  1. May 3, 2025 at 6:28 PM
    Dakillacore
    Georgia
    3 turns to the right creates a black hole. Never do three turns to the right.
  2. May 3, 2025 at 6:50 PM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    If you hold the key to one side will it roll down the windows?
    mine doesnt, but i’m fairly sure the sequoia did.
  3. May 3, 2025 at 7:51 PM
    Dude. What the hell? Where’s your felt washers and dielectric grease? Do you hate your Tundra, or what?
  4. May 3, 2025 at 7:53 PM
    If you go 3 turns to the right while going ass to mouth, do they cancel each other out?
    https://www.youtube.com/watch?v=JoRQEQUi9NM
    Dakillacore[QUOTED] likes this.
  5. May 3, 2025 at 10:31 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Wow. I sometimes feel I am de cyphering some code.....
    Back when I had just turned 18 and the Warsaw Pact fell apart....all those wonderful WW2 rifles started flooding in at basically scrap metal prices...no rifle you bought came with a box or instructions....and I'd be out with the thing and discover something new concerning how it worked.....almost like that. :)
  6. May 4, 2025 at 2:37 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Lol I plan on getting the felt washers, already have the greese just didn't bother throwing on yet. Thinking of just getting new terminals too
    bmf4069 and shifty`[QUOTED] like this.
  7. May 4, 2025 at 4:06 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Can’t wait…. I get mine back tomorrow with its new set of Billies and 2883s….
    Filthyphil likes this.
  8. May 4, 2025 at 6:53 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'll bet you'll like them! Seems like these trucks are affected very differently by suspension depending on whether they're RCLB, AC or DC, so it'll be different for you, but I really like my 2883s with 4600s.
    Filthyphil and MooreKen like this.
  9. May 4, 2025 at 6:56 AM
    MT-Tundra
    Montana
    I've been too lazy to do it, but shifty`'s advice on the buffing is something I've been thinking about. My paint is definitely chalky, and yes, everything sticks to it. Anytime I get mud on it, I need to use the foaming brush at the car wash. Just spraying it won't get it clean.
  10. May 4, 2025 at 7:32 AM
    Low buy-in here, just to show you an example of what's possible. Grab one of these from your preferred source, specifically the orange one. Grab a bottle of this from your preferred source.
    Wash your truck so you don't have residual grains of sand that will screw you over. Find an inconspicuous area that's dry and dirt/sand-free. Apply a squirt of polish to the honeycomb side of the pad, silver dollar sized. Firmly work it in 6-8" overlapping circles slowly on your desired incsonpicuous panel, with medium-heavy pressure, overlapping each circle about half an inch. Repeat back/forth 2-3 times. Buff away with a clean terrycloth towel that, again, is free of sand/dirt. If you don't see a significant improvement, I'll be shocked.
    Nicklovin and KNABORES like this.
  11. May 4, 2025 at 8:39 AM
    MT-Tundra
    Montana
    Thanks! I think the random-orbital sander purchase plus the time commitment are what's held me back, but I know they're low hurdles. I have no doubt that buffing will produce amazing results. Just hasn't beat out other projects on my priority list. YET.
    Between my truck, car, utility trailer, slide-in camper, camper trailer and other stuff, all of which are old and requiring maintenance to even be functional, I just have too much to be concerned with my truck not being shiny enough and having dirt stick to it. :D I care about it, and I DO plan to do it at some point. Right now I'm trying to get all my stuff ready for use this summer, so I'm not taking up summer weekends working on my stuff. I want to just use my stuff this summer.
  12. May 4, 2025 at 9:48 AM
    Before you make the investment on the orbital, you're looking at ~$25 for a proof of concept. The truth is, you're going to need those two items I just mentioned to get the tight areas, namely the A- and B-pillars of the truck, the ridgeline above the rear window, the strip of metal below the bed, that annoyingly tight area under the rear view mirrors on the doors, etc. You won't be able to run a random-DA/orbital on those areas, and that hex logic pad is your ticket.
    Since you've got to pick them up anyway, and you probably want to test an area BEFORE you drop money on the polisher and 6" corrective pads - just to make sure you're going to get an acceptable result - it's the only reason I mention it.
    The reality is, if results are good and you buy the polisher, I'd recommend to practice on the tailgate since you can take it off, lay it flat on some sawhorses, and sample various pressures. You'll probably find (like I did) that the semi-circle body line on the tailgate is a bugger to polish out when it's time. But it's also one small, cohesive panel to cut your teeth on, get a feel for it. Then I'd move to a bedside (or both). Then the doors. Then the roof. Then the hood and fenders. Then do the fill-in spots. It's a hell of a lot easier and less monumental (speaking from experience) if you break the job up into panels.
    Just make sure you wax anywhere you polish once you're done, or it'll oxidize again in a few months.
    MT-Tundra[QUOTED] likes this.
  13. May 4, 2025 at 10:32 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    They’ll fit with just a few more mods…
  14. May 4, 2025 at 10:38 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Nothing an angle grinder cant handle.
    Voss, bmf4069, oscardog86 and 3 others like this.
  15. May 4, 2025 at 10:42 AM
    Probably have to cut the bump… oh wait, nvm
    bmf4069, shifty` and Sirfive[QUOTED] like this.
  16. May 4, 2025 at 10:51 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Wide 35’s hit my uca’s even though the jba’s have more clearance than stock uca’s. Assdogs adjustable uca’s must have even more clearance. I dont think he had front spacers on.
    sidenote: i need an engine bay/interior decorators thoughts on powdercoating, would a gold intake and red valve covers/brake calipers/uca’s be a bit too german? Should i keep the intake silver? Maybe paint something green in there to throw em off?
    Voss, oscardog86 and Filthyphil like this.
  17. May 4, 2025 at 11:46 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    You spelled thousands wrong haha. I've honestly been putting it off because it's going to spiral out of control. LT, glass, bypasses.. Then I might as well order rear glass and then I'll want the truck painted. Then I'll want my rear end redone. Then my wife will want a divorce haha
  18. May 4, 2025 at 11:48 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I honestly like the silver. Polished manifold would look hot.
  19. May 4, 2025 at 11:49 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    then you’re gonna want an 8krpm ls swap.
    khooiii[QUOTED] likes this.
  20. May 4, 2025 at 11:55 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i’ve got a belt sander, to see how solid that casting is. I’ve polished a b16 valvecover, and a ford 7.3 turbo hardpipe (for an exhaust on a 2 dr hyundai accent.) if its a good casting, i’ve got the time, if its got bubbles, it’ll get filled & powder coated, or jet-hot’d.
  21. May 4, 2025 at 2:01 PM
    bfunke
    bfunke Tundra Curmudgeon
    Why is that engine compartment so glossy?
  22. May 4, 2025 at 2:22 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Ferrari wrinkle red valve covers baby.
    bmf4069 and Sirfive[QUOTED] like this.
  23. May 4, 2025 at 2:23 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    BroHon and shifty` like this.
  24. May 4, 2025 at 3:42 PM
    Note the droplets on underside of hood.
  25. May 4, 2025 at 3:55 PM
    Openbaffle
    Openbaffle New Member
    G_unit3000 and Filthyphil like this.
  26. May 4, 2025 at 4:26 PM
    Mullen
    Mullen Desert Dude
    Corona, CA
    You nailed it. I often think a drug habit would have cost me less money and trouble!
  27. May 4, 2025 at 8:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No front spacers with the 35's.
    But I found the new rubs with the 33's, thanks to the Solos. The fronts of the front fender flares aren't happy. No clue what happened to that signal.
    Had some good crunches at Jambo.
    Might be time to rip off the flares. I think 3/4 are coming off anyways haha
    Truth is, I wanted to ditch the flares on day one, but they grew on me. Almost 7 years later, I might follow through and remove em.
  28. May 4, 2025 at 8:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You oughtta check out how @RUSTYNUTS did his rear bedsides without glass. Pretty neat trick.
  29. May 4, 2025 at 10:20 PM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    I am planning a future project. If anyone has any additional advice it would be appreciated.
    I plan on: Removing blower control resistor and cleaning as much dirt, dust, and debris as possible from the A/C coil before spraying with some type of foam coil cleaner. (From what I read, doing as much cleaning as possible while dry is key, such as using a toothbrush , etc…). Then I plan on using a water hose to rinse it all out, (this is where I hope the condensation drain isn’t clogged). The good news is my floor is vinyl and can be cleaned with ease if I make a mess. I may purchase one of those cheap ozone machines to use after I’m done and everything has dried.
    Any additional thoughts?
  30. May 5, 2025 at 1:31 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    WTAF?, did you park the front of the truck too close a campfire at T2S or jambo? Looks like it's got shrinkage:rofl:
