12 volt battery charging system malfunction
Discussion in '3rd Gen Tundras (2022+)' started by JK3, May 3, 2025.
  1. May 3, 2025 at 11:29 AM
    JK3
    JK3 [OP] New Member
    2022 Limited TRD OffRoad
    Had anyone ever had the 12 V battery charging system malfunction come up on your tundra? I have a 2022 limited off-road package. Bought it used with 28,000 miles. Drove it from IL to NC 750 miles not a single hiccup. A week ago I got the message and some flashing lights on my dash. Got a “new” lifetime battery replacement. Still showing up. Had a light bar installed by the previous owner the second Toyota dealership I was at told me that this was the issue, disconnected it and said the truck was fine. Truck started up but showed 9 V on the voltage meter then my power steering went out. They say it’s not the alternator but I saw a previous post that said the dealerships the other poster went to said that the truck was fine just like mine. The second dealership said that the battery that was replaced was an older stock battery from 2023 so that also could be the issue but my gut is telling me alternator. Any info or help would be great thanks.
  2. May 3, 2025 at 3:13 PM
    JayDee
    JayDee New Member
    Check that your battery cables are securely attached on both ends. The taps used for light bar may have messed up the main connections.
    JK3[OP] likes this.
  3. May 3, 2025 at 3:37 PM
    vtown76
    vtown76 New Member
    No way to diagnose remotely, but I can’t see how it would be the battery if it will start the truck. Put an actual volt meter on it. The dash thing is probably more of an idiot light.
    When the truck is off you should show ~12.3 or more if the battery is good (unless you’ve already depleted it if the alternator is bad) . When it’s running, it should show slightly higher indicating the alternator is charging the battery.
    raylo and JK3[OP] like this.
  4. May 3, 2025 at 4:03 PM
    JK3
    JK3 [OP] New Member
    Forgot to add after turning the truck off it wouldn’t start back up fast clicking ticking but would not start. But accessories worked truck just wouldn’t turn over.
  5. May 3, 2025 at 4:13 PM
    vtown76
    vtown76 New Member
    Well if the alternator isn’t charging, it would have been running off the battery, depleting it.
    Do you have a charger? You could charge the battery and see if it will hold the charge.
    Or jump it to start. If it won’t stay running it’s the alternator. If it will stay running, it’s not.
  6. May 3, 2025 at 4:14 PM
    JK3
    JK3 [OP] New Member
    I jumped it to start and it would*** stay on until I killed it. Then when trying to start it again I would need to jump it off.
  7. May 3, 2025 at 5:25 PM
    DRP
    DRP Old Member
    Dave
    Check the battery connections as @JayDee pointed out. Might be a good enough connection for accessories but not starting.
    JK3[QUOTED][OP] likes this.
  8. May 3, 2025 at 7:07 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Being that your volt guage is showing 9v while engine is running indicates that its not charging. At least swing by auto zone or somewhere that can check the charging system (for free). Its quite possible the alternator is gone,,and possibly from whatever lights were installed.
  9. May 5, 2025 at 1:38 PM
    JK3
    JK3 [OP] New Member
    Just got it back after the third battery replacement and it’s still showing up everything that I posted here the other day. Dealership says it’s not the alternator. I’m taking it back right now and telling them to change it regardless.
  10. May 5, 2025 at 1:51 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    This won't fix your problem, but for $30 it tests voltage, cranking, and charging..
    Amazon.com: KONNWEI KW208 12V Car Battery Tester, 100-2000 CCA Load Tester Automotive Alternator Tester Digital Auto Battery Analyzer Charging Cranking System Tester for Truck Marine Motorcycle SUV Boat : Automotive
    I'd run it a few times and see if it gets consistent results..
    Good luck.
  11. May 6, 2025 at 10:52 AM
    JK3
    JK3 [OP] New Member
    Well, I picked up the truck today and it’s fixed! Previous owner had some maintenance done somewhere in the engine bay requiring the removal of the alternator. Come to find out the bolts securing the alternator were loose! I’ve been driving since 11 AM this morning and battery gauge has stayed in the middle (i’m guessing) at 14 V. So looks like me pressuring them about it being somewhere in the alternator helped. Thanks all for your replies.
  12. May 6, 2025 at 10:55 AM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Glad you got it fixed but sorry you had to pressure the dealership to do the right and most logical thing.
    vtown76 and NewImprovedRon like this.
  13. May 6, 2025 at 11:53 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    I have my ScanGauge showing volts and when charging it is usually 14.1-14.5V. But these trucks relax the charging when the battery is topped up so it can read normal ~12.x volts even when running. Which may make it a little harder to diagnose an alternator. Techstream and maybe other scanners can show if the system is calling for charge or not.
