Wheel Flare Pads for Access Cab 1G - Part Numbers Help
Discussion in '1st Gen Tundras (2000-2006)' started by JustJake, Mar 19, 2021.
  1. Mar 19, 2021 at 8:15 AM
    JustJake
    JustJake [OP] New Member
    2006 AC
    Calling on the parts experts for this one. Hours of searching and I cannot turn up what I need.
    The Front and Rear fender flares on my 2005 Tundra Access Cab have a rubber adhesive strip between the body and the flare.
    For the life of me, I can not find the rear gray left and right wheel pads.
    What I have found so far:
    Double Cab Rear Left Gray: 61783-0C030-B0
    Access Cab Front Left Gray: 53851-0C030-B0
    Is there a Right and Left? Or are they interchangeable?
  2. Mar 19, 2021 at 8:24 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Looks side specific if these adapt to your flares. Safe bet is order one for each side. Here is what your first part number brought up. Didn’t do the other number, but my 2002 VIN was sending Red Alerts on my search so best to stick with DC Options. Suggest calling Stealer for more info.
    JustJake[OP] likes this.
  3. Mar 19, 2021 at 8:27 AM
    JustJake
    2006 AC
    How it usually goes. As soon as I post for help, I find the solution.
    This site has a diagram for a bunch of different wheel flare pads from 00 to 06 for AC and DC.
    https://parts.lakelandtoyota.com/p/...ENING-EXTENSION-NO1/3987725/617830C030C0.html
    Looks like 2005/2006 Access Cab Rear Gray is 617830C050B0
    Hopefully the next person who needs these will find this post.
  4. Nov 22, 2024 at 4:28 PM
    RacerX1962
    RacerX1962 New Member
    '02 Tundra Limited
    Lifted 1" , 3/4" wheel spacers
    Okay,
    I have been looking for gray flare pads forever also. The ones sited are black and I need Gray. How did your search/ install end up?
    What would be ideal is if there were appropriate aftermarket 3m welting in bulk, and cheaper in gray, if anyone has ever done that for Gen 1.
    I'm repainting/ restoring mine and in need all 4. Repainting to Nissan Platinum Graphite (K51) to try to keep the patina color pictured.
    First post- Thanks
  5. May 7, 2025 at 6:22 AM
    Bumping this old thread to put in part numbers. I know there's an aftermarket alternative someone found and I'll edit to add it when I find that again.
    But that rubber seal between the fender flare and body panel is front/rear specific but not side specific. It comes in two colors, grey and black. The last two digits of the part number dictate the color. Part numbers I pulled and confirmed for the 2005-2006 Access Cab:
    FRONT: 53851-0C030-XX
    REAR: 61783-0C050-XX
    Replace "XX" with your required color:
    C0 = black
    B0 = medium grey
    At the time of this post, the rubber gasket was still available for roughly $30 MSRP per piece (so ~$20 in reality if you start your order through the national parts site).
    The parts diagram shows separate LH/RH (driver/passenger) part designations as seen here (parts suffixed with G and D, left red box), but the part number is identical regardless which one you dig on in the EPC.
