  1. May 3, 2025 at 5:27 PM
    #9841
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Oh wow ok. What’s the ideal range? I am about to go through 120 degree summers here in Las Vegas. I guess I should watch my JB4 app more often.
  2. May 3, 2025 at 5:33 PM
    #9842
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    It'll stay in that range as mine. I see 110 or so where I'm at in SoCal and visit family in Yuma and Imperial, CA where they see 120 as well. It'll get in the 220s and stay there even when empty. I'm shooting for 180-190 readings.
  3. May 3, 2025 at 5:39 PM
    #9843
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Is that the screen from the JB4 app? Thats pretty cool.
    BlackNBlu likes this.
  4. May 3, 2025 at 5:40 PM
    #9844
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    I just looked at my door jamb and it says L4A0F. The operating range is 175-225 degrees. After that, components may degrade. I’m definitely curious now. Did you guys figure out plumbing on your own or are there kits with the right length of hoses already? Do they have -AN fittings?
    I DIY’d my oil cooler on my GT-R and hope the plumbing is similar to it. Basically put it inline the system right? Making PTFE -AN oil cooler lines was fun.
  5. May 3, 2025 at 5:41 PM
    #9845
    SilveradoSwap
    Not to hijack, what year GT-R u have?
  6. May 3, 2025 at 5:44 PM
    #9846
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    1995 R33 GT-R VSPEC
    I am checking out the 2022 Supplemental Trans Cooler thread now. I would def like to get one installed before the summer hits.
  7. May 3, 2025 at 5:59 PM
    #9847
    eddiefromcali
    Eddie
    100% Stock
    It is
    Pretty much plumb it in line on the return line back to the trans
    Derfla[QUOTED] likes this.
  8. May 3, 2025 at 6:01 PM
    #9848
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Did you do -AN hose fittings?
  9. May 3, 2025 at 6:02 PM
    #9849
    eddiefromcali
    Eddie
    100% Stock
    Nope...saw no need/advantage on such a short run and low psi line.
  10. May 3, 2025 at 6:02 PM
    #9850
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Appreciate the info!
    eddiefromcali[QUOTED] likes this.
  11. May 3, 2025 at 6:25 PM
    #9851
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    Mines got the billstein 4100 or whatever they are
  12. May 4, 2025 at 11:43 AM
    #9852
    Daedalus
    Daedalus New Member
    Yup.
    Although I’m going to bypass for now the radiator cooler. This will be the single one only. I have a thermostatic bypass that’s going inline as well.
    if I need to upgrade to a larger size I now have the provisions for it.
  13. May 4, 2025 at 1:19 PM
    #9853
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Got a stall mat for my bed and test fitted my $70 bed tent!
    Mr Rick and eddiefromcali like this.
  14. May 4, 2025 at 1:32 PM
    #9854
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Do you have a write up on this?
  15. May 4, 2025 at 2:50 PM
    #9855
    eddiefromcali
    Eddie
    100% Stock
    Hope it works for you. Seeing 208° with rain and 55° ambient temp is not for me. Picked up some trans fluid hose I liked better than what I got before. 400psi Gates hose has thicker wall that was appealing. Will slap it on as soon as it stops raining.
    VCheng likes this.
  16. May 4, 2025 at 3:45 PM
    #9856
    Foolishfrog
    Foolishfrog New Member
    Mitch
    2024 6.5 Pearl Platinum for towing camper
    This is certainly not the most exciting mod on this thread but it sure made things easier for me. I had to lower the spare on my Platinum and getting the hook lined up with the shaft to make that work required way too much time and ay too many swear words. So I made this mod.
    I will admit freely that I stole this idea from the Tacoma forum and used it on my Tacoma before I upgraded to my Tundra. ( and my brother in law, a Chevy guy, says that they have a tube built in to their truck) but I made a modification that makes it really easy to raise and lower the spare.
    I took an 14 inch section of a 2 inch PVC pipe (my Home Depot sells them in two foot sections), cut a notch on one end that is one inch long and 1/2 inch deep, and rounded off the corners of the notch so it fits over the shaft where the hook is supposed to fit in and rests easily in the curve of the bracket that supports the shaft.. I secured it to the crossmember with two zip ties and drilled a couple small holes in the rail that supports the shaft and used a small zip tie to keep the tube aligned with the shaft. The hook slides in the “bumper” slot and is directed into the slot. It might align better if a made a little notch where the tube rests on the crossmember, but I’m thinking I’m not going to need it often enough to make it worthwhile to take it apart to make that change.
    Volator, Yaboy, BlackNBlu and 4 others like this.
  17. May 4, 2025 at 5:42 PM
    #9857
    Daedalus
    Daedalus New Member
    Nothing in particular.
    Aluminum angle and some flat bar aluminum.
    Literally eyeballed the positions.
    The nice thing is the two center most supports for the bumper that connect to the core support are perfectly positioned to hold this thing.
    PapaDave418[QUOTED] likes this.
  18. May 4, 2025 at 5:44 PM
    #9858
    Daedalus
    Daedalus New Member
    same size cooler or different?
    What was the BTU rejection for yours.
  19. May 4, 2025 at 5:58 PM
    #9859
    Daedalus
    Daedalus New Member
  20. May 4, 2025 at 6:19 PM
    #9860
    Daedalus
    Daedalus New Member
  21. May 4, 2025 at 6:20 PM
    #9861
    eddiefromcali
    Eddie
    100% Stock
    I havent plumbed my cooler yet, but I went with a Trucool 40k. I have it ready to go, was just waiting on the cooler hose. Got some today but its been raining all day.
    Mr Rick and Daedalus[QUOTED] like this.
  22. May 4, 2025 at 6:35 PM
    #9862
    eddiefromcali
    Eddie
    100% Stock
  23. May 4, 2025 at 9:10 PM
    #9863
    Retroboy1989
    Northern Utah
    Yeah, I ordered the Derale 13016 hose which had thicker walls like the OE lines. Stupid expensive per foot, but I only used a few inches to transition from the braided AN lines and magnafine filter to the OE hard lines.
  24. May 5, 2025 at 5:55 AM
    #9864
    tundramh
    tundramh New Member
    OHIO
    I hate I am going to die without some kind of passion like you all have for these trucks and hobbies. I've always been do it a few times and I'm over it. I totally admire everything being done with the trucks in this forum. Well done if you haven't been told on any of your mods. Now back to your regularly scheduled program.
  25. May 5, 2025 at 12:03 PM
    #9865
    CappyKD
    CappyKD New Member
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I ran a pair of these in the engine compartment of my Gen 2.5 and once I did, I stopped seeing droppings on top of the engine cover. I run them in the engine compartment of my 2021 Outback XT as well and see no droppings. For the new 3rd gen, I will run a pair in the engine bay and a pair in the cabin on the Gen 3. HTH
    ziznack[QUOTED] likes this.
  26. May 5, 2025 at 4:11 PM
    #9866
    RabidAxolotl
    RabidAxolotl New Member
    25 Lunar Rock Limited
    Method 316 Gloss Titanium with Wildpeak AT4W 275/70r18
    TRD Pro Grille swap with lightbars and new fogs this weekend hopefully.
    sandiegosteve and SilveradoSwap like this.
  27. May 5, 2025 at 9:59 PM
    #9867
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
  28. May 6, 2025 at 5:23 AM
    #9868
    SilveradoSwap
    Nailed the look, loving that color.
  29. May 6, 2025 at 5:43 AM
    #9869
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    I went back a little ways here....
    The factory mats are ridiculously undersized, especially if you have a winter season and the slop that goes with it.
    I just have the "Tundra" rubber all-weather mats so far and they look to be the same size as your original 1794 mats, that is, really small.
    I am torn between the Husky's and TuxMats, which look like they provide even more coverage than the Husky's.
    I'm also a cheap ass, and have a hard time justifying the TuxMat's price.
    Decisions, decisions.
    Derfla and DubfromGA[QUOTED] like this.
  30. May 6, 2025 at 5:44 AM
    #9870
    BlackNBlu
    Rich
    MN
    Looks good. :thumbsup:
    Etsy?
    Link?
    (Assuming they would do "Off Road" in red.)
    Derfla[QUOTED] and SoCal_Erik like this.
