3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Mar 25, 2025 at 8:22 AM
    #2701
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    I don’t, normally if you feel the headrest, the back is often softer and the front is. It’s because the front is designed to deal with hair and the increased level of oil, the rear is not and will wear out quicker. Additional the front is designed at an angle so if your in a crash it minimizes neck injury. So while on my Subaru (they were the worst at this) the head rest was far more comfortable turned around, it would wear out quicker and be worse in a crash.
  2. Mar 25, 2025 at 8:50 AM
    #2702
    Kerplunk
    Kerplunk New Member
    I use it when I need to take a nap. Turn on cruise control and LKA, and I am good to go.
    CAPT_Squatchy86 and 75tranzam like this.
  3. Apr 22, 2025 at 9:51 AM
    #2703
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    :monocle::D:D:D
  4. May 5, 2025 at 4:28 PM
    #2704
    RabidAxolotl
    RabidAxolotl New Member
    25 Lunar Rock Limited
    Anyone with experience with Ark Splash Guards?
    Raven67 likes this.
  5. May 5, 2025 at 6:01 PM
    #2705
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Yes! I put them on the front of mine. Excellent coverage & easy install.20250328_124811.jpg 20250328_125141.jpg 20250328_125705.jpg
  6. Jun 12, 2025 at 10:56 AM
    #2706
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    Is it me or do I find all of @JohnF4x4 post a must look at! (and read too) :bananadance:
    az 3rdGen likes this.
  7. Jun 15, 2025 at 7:28 PM
    #2707
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    My current fog light shroud is shiny black, can a competent body shop still apply a durable layer of paint?
    If yes I was thinking about removing it from behind while my bumper is off, then when it's painted/ready I assume I can just snap it back in with the bumper already back on the truck?
  8. Jun 15, 2025 at 9:53 PM
    #2708
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    Do I need to worry about Weathertech in-channel rain visors scratching tint?
    There is a five year old thread on here that says AVS have inconsistent quality and I don't really want stick-on ones.
  9. Jun 15, 2025 at 10:59 PM
    #2709
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    What's the part number for this steering wheel?
  10. Jun 16, 2025 at 3:45 AM
    #2710
    sudobash
    sudobash New Member
    45100-0C500-C2
    Wraith[QUOTED] and oddhours like this.
  11. Jun 16, 2025 at 7:49 AM
    #2711
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    Thank you!
    sudobash[QUOTED] likes this.
  12. Jun 17, 2025 at 7:19 PM
    #2712
    VW-WOB
    VW-WOB New Member
    2024 Tundra SR5
    Just finished up my Auxbeam/oepanel wiring and install for some ditch lights.
    datacomguy and MAC25Tundra like this.
  13. Jun 17, 2025 at 7:25 PM
    #2713
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    I had them on two of my previous Tundra's with tint and never had any problems.
    Wraith[QUOTED] likes this.
  14. Jun 17, 2025 at 8:01 PM
    #2714
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    Perfect, thanks that's what I needed to hear. I'm now off to order...
  15. Jun 18, 2025 at 7:59 AM
    #2715
    jtweezy
    jtweezy New Member
    Jeffrey
    The in-channel visors won't mess with your window tint, unless your tint was installed wrong (i.e. on the outside of the window, not the inside). The outside of the window contacts the inside of the visor, so the inside of the window doesn't touch it at all. It also doesn't push the glass enough to make the inside of the window contact the frame/door enough to cause issues. Source: I had the WeatherTech in-channels on my Tacoma.
    vtown76 and Wraith[QUOTED] like this.
