2014 Tundra Platinum Steering Wheel Shake Violently When Braking at 70 MPH
Discussion in '2.5 Gen Tundras (2014-2021)' started by JayKay, Apr 11, 2025.
  1. Apr 11, 2025 at 11:54 AM
    JayKay
    JayKay [OP] New Member
    I'll try to make this as short as possible. Had a 2014 Tundra Platinum that I use for work. I put a 10 inch lift and 37 inch tires. Don't ever lift your truck, it runs like GARBAGE!!! Steering wheel shake during braking so I had them install new Toyota front rotors with the USED brake pads while the lift was being installed. Ran it for like 30K miles with ZERO issues and then got tired of pumping gas EVERY OTHER DAY with the poor performance in acceleration and horrible braking distance from the lift. So I got rid of it and bought another 2014 Tundra Platinum with steering wheel shaking violently when braking. Installed new Toyota rotors with the USED brake pads. A lot of people are saying new rotors and brake pads are required but I've never had an issue using used brake pads with new rotors. Anyways, it ran smoothly until about 7K miles in and the steering wheel shakes when braking at 65+ MPH. A few folks mentioned using drilled rotors so I bought some drilled rotors with new brake pads from the drilled rotor company. It wasn't expensive, like $200 for the rotors and pads set. It ran very smooth until about 7K miles again and the steering wheel shakes violently more and more when braking at 65+ MPH. I'm pretty sure my front shocks are bad but could it be the shocks? Or maybe the hub that the rotors mount on? This is so annoying because the rotors don't even last an oil change! Any help is greatly appreciated!
  2. Apr 11, 2025 at 12:13 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    - Measure your rotor run out
    https://youtu.be/RdTK7Lvxflo?si=yfR_XEm1bsOcP0uJ
    - Tundra run our should not exceed 0.05mm or 0.002 inch
    - If you have excessive run out, that means usually you have worn out bushings or tires/wheels out of balance.
    - if you do not have excessive run outs, check the calipers, the calipers may be dirty or the pads can't slide smoothly when the brakes are applied.
    Always clean the hub surface when installing rotors.
  3. Apr 11, 2025 at 12:31 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    no, that shaking in the wheel you're feeling is the fact that your front rotors are warped. If you feel the shaking in the brake pedal or seat, its the rear rotors. Sounds like you are either too hard on your brakes or hitting too much water (car wash?) when they're hot causing them to warp. You could try drilled and slotted rotors from power stop to see if they'll stay more cool; also change the pads at the same time
    Black@Blue19 likes this.
  4. Apr 11, 2025 at 12:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Use cryogenic rotors and make sure you properly bed in the brakes. Tundras are heavy, if you do alot of driving at elevation make sure you engine brake. That's how I warped mine first time. Also unbalanced tires would contribute to shake also.
  5. Apr 11, 2025 at 12:44 PM
    joseph_womack
    Joe
    Louisiana
    whatre cryogenic rotors?
    +1 for burning in the pads and rotors, we do this on every car that comes through the shop for a brake job
  6. Apr 11, 2025 at 1:25 PM
    MadMaxCanon
    Frozen rotors, cryogenically treated to extremely cold temperatures. Makes them very durable. Love mine, very good bite.
    joseph_womack[QUOTED] likes this.
  7. Apr 11, 2025 at 1:26 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Bad rotors
  8. Apr 11, 2025 at 1:40 PM
    shoot-staight
    shoot-staight New Member
    Brett
    2007 SR5 double cab, 2020 SR5 double cab
    While not on my tundra I had A terrible issue with shaking when braking on my beater equinox. Replaced rotors, brakes etc. did not go away. Lives w it for a while then my front bearing really got loud. Replaced them. Went away completely.
    So it's not always the rotors themselves. Other things can be loose and give vibration or pulsation in my experience.
    ColoradoTJ likes this.
  9. Apr 11, 2025 at 2:31 PM
    JayKay
    Thanks everyone! I'll check to see if the bearings are bad or any of the tie rods are bad over the weekend. If the bearings and tie rods seem fine, then I'll purchase the dial indicator to check the run out. What I don't understand is why my lifted Tundra had zero issues with the steering wheel shaking when applying the brakes, while this Tundra has the steering wheel shaking after 7K miles after installing new rotors, twice!
  10. Apr 11, 2025 at 4:08 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    It is very weird that it seems to happen around 7000 miles or so. I would ask how often do you need to brake at 65mph and how hard are you applying the brakes when you are? I have the same year truck and have never had this issue fortunately, but I am a firm believer that driving styles have a lot to do with braking issues that seem to be a frequent issue. I have yet to replace rotors on most of my vehicles more than once honestly. Rotors should last quite a few miles without needing replaced so often as what you are describing.
  11. Apr 12, 2025 at 5:16 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    As mentioned, it can be different things. Brake calipers, pads stuck in caliper, wheel bearing, rust on the hub should be removed and flat before installing rotor, front end steering and suspension checked, rotors. Many use the drilled and slotted rotors, I've been using slotted only, EBC on fronts have been great, on my 3rd set of pads no issues..
  12. Apr 12, 2025 at 3:30 PM
    JayKay
    When I'm traveling on the freeway, I always go 70 MPH. As I'm going 70 MPH, a car might cut me off or a car in front of me slamming on their brakes making me slam on my brakes which is when the steering wheel starts shaking. This is after something like 7K miles after replacing new rotors. Once new rotors are on, there are zero issues with braking and zero issues with steering wheel shaking when I slam on the brakes at 70 MPH. Like I said, on my previous Tundra with the same year never had an issue with steering wheel shaking once the rotors were replaced, even after 30K miles. This Tundra, the rotors were replaced twice already and about to do it the third time but I know it will shake again once it gets near 7K miles.
    freerider8[QUOTED] likes this.
  13. Apr 12, 2025 at 5:34 PM
    joseph_womack
    Joe
    Louisiana
    Again, like I stated above; your rotors are warped… trying going a different direction than oem rotors, maybe a heavy duty rotor meant for towing with NEW ceramic pads.
    doesn’t hurt to double check bearings, calipers and tie rods but the symptoms you’re telling me, it’s 9/10 times rotors
    freerider8 likes this.
  14. Apr 12, 2025 at 6:25 PM
    freerider8
    Fairview PA
    Like others are saying that it definitely sounds like it is the rotors are the issue. I would look to see if there are ones that may be more heavy duty and see if you can get more miles out of them and then in the long term would actually save you money and time. Good luck with whatever you decide.
  15. Apr 15, 2025 at 1:14 PM
    JayKay
    For sure I know it's the rotors but what drives me crazy is, I had another Tundra same year, same trim, same everything but had ZERO issues with the rotors warping, even after 30K miles with new rotors installed. Again, steering wheel only shakes when appying the brakes at 70 MPH after 7K miles of installing new rotors. Wheel bearings are solid with no issues when I jacked the Tundra up and tried to wiggle it. The wheels does wiggle at all.
  16. Apr 15, 2025 at 1:56 PM
    joseph_womack
    Joe
    Louisiana
    It’s not an apples to apples comparison.
    Just cause the trucks are identical doesn’t mean your experiences will be.
    maybe you drove through water after braking hard and warped them, or went through a car wash etc etc
  17. Apr 18, 2025 at 3:32 PM
    JayKay
    Then everyone would be braking hard in the rain every now and then
  18. Apr 18, 2025 at 3:38 PM
    JayKay
    But why would the steering wheel shake when braking at 70 MPH but when braking at 60 MPH, the steering wheel doesn't shake at all? Braking at 70+ MPH makes the steering wheel shake badly, braking at 65 MPH makes the steering shake but not that bad and braking at 60 MPH, the steering wheel doesn't shake at all. Right now, I'm just thinking about buying a pair of cheap rotors for $50 and replacing them every oil change or every 2 oil changes, depending on how bad the steering wheel shakes. The $50 pair of rotors have a 4.5 star rating on Amazon also.
  19. Apr 18, 2025 at 3:45 PM
    LightTheBeam
    LightTheBeam New Member
    Sacramento, CA
    2024 Tundra Limited
    Bone stock (for now)
    Take the brakes off and you won't get the vibration anymore
    Corndog123 and joseph_womack like this.
  20. Apr 24, 2025 at 5:05 AM
  21. Apr 24, 2025 at 4:53 PM
    MadMaxCanon
  22. Apr 24, 2025 at 5:01 PM
  23. Apr 24, 2025 at 5:48 PM
    MadMaxCanon
  24. Apr 24, 2025 at 6:00 PM
    Yeah I just did the OCD thing and ordered both. Expensive but not near as expensive as my suspension that I am waiting to arrive.
    MadMaxCanon[QUOTED] likes this.
  25. Apr 24, 2025 at 7:14 PM
    MadMaxCanon
    It'll definitely feel way better with all 4
    Tundra234[QUOTED] likes this.
  26. Apr 27, 2025 at 5:22 AM
    Throwing parts at a problem is going to get very expensive for you. Let's do some troubleshooting shall we?
    What we know:
    -brake rotors are getting material build up ever 7k miles and causing vibrations when hard braking from 70 mph.
    -this problem has happened two times before with relative low miles.
    -new rotors, old pads. This isn't a problem unless there is a problem.
    -this keeps happening with no changing of process and same results.
    Let's find the problem:
    Tools needed- Thermal gun, basic tools, brake lube, brake cleaner, some sort of abrasive to clean hardware if all gummed up with debris.
    -take the truck for a drive and use the brakes as little as possible. Before you check with a thermal gun, coast to a stop if you can. If not, the results will be obvious. Once stopped, check rotor/hub temp on both sides and write it down.
    -Now go take a drive and use the brakes heavily. Stop again and check rotor and hub temps again.
    Are both sides pretty close in temperature?
    If no, the higher temperature side is probably the issue.
    -common problem is brake drag from a sticking caliper. Did you install all new brake hardware? Did you use brake caliper lube? Are the caliper pistons retracting all the way?
    Once a year I would pull my front pads and hardware, clean all the road debris off and lube the correct areas. This helped quite a bit and made my 2nd gen front brakes last 60k+ miles with a lot of towing in mountain terrain.
    Yes...move on.
    New rotors, old pads, calipers are not sticking (if verified).
    Let's look at your old pads. Remove and put a straight edge on them. Check thickness. Are the pads the same all the way around?
    How is the surface?
    Do you have a brake line getting soft? Does the truck pull to one side under heavy braking? Have a friend step on the brake pedal and check to see if a rubber brake line is failing. You will see a bulging in the line. This will cause uneven braking (but usually a pull to one side).
    Alignments and wheel balancing can cause vibrations but I personally don't think this is the problem since changing out rotors fixes the problem temporarily but degrades quickly.
    BrandonL812 and freerider8 like this.
  27. May 1, 2025 at 5:31 PM
    If I'm reading correctly, the Frozens don't require bedding, just easy on the brakes for a couple hundred miles until they are broken in?
  28. May 1, 2025 at 7:54 PM
    MadMaxCanon
    Don't think I read that, I did a bedding process just to be sure. I figured the pads would benefit too.
  29. May 5, 2025 at 1:32 PM
    I would recommend staying on course and not getting into trading senseless blows. That will lead to getting banned.
    JayKay[QUOTED][OP] likes this.
