Sensor recalibration after Gen3 TRD Pro Heritage grille conversion
Discussion in '3rd Gen Tundras (2022+)' started by paranoid_android, Apr 21, 2025.
  1. Apr 21, 2025 at 4:10 AM
    paranoid_android
    paranoid_android [OP] New Member
    NJ
    2025 Toyota Tundra Platinum
    Hi folks,
    Long time looker first time poster. Hoping to get some internet wisdom. I have a 2025 Platinum and am looking to do a TRD Pro Heritage grille conversion. So far, I have the following:
    - OEM TRD Pro Heritage Grille (PN: 53101-0C220)
    - OEM Marker Lights (PN: PT358-34220-AB)
    - Rave off Road 2022+ Tundra OEM TRD Pro Marker Lights Wire Harness
    - Westcott Designs 2022-’24 Toyota Tundra & Sequoia Front Camera Relocation Bracket
    (I am still debating between the Baja Designs S8 Light Bar Kit vs. Leaving this spot blank)
    I came to realize that I am not sure if all systems such as 360 camera, cruise control, pre-collision, etc. will work as expected after the conversion or is some sort of recalibration needed?
    Can those of you who have gone through the process share some insight here please?
  2. Apr 21, 2025 at 4:28 AM
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    After changing my 24 Platinum grill to the Heritage grill I didn’t experience any issues with my sensors. I wouldn’t worry about it.
    DocK, SrgJigPog, 23 Platinum and 3 others like this.
  3. Apr 21, 2025 at 7:43 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I changed my 24 limited to Pro grille, and leveled the front end & larger tires. Nothing needed as far as recalibration on mine, i also have 360 cameras & everything works as it should.
    Yaboy likes this.
  4. Apr 21, 2025 at 7:47 AM
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    If you get the diode dynamics light bar, you get a free camera relocation bracket. Just another option for you..
    I just did this conversion on my Platinum and there were no issues with the sensors, but my grille camera mysteriously failed 3 weeks later (replaced and recalibrated under warranty).
  5. Apr 27, 2025 at 7:25 PM
    estebanoss
    estebanoss New Member
    '23 Limited 4x4 TRD OR
    No issues with sensors so long as you remember to plug in everything when it's all done.
    You may just have to align the front camera on the new bracket.
    23 Platinum likes this.
  6. May 7, 2025 at 4:36 AM
    DocK
    DocK New Member
    Billy
    2025 SR5 Premium 4x4
    There will be plenty!
    Looks great! How hard was it to install (looks simple) and how did you hook up the light bar?
  7. May 7, 2025 at 6:02 AM
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Not hard at all. I did it by myself so just took my time. Light bar was the easiest since I connected it to a Garmin.
  8. Jun 22, 2025 at 6:32 PM
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    This is actually a really useful detail to know, thank you. I was mid-shopping for a camera relocation bracket.
    RDW[QUOTED] likes this.
  9. Jun 26, 2025 at 5:29 AM
    RDW
    RDW New Member
    Rob
    NJ
    Glad I could help. Saves you about $20
