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Red is the only one of those that's nice.
    Of course, if and when I replace my truck, my only criteria will be that the new one not be white and I'll probably have to give up on that to get the other features I want. This is the land of white trucks.
    Corndog123 and Azblue like this.
  9. May 7, 2025 at 1:07 PM
    #249
    NWPirate
    Zach
    WA
    My choice in colors is based on hiding scratches :laugh:
    White and silver ftw!
    Soupbean77, kirkb, Corndog123 and 2 others like this.
  10. May 8, 2025 at 4:03 AM
    #250
    Corndog123 likes this.
  11. May 9, 2025 at 1:43 AM
    #251
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Very exciting routine maintenance on the not a 3rd Gen Tundra last week.
    2nd oil change. First one at 1200 miles, this one at 4920 or so.
    Toyota can recommend 10K OCI’s all they like, I’m not interested in sub par maintenance. For a whopping $70/year extra I can do 2 oil changes instead of one (average about 10K miles per year).
    Soupbean77, ansel123, kirkb and 5 others like this.
  12. May 11, 2025 at 7:29 PM
    #252
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Installed the GM upfitter kit and then installed my DD SS6 fogs that I kept from the Tundra.
    I got the upfitter kit in November and finally got around to installing it. I needed a ladder to reach the firewall to run the wires. I had to lay on the engine. I had the fogs for over a year. They are hard to miss for the idiots are pulling out in front of you!
    Cpl_Punishment and GODZILLA[OP] like this.
  13. May 11, 2025 at 7:53 PM
    #253
    :worthless:
    Cpl_Punishment likes this.
  14. May 11, 2025 at 8:05 PM
    #254
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The better picture would have been me rolling around on the engine! I will snap some shots once I clean up the wires.
  15. May 14, 2025 at 10:30 AM
    #255
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    j-utah, kirkb, Cpl_Punishment and 3 others like this.
  16. May 14, 2025 at 10:33 AM
    #256
    Almost look factory with that placement. Very nice.
    Is the upfitter kit just switches inside?
  17. May 14, 2025 at 10:50 AM
    #257
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    GM Made a kit that includes a heavy wire that connects to one of the 2 batteries. It comes with a 60 amp and 200 amp fuse that sits on the battery. Then you get a fuse block with relays and then 5 push buttons that go in the kick panel. It comes with all the bits and pieces to install it. It is pretty well built but can be a pain to install.
    If you buy a HD GM you usually will find this kit in sitting in a bag on the back seat. GM doesn't want to install the kit for some reason. It is a bit of a chore to put in but if you want a control to run a winch or snow plow or something like that, this kit will work well to power it.
    You get 4 connections under the dash to connect things to and you get one more connection at the 3rd brake light to connect to. Like bed lights or big spots for camping!
    Our Truck was used and the salesman rounded up all the pieces for the kit. The row of 5 push buttons was already in the kick panel so that made the install easier.
  18. May 16, 2025 at 6:04 PM
    #258
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Got the Blackvue Dash Cam installed and used another one of those upfitter buttons. (I kept this when I traded the Tundra).
    The install was pretty easy. The hard part was finding the wire and plug since I left the original plug in the Tundra. Doh!
    Only 3 AUX buttons left! :)
    GODZILLA[OP] likes this.
  19. May 18, 2025 at 4:24 AM
    #259
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    2024 Silverado 1500 LZ0
    I like this little 3.0 Duramax, but your 3500 pictures make me miss owning an HD truck!
  20. May 18, 2025 at 9:56 AM
    #260
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Checked the oil in a 42-year-old six cylinder. Perfect as always. Sibling gets a new engine Tuesday.
  21. May 18, 2025 at 4:16 PM
    #261
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Got the Rock Tamers setup and ready for our trip out to the boonies (Saskatchewan) in a week or so. They have so many gravel highways!
    I wanted to use at least one of the Rock Tamers exhaust ports (made for smaller dual exhaust pipes) for the big fat exhaust pipe. They offer a heat shield as well but I figured I would use the port and make my own heat shield out of some left over stainless sheet.
    Turned out okay but these things are a chore to install.
    The position of the hole lines up pretty good but looks low in the pics but when the trailer is connected, the whole assembly levels out. The idea is that the exhaust would just deflect off the heat shield but it does come out the hole too.
  22. May 18, 2025 at 4:21 PM
    #262
    TRDGoodness
    TRDGoodness Not new, but not old either
    East Coast
    2020 Ram 2500 Tradesman 6.4L gas; ZF 8 spd Transmission
    Forgot to mention: Got my truck back from the rust. Taken care of under warranty, except for two spots that they said they would not cover which is not really rust, according to the body shop.
    So I am happy about that.
  23. May 20, 2025 at 6:10 AM
    #263
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    What sort of rust were you dealing with? Why did they leave two spots? Sounds like progress.
    TRDGoodness[QUOTED] likes this.
  24. May 20, 2025 at 6:25 AM
    #264
    TRDGoodness
    East Coast
    Thank you, yes, progress was made and I am so happy to have a fixed truck :). I have some pics somewhere on here showing the rust on the body, and if I can find it, I will link to it.
    The two spots that I have knowledge of is not considered "rust" by even the body shop they used. The first one is to bare metal and all I need is to put a sealer and then paint match it. The other is right above the window on the edge of the body but the body shop said that a clay bar should take that out as well.
    However the major rust spots and all 6 of the others were all done and it looks fantastic!
    I will try to grab some finished pics and post those. Life has me going crazy right now, LOL.
  25. May 21, 2025 at 9:04 AM
    #265
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Washed, clay bar, & ceramic coating on wife's Lexus. Oil change & tire rotation is next..20250521_120128.jpg
  26. May 21, 2025 at 9:05 AM
    #266
    TRDGoodness
    East Coast
    Is that a Challenger in your Avatar?
    Raven67[QUOTED] likes this.
  27. May 21, 2025 at 10:18 AM
    #267
    SoTexTundra
    SoTexTundra New Member
    19 DC TRD OFF-ROAD
    I have a 2.5 gen but i like this thread cause i can see what everyone else is getting for future vehicles. Who all has either a chevy/ford HD gasser? Are they worth it compared to the diesel with the emission nonsense?
  28. May 21, 2025 at 10:38 AM
    #268
    @ColoradoTJ do you have a list to help him out?
  29. May 21, 2025 at 10:49 AM
    #269
    Right now these are your options:
    Ford 6.8/7.3 with the 10 speed.
    GM 6.6L gas. Install new or updated valve body.
    Ram has MDS, so it wouldn't even be a consideration.
  30. May 21, 2025 at 11:00 AM
    #270
    Raven67
    Kentucky
    Yes it is. Hellcat Redeye.
