What is this part attached to the filler neck?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jzsmooth, May 5, 2025.
  1. May 5, 2025 at 4:37 AM
    Jzsmooth
    Jzsmooth [OP] New Member
    14 Tundra Limited
    14 Tundra has a small evap leak code P0441. Ran smoke through the system and saw smoke coming out of a small hole in this part attached to the filler neck. Any idea what it is and if it’s supposed to be a vent or something? Photo attached.
  2. May 5, 2025 at 6:36 PM
    ToyotaBeast
    ToyotaBeast New Member
    Thats normal for it to leak from there, That is a vent. You can plug the vent line and try smoking the system again.
  3. May 13, 2025 at 3:31 AM
    Manuel0101
    Manuel0101 New Member
    Did you figure it out? I'm currently experiencing the same issue. I did a smoke test and noticed the smoke coming out of those two holes as well.
