Exploded rear driver window
Discussion in '2.5 Gen Tundras (2014-2021)' started by yakeng, May 5, 2025.
  1. May 5, 2025 at 4:58 PM
    yakeng
    yakeng [OP] 3URFE Apologist
    My driver side rear window exploded on the way home. Anyone have this happen? Think about replacing it myself, curious on if anyone has done this before. Stealership has one in stock.
  2. May 5, 2025 at 5:04 PM
    AZTundra
    Paul
    Phoenix, AZ
    I’ve replaced three windows on a Corolla before which wasn’t too bad at all. I can’t imagine the Tundra would be any harder aside from the larger glass to deal with. Go for it!
    OldGuy03 and yakeng[OP] like this.
  3. May 5, 2025 at 7:28 PM
    yakeng
    Just finished vacuuming the glass, what a pain.
  4. May 5, 2025 at 7:44 PM
    biebs96
    PA
    Go for the DIY. If available I would do it.
    OldGuy03 likes this.
  5. May 5, 2025 at 7:55 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    How does a window just explode? Sure u didn’t catch a bullet
  6. May 6, 2025 at 4:15 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    3 windows? Ex-gf drama?
  7. May 6, 2025 at 4:22 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    There will be glass inside the door shell as well, if you haven't cleaned in there already. Peel back the moisture barrier and vacuum in there or you'll have a glass rattle.
  8. May 6, 2025 at 7:38 AM
    yakeng
    If you look at the bottom of the vapor barrier, you can see the butyl caulk all stringy, already pulled it back and vacuumed all the glass. It took me about an hour and a half to vacuum it all back, with the help of a trim tool and pic getting all the glass out of the crevis.
  9. May 6, 2025 at 8:13 AM
    AZTundra
    Paul
    Phoenix, AZ
    Haha,nope. My son’s older Corolla at the time had the glass mount (plastic piece glued to the bottom of the glass) snap on one of the windows. I pulled a new window from a junkyard and installed it as a replacement. The other two windows had the tint bubbling up and it was cheaper to swap the glass from the junkyard with perfect tint than to re-tint the windows he had. If I recall correctly they charged me $30 per window at the junkyard and all had perfect tint as well. A couple hours to swap all three at home and good as new.
    OldGuy03 and Shanet421[QUOTED] like this.
  10. May 6, 2025 at 1:56 PM
    yakeng
    So I just replaced the window and this job isn't exactly easy. I could not rotate the window in, so I ended up having to remove all of the window seal/trim and disconnect the guide inside the door (remove the two 10MM bolts by the back of the truck). I ended up disconnecting the guide facing the front (also used 10MM bolts), but I don't think that one is as necessary. Removing the trim allows just enough clearance to rotate the window with the corner facing the back of the door. You then have to clear the door handle/lock and once you do, then you are able to rotate it clockwise and get it fully into the door.
    Removing the trim (fully) will allow you room to push the window further towards the driver seat and just enough clearance to rotate the window:
    When you do this, I strongly recommend buying a replacement bottom trim. Mine broke when pulling it off.
    Also, if your window is broken, I found that there was a ton of glass stuck in the trim channels. Removing the trim and guides allowed me to clean all the glass out.
  11. May 6, 2025 at 2:09 PM
    Dakillacore
    Georgia
    Yeah, we typically replace the run channel, glass, and belt molding on window jobs as the bare minimum. The bottom trim (belt molding) is one-time-use per Toyota anyway.
    AZTundra and yakeng[QUOTED][OP] like this.
  12. May 6, 2025 at 2:31 PM
    yakeng
    You have the patience of a saint if you do this for a living.
    panicman likes this.
  13. May 6, 2025 at 2:48 PM
    Dakillacore
    Georgia
    Ha, nah I don't do the work on the daily. I'm a collision estimator so I write more than I do. But I did have to replace the window regulator on my grandmas Hyundai Tuscon recently and it was a bitch of a job. Their regulator is built into a thick plastic vapor barrier, so you have to replace the entire unit. They also make it damned near impossible to get a hand behind the unit to be able to reattach the window to the regulator.
    I had to close my eyes and feel for the bolt holes on the glass.
    panicman and bulldog93 like this.
  14. Aug 17, 2025 at 7:16 AM
    DoggerDave
    DoggerDave New Member
    Dave
    2025 TRD OFF ROAD
    Not sure if this is a common thing or it but my 2025 Crew Max rear drivers side window “spontaneously” exploded yesterday. My truck is a lease and we have damage protection but I’m hoping (probably wishful thinking) that the dealer will warranty it as a defective window. Either way, I guess I won’t have to pay for it.
  15. Aug 18, 2025 at 5:41 AM
    DoggerDave
    Dave
    2025 TRD OFF ROAD
    So I called my dealer today and it sounds like the window will be covered under the manufacturer warranty. I wonder if this is a common thing. When I called, they could have a window for tomorrow. Not common for my area to get any part for tomorrow!
  16. Aug 18, 2025 at 12:29 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Okay thats just weird!!!
    I've been driving Toyotas for decades as has my Wife and I've never heard of this happening!!
    Nor have I heard of a recall.
    Curious to see what the outcome is.
    Defective glass maybe?
  17. Aug 18, 2025 at 1:57 PM
    2mchfun
    Stones flying from tires. Many more heavy lug A/T tires on the roads nowadays. They hold rocks until centrifugal forces release them with lots of energy.
    yakeng[OP] likes this.
