  1. May 6, 2025 at 7:31 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    For sure. RA.
    KNABORES[QUOTED] likes this.
  2. May 6, 2025 at 7:39 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Speaking of plugs, it's a little spooky torquing to the specified 156 in-lbs (13 ft-lbs). I always follow torque specs, but these made me glad I have a good spark plug socket and digital torque wrench. The torque wrench was kind of expensive, and I haven't been able to justify it until this job. But worth every penny.
  3. May 6, 2025 at 7:41 AM
    FTFY.
    We were so close to cracking down on counterfeiting in 2022-2023. INFORM, SHOP SAFE, etc. all being put out there. Still pisses me off this is such a substantial problem.
    I go by hand-feel. I'd never trust my torque wrench to get it right. The cost of munging/mangling your threads isn't worth it.
    bfunke and 455h0le_dachshund like this.
  4. May 6, 2025 at 7:52 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Found it…. Thx!!!
  5. May 6, 2025 at 7:56 AM
    oscardog86
    oscardog86 New Member
    Southern California
    I just ordered new plugs from the dealer. Itll be my first spark plug change that ive done since owning the truck. I had it done when i first bought the truck about 40k miles ago.
    Bought them to have on hand when I do try to change them, but i believe its recommended every 30k approximately?
  6. May 6, 2025 at 7:57 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Actually every 60K.
    oscardog86[QUOTED] likes this.
  7. May 6, 2025 at 8:00 AM
    oscardog86
    Southern California
    Well i guess i have some time until I have to try doing spark plugs. Ive never done them and always hear how sketchy it could be if you mess something up. A recent video I watched said to go hand tight and then a 1/4 turn to get it snug. Or 13 ft/lbs but I dont know If id trust my torque wrench to click in time before I over tighten!
  8. May 6, 2025 at 8:05 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    It's very easy. I wouldn't attempt to torque with a clicker type wrench because you're correct, sometimes you can't feel it "click" at low torque. I have a digital that is audible and vibrates.
  9. May 6, 2025 at 8:08 AM
    Change interval depends on the plugs used. Coppers would be 25-30k mile intervals. Iridium and Platinum would be 60-100k
  10. May 6, 2025 at 8:10 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Just call me “Baby Billy” as in Billy 5100/OME 2883. Installed, aligned…. And test driven. First off…. I love it! At first I didn’t think the ride quality had improved that much, but the more I drove it …. I realized how much nicer it was in areas that I had driven previous. I’d say ride quality improved 40% give or take…. Which is better than what I was expecting actually. Handled great on the highway…. Buttery smooth which it wasn’t bad on the highway to begin with. All and all…. Very happy! Thx guys for all your input …. Here are some pics. (BTW…. I took some rough measurements and came up with like a .5 inch squat. That may settle after a while, if not, it still looks good to me.
    My LCA bushing on the passenger side is shot but for now I don’t think spending another thousand (did I spell that right??) is on my horizon…..lolIMG_2169.jpg IMG_2170.jpg IMG_2171.jpg IMG_2172.jpg
  11. May 6, 2025 at 8:12 AM
    oscardog86
    Southern California
    Not sure what was installed in mine when I had the plugs done, so guess I might be giving that a go soon with the new Denso plugs I just bought
  12. May 6, 2025 at 8:16 AM
    If you're not planning to replace your sway bar end links with extended ones, I modded my stock by adding some washers under the bushing stack (arrow and lines) to correct the angle from lifting. You can see how many threads you have available at the top here (circle).
  13. May 6, 2025 at 8:27 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    When I rebuilt my rockers I put some commercial 3M step grip on there. One thing I've noticed (that mine does not have) while shopping these trucks and looking at other people's pictures is the brutal dents in a LOT of the inner rockers from the seatbelt buckle being SLAMMED in there because it didn't retract :rofl:
  14. May 6, 2025 at 8:42 AM
    Hey! I resemble that remark
    BroHon[QUOTED] likes this.
  15. May 6, 2025 at 10:00 AM
    Damn! Beat me to it :rofl:
    Two things:
    1. Looks like the 2883 did you right, I presume they're gonna settle a little bit more and should have you just shy of level. It looks a little high up front to me in your last pic, but it may be optical illusion. Great stance. Would look killer with some similarly meaty A/T in 265/70r17 tires to give you an extra inch of diameter, but those KO2 you have there look damn near brand new.
    2. The lower bushing on the swaybar link I just quoted from KNABORES looks overcompressed. I feel like you may want/need to back off 2 full threads on that top nut. But it may be because it's also not sitting in the pocket of the cup washer under it properly. Either way, you need to loosen that top nut, center the bushing in the cup washer, then tighten it down to where it's barely engaging, which will probably be right about 2-4 threads exposed up top.
    MooreKen likes this.
  16. May 6, 2025 at 10:44 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Was gonna back them off but those bushings are shot, that’s probably why they look so over compressed. Driver side has some give to it but the passenger side is toast. Is there a particular brand of bushing or for that matter any advice on extended sway bar links? They don’t appear to be too expensive. UPDATE: Ordered Suspension Maxx
    G_unit3000 and oscardog86 like this.
  17. May 6, 2025 at 10:48 AM
    OEM rubber is better than most aftermarket replacements. Suspension Maxx makes regular and extended length sway bar end links for these trucks. I’m running a set of them now after swapping my homemade “extended” ones out.
    OEM+
    Suspension Maxx
  18. May 6, 2025 at 10:57 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Just ordered the Suspension max from Josh….too funny.
  19. May 6, 2025 at 11:22 AM
    Dakillacore
    Georgia
    Poor guy is trying to come undressed
  20. May 6, 2025 at 11:36 AM
    Old pic. Was part of my front end rebuild recently. Lots of sadness in those old pics.
  21. May 6, 2025 at 1:57 PM
    oscardog86
    Southern California
    A little late sharing my recent Utah trip then Tundras 2 Sedona on the way home.
    1000003514.jpg 1000003533.jpg 1000003603.jpg 1000003648.jpg 1000003694.jpg 1000003687.jpg 1000003549.jpg
    Voss, Dblock500, RealTruck and 20 others like this.
  22. May 6, 2025 at 1:59 PM
    We just missed each other. Beautiful pics
  23. May 6, 2025 at 2:00 PM
    oscardog86
    Southern California
    Thats too bad, i think i remember you mentioning youd be doing a similar route. But backwards i think? Such a beautiful place, ill definitely be back next year
  24. May 6, 2025 at 2:03 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    Whewwww look at those views, nice pics :thumbsup:. Jealous of that first photo's camping spot, gonna have to find that next time I'm in moab!
    Also what's the antenna on the camper for, ham radio?
  25. May 6, 2025 at 2:04 PM
    Monday arriving to Grand Canyon Junction, Tuesday we hiked the Canyon down to Phantom Ranch and back up, Wednesday Zion, Thursday Antelope Canyon, Lees Ferry and Lake Powell, Friday Brice Canyon, Saturday travel home.
  26. May 6, 2025 at 2:06 PM
    oscardog86
    Southern California
    @Nicklovin Thanks man, yea the views were incredible. That first spot I found last year and made a point to go there again this year. Its one of my favorite trails so far that ive done, especially because of the view at the end. And best part, had the place all to myself both times ive camped there!
    The antenna is a WeBoost Amazon knockoff to help increase my cell data. It actually works pretty good and gets me service in many places.
  27. May 6, 2025 at 2:08 PM
    oscardog86
    Southern California
    That sounds like a great trip too! I wanna do more hiking in some of the places you went, but my dog is over 16 years old. So we just SLOWLY explore around the camping areas these days, haha.
    FirstGenVol, shifty` and FrenchToasty like this.
  28. May 6, 2025 at 3:23 PM
    We hiked about 60 miles over the 4 days. It was a blast, but the legs were screaming after day 1 with 20 miles up and down the canyon
  29. May 6, 2025 at 5:27 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Nothing wrong with getting the extended links, but I doubt you need them. The 2883 is such a small lift. I went with regular length end links and I have no issues, even driving some very rough dirt roads.
  30. May 6, 2025 at 6:35 PM
    Nicklovin
    Nicklovin Yap Yap
    00’ 4.7 AC 4x4
    Darn that sounds like a fun trip too, gf is begging me to take her back to utah. Might go next month
    Niceeee, what trail was it? I was thinking maybe it was the one that zig zags down from one of the parks and follows along the river. Sheep something?
