Door lock actuator nightmare
Discussion in '1st Gen Tundras (2000-2006)' started by literallyme, May 1, 2025.
  1. May 1, 2025 at 4:58 PM
    literallyme
    literallyme [OP] New Member
    Southern California
    2006 Sequoia Limited 2WD, 1974 Pontiac Firebird 350
    I’m am now faced with a new issue on my Sequoia. My power door lock actuator decided to kick the bucket. Ordered a new one, and it’s not working correctly out of the box. Let the dealers parts guy know, he got me another one, same thing. Now I’m on my third, gotta unwrap it, it’s been weeks now. What happens is, when I press unlock to actuate it, it locks it instead while all the other doors unlock as usual. I ruled out that I assembled it incorrectly. The FACTORY motor “kicks out” to the RIGHT to unlock, I’ve never had an issue with it until it gave up. The NEW one “kicks out” to the LEFT when I press unlock, this is what causes it to lock instead. Dealer parts guy was apologetic at first, but now shop foreman is getting involved and now I’m getting the blame for installing it wrong. I even got the one for the passenger side, but that one doesn’t fit at all on the drivers side, so I ruled out the possibility of it being for the wrong side. ATP I am thinking of just going aftermarket, but I feel even that’s gonna be a crapshoot. Any ideas?
  2. May 1, 2025 at 5:27 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    That’s strange, my first thought was that they mixed up the part number and gave the wrong side. I can’t imagine Toyota changing the locking directions and the plug only goes one way, so it can’t be hooked up backwards. Does all the linkage connect correctly? Absolutely a head scratcher. I’ll let the smarter folks assist ya, but best to ya.
  3. May 1, 2025 at 5:39 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    When the actuators went out on my Tacoma, I replaced them with the manual version. It was the different between something like $400/side for auto, or just under $200/side for manual. Parts guy said they looked like they'd fit, and if they didn't I could return them. They fit, and I just dealt with manual door locks the rest of the time I owned the truck. But it was just a two-door...
    Not much help with your problem though. I don't understand electronics very well but I can't see how, if everything was working correctly before, and you connected it all correctly, it could be working backwards. Did you read any tutorials on installation? I can imagine there being some critical step you missed. Like all the other doors being locked during install, but this one being unlocked? If they all operate as one, maybe they all need to be locked, or all need to be unlocked, when you install the "master" aka driver lock?
  4. May 2, 2025 at 9:53 AM
    Try reversing the wires?
    It's not abnormal for the wiring on window motors and door lock actuators (aftermarket ones, at least) to be reversed. It's been reported on here a number of times. You should be able to -repin the factory connector to swap the wires, or you can potentially use a 9v battery to trigger the door, and reverse the terminals to see if you get the correct response.
    gearmesh, Tunrod and NewImprovedRon like this.
  5. May 2, 2025 at 10:23 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    At that point I would either have the parts guy or foreman check it out and verify. Then I would probably return it and buy used off ebay with a warranty. I just bought a driver-side replacement that has a 60 day warranty for $70.
    literallyme[OP] likes this.
  6. May 2, 2025 at 10:27 AM
    I'm also wondering if maybe it's for the wrong side, or is that even possible?
    Use the left-hand latch on right-hand door, it has to pull the other direction, right? Or maybe I'm wrong.
  7. May 2, 2025 at 10:42 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I imagine it would pull the other direction but if I remember correctly from swapping the passenger side the orientation wouldn't allow for you to swap sides. That's what seems really weird to me. I wonder if there's a chance it could be for the rear door?
    rouxster70 likes this.
  8. May 2, 2025 at 12:25 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    RH can not fit on LH nor vice versa. The part # 69120-06010 on the bag is indeed part for FNT LH for various year Tundra/Sequoia according to Ourisman Toyota..
    The below is my spare FNT RH from few years back showing R for right hand. Should be an L on @literallyme actuator.
    Wire drawing in case you need it @literallyme
  9. May 4, 2025 at 10:34 AM
    literallyme
    Southern California
    Thanks for the diagram, yeah I’m gonna try playing with the connector and seeing if that’s the issue. I just don’t know why I’d have to modify it for a TOYOTA PART like it’s an aftermarket one. If worst comes to worst, can’t figure it out, the parts guy said he’d still give me a refund, take the money, and just either get one at a junkyard or aftermarket. Gotta make a junkyard visit anyways. At least I’m getting used to the manual lock…
  10. May 4, 2025 at 12:27 PM
    The two parts look physically different to me, as if one of them isn't OEM, what's that embossed logo on the one above, "LiteCOM" or something?
    Is it possible a previous owner swapped out the actuator thinking it was a problem previously, and they installed an aftermarket part which is not malfunctioning in short order, because aftermarket parts are utter shit these days? Maybe they had to re-pin the wires in reverse because, as others have found on here with window and door controls, the wiring for the aftermarket part was generic or reversed from OEM?
    Aisin made some electronics in the doors, I just can't recall if it was the door or window actuators. Maybe it was both. These are the ones I logged down using Aisin's online part finder after plugging in my (specifically) 2006 Access Cab, which may not match your Sequoia - note the last block below. You should use that parts finder to look yours up: https://aisinaftermarket.com/online
    Maybe your issue is, a previous owner cheaped out, and now you're left holding the bag for their ignorance or stupidity (whichever it may be, I can't say).
  11. May 4, 2025 at 1:35 PM
    literallyme
    Southern California
    Yes it says GECOM, and yes it’s what came in the bag with the part no. from Toyota. I see the diagram, it makes sense, but I’m not sure on how to repin the wires…
  12. May 4, 2025 at 2:28 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If I'm not mistaken, I recall the black connector had what I remember to be white tabs on one side that you initially have to raise up slightly. Then you work on depinning.
    It does not have to be jeweler screwdrivers but my set has helped me on many projects including depinning.
    There are other videos out there but the one below I started where he's getting to the meat of depinning.
  13. May 4, 2025 at 3:38 PM
    Welp, looks like it's probably OEM.
