Coolant running down transmission
Discussion in '2.5 Gen Tundras (2014-2021)' started by Haulmode, May 4, 2025.
  1. May 4, 2025 at 3:52 PM
    Haulmode
    Haulmode [OP] New Member
    2021 CM SR5 Cement
    Bilstein 6112/5160, Falken Wildpeak 285/75r18, Demello Rock Crushers, Tech12Volts Sound, Trans cooler
    While running hoses for a trans cooler on my '21 with 51k miles, I noticed dried coolant around the "warmer puck" area of the trans. Could this be a valley plate leak, or leak from somewhere else? Debating whether to install the trans thermostat or not before I take it in for diagnosis.
    20250504_174319.jpg I did not see any signs of coolant leaking from up top or higher on the lines going to the warmer puck.
  2. May 4, 2025 at 4:10 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Could just be the o rings on the puck itself. If it is your install should fix it and if not, I doubt installing a thermostat would impact the diagnosis at all.
    Haulmode[OP] and Mdl like this.
  3. May 6, 2025 at 6:30 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    If o rings leak they leak atf fluid not coolant.
    MadMaxCanon[QUOTED] and vtl like this.
  4. May 6, 2025 at 6:34 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Check it from top of the engine. May need inspection mirror.
    Haulmode[OP] likes this.
  5. May 6, 2025 at 7:26 PM
    MadMaxCanon
    Fair point lol
  6. May 7, 2025 at 3:50 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    To me that looks like a valley plate leak. Pretty common on these 5.7s and a fairly involved job to fix.
  7. May 7, 2025 at 4:57 AM
    Haulmode
    2021 CM SR5 Cement
    Couldn't find any pink stuff from the top. I'm taking it in to have it looked at. Appreciate all the feedback!
    23Tundy likes this.
