GM V8 Recall. 0W-20 to 0W-40
Discussion in 'General Automotive' started by RookieEP, May 5, 2025.
  1. May 5, 2025 at 1:13 PM
    RookieEP
    RookieEP [OP] New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    Anyone check to see that GM is recalling the vast majority of their V8 engines. One of the interventions is to change the oil weight from 0W 20 to 0W 40. Curious, what people think and if people think Toyota will do the same regarding engine oil viscosity.
  2. May 5, 2025 at 1:27 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    One of the main reasons you would hear people say don’t use 30 or 40 weight was the oiling system was not designed for that weight. Now that GM is recommending going from 20 to 40 it seems to indicate that engine wear is more important/effective with a system designed for 20 weight. It could also be that GM is knee jerk reacting and putting a bandaid on an engine block hole.
    Using 20 weight is most likely for fuel efficiency , possibly emissions and the unknown of “lubricates better” since it can get into smaller areas in the engine design.
    20 weight seems slightly more expensive in my experience. Overall I have switched to doing 5k oil changes using 5-30 on all my Toyotas. Assuming 30 weight doesn’t causes additional wear the slightly improved mpg seems trivial to the likely improvements in engine life. I think million mile Tundra guy did 10ks at the dealership with 20 weight though, so maybe doesn’t matter and GM makes a shitty engine with piston deactivation.
    NWPirate likes this.
  3. May 5, 2025 at 3:05 PM
    sudobash
    sudobash New Member
  4. May 5, 2025 at 3:07 PM
    sudobash
    sudobash New Member
    0W-20, 5W-20, 5W-30, and 10W-30 are already spec'ed for the V35A.
    Daedalus likes this.
  5. May 5, 2025 at 3:28 PM
    EmergencyMaximum
    Probably a knee-jerk. Doubtful magical oil formula is going to save a failing design.
    Cpl_Punishment likes this.
  6. May 5, 2025 at 3:31 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    The thinner oils are all to meet EPA standards for fuel economy. The Motor Oil Geek just posted a great video on all of this. All the myths of we need to run exactly what the manufacturer says is busted. My two cents... I was only offered a penny for my thoughts and today, y'all got a DEAL ! LoL
    BoyHowdy, Eaganite, sudobash and 2 others like this.
  7. May 5, 2025 at 3:47 PM
    2mchfun
  8. May 5, 2025 at 3:52 PM
    EmergencyMaximum
    Advice worth the price charged?:spending:
    C'mon, if thinner oils were bad, we'd see engines blowing left and right. I know 3rd gens are doing exactly that, but that's just garbage motor, we all know that.
    Cpl_Punishment and sudobash like this.
  9. May 7, 2025 at 10:14 AM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    It’s not just any 0W-40. It’s DexosR supercar oil. We should all switch to this oil for its better protection in all vehicles.
    GM is in no way trying to get these engines past the warranty period.
    You see they just screwed up and specced the wrong oil. It should have been this super car oil all along.
    2025 6.2’s are still calling for 0W-20. This is a mistake and will be corrected by a future recall. There will also be one more recall for all GM engines 2020 and earlier to switch to this DexosR 40w oil. There is no problem with any of these engines in design or parts quality, it’s just a mistake on the oil spec causing these engine failures.
  10. May 7, 2025 at 11:07 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    At least they're not trying to "fix" it with a software update...
  11. May 7, 2025 at 11:09 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    2WD[QUOTED], NWPirate and sudobash like this.
  12. May 7, 2025 at 11:17 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    GM is just recalling the 6.2 V8 from its half-ton truck and SUV platforms for four model years. The 5.3 V8 for those same vehicles and the 6.6 gas and 6.6 diesel V8s in the HD trucks are not affected. Not sure that's a vast majority, but it's significant.
  13. May 7, 2025 at 12:36 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Motor Oil Geek did a good video on this recently. It's possible to push the boundaries of engineering with resulting failures with lower safety factors. Oil technology has come a long way in the past 20 years. While 0w20 is probably fine in most cases, we may be seeing limits pushed too far.
  14. May 7, 2025 at 1:03 PM
    EmergencyMaximum
    They make 0w16 now. The world will surely be ending when touota starts recommending that oil in new tundras.
  15. May 7, 2025 at 1:16 PM
    mrlittlejohn
    Michael
    I do believe there is a 0w08 here in the states with a 0w04 in Japan.
  16. May 7, 2025 at 1:19 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Air bearings are next
