2020 needing a trans cooler...
Discussion in '2.5 Gen Tundras (2014-2021)' started by mountaingroan, May 4, 2025.
  1. May 4, 2025 at 10:45 AM
    mountaingroan
    mountaingroan [OP] New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Preparing to head from Idaho to Ontario, Canada with truck camper and boat later this month and have a '20; as such it is missing the prior-equipped 2nd gen trans cooler.
    I don't want to spend a $1000+ for a dang cooler. I've installed many of them, the last in my 2007 4.6 for the truck/camper boat burden. It was a 45 minute job and $175.
    Curious what options exist for a $300-$400 setup if any. It seems that this all comes down to an (unavailable) access line for an added cooler. Thoughts?
    Thank you in advance!
  2. May 4, 2025 at 10:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  3. May 4, 2025 at 11:10 AM
    mountaingroan
    Frank
    North Idaho
    T/Y!
    Looks like these parts....and a cooler.
    32970-34030 Thermostat Unit $163.26
    32907-0C020Cooler Pipe $80.34. (Unless I go 'all rubber' lines)
  4. May 5, 2025 at 4:55 AM
    Earthsurfer
    Earthsurfer Randyman the Handyman
    Randell
    Edwards, CO
    21 Tundra limited
    Rear sway bar, trd air filter, running boards, sound deadener in doors, upgraded speakers, cargo glide, topper, Roof racks, overland awning.
  5. May 5, 2025 at 5:10 AM
    Earthsurfer
    Randell
    Edwards, CO
    21 Tundra limited
    many you tube posts on towing w the 2.5 gen without the cooler and there were no issues w it.
    funny how Toyotas are a sealed transmissions that require no maintenance, but
    Toyota recommends changing the transmission fluid every 30k if towing frequently. Most call it a drain and fill not a flush.
    I tow a camper all summer so I did a drain and fill on mine and it’s pretty easy.
    There are deep transmission pans that have vent holes that allow air to help cool the fluid without using a cooler, but you end up adding a bit of fluid.
    Your unit hold about 12 quarts of fluid, a drain and fill will drain off about 3.5 quarts of that but if you drop the pan you drain about 4.5 quarts.
    So I added a deep pan to mine and it’s been great.
    I do frequent drain and fills ( every 2 years) and sent the fluid in for testing after installing the deep pan and the results were very good.
    bulldog93 and _none_ like this.
  6. May 5, 2025 at 5:37 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I get it, but if you are going to go through all of that, just add the cooler and not worry about it any more.
    My pan temps have hit a high of 199F since i've added the cooler, and that was only on a few mile climb up a steep grade, 3rd gear (TC unlocked) towing a trailer. Remainder of the time, im hitting highs of 194ish. No concerns of temps any more.
    https://www.tundras.com/threads/parts-list-for-adding-oem-trans-cooler-to-5-7l.125248/
    mountaingroan[OP] and bulldog93 like this.
  7. May 5, 2025 at 5:48 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Need two rubber lines between t-stat and steel pipes, too.
    This is a good deal: https://www.ebay.com/itm/286138420790 I paid $520 for the same set of parts back in 2023. Shipping was fast, too (it comes from Japan).
    bulldog93 likes this.
  8. May 5, 2025 at 6:50 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    The least expensive would be the LC Saraha setup - its 2 OEM fittings for trans and then your lines (I like braided) and your awesome cooler + a fan (for stop/go towing).
    Mdl likes this.
  9. May 5, 2025 at 10:06 AM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    The Genuine Cooler Trans cooler is 1388.00 shipped, my lack of patience and anxiety taught me a lesson my bank account felt firsthand.
    if I were to do it again, I’d piece a kit together, use braided lines or even purchase the hard lines (80.00 +/-) and do it in a couple hours.
    I have the MillerCat Shields on my 2020 and spent a week waiting on the security screw bits I had to order because I misplaced mine.
    Some of these guys are getting kits together under 500.00, I should’ve been patient.
  10. May 6, 2025 at 4:37 PM
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Bilstein 6112/5160, Falken Wildpeak 285/75r18, Demello Rock Crushers, Tech12Volts Sound, Trans cooler
    For under $400, I pieced together thermostat, cooler, AN fittings, clamps, hoses with temp braiding, trans pan gasket and 4 gallons of Triax global ATF. Flushed the trans after installing the cooler. Let's see if I destroy the truck by not using OEM parts and WS... :rofl:
    So far, pan temp has been no higher than 201, and post- converter temps have spiked to 221, but come down pretty quick. I have cat shields, which i believe make the temps a bit higher.
  11. May 6, 2025 at 5:03 PM
    Johnsonman
    Austin
    Sequoia
    That's the way I like it - uha uha!
    Haulmode likes this.
  12. May 6, 2025 at 7:36 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    This was after I test drove it, taking the back roads home
    Haulmode and bulldog93 like this.
  13. May 6, 2025 at 7:45 PM
    JohnWhicker
    JohnWhicker New Member
    Why in the phuk are these cooler kits so expensive, after market ones?
  14. May 6, 2025 at 8:30 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    I’m guessing it’s because they do all the leg work, the kits complete and if you have a lift and don’t have CatShields it can be done in 2 1/2 or 3 hours. It took me about 4 1/2 hours… no lift and CatShields, shimmying on my back all over my hangar bay, I’m glad nobody was around, I was cussing like a fool.
    This was AFTER I contacted MillerCat Shields to order two new security screw bits… took about a week to get here, showed up late Saturday and I knew I’d get it done today.
  15. May 6, 2025 at 8:47 PM
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Best part of that pic is the shepard with the look like "yeah, you're not gonna tether me."
  16. May 11, 2025 at 9:06 PM
    mountaingroan
    Frank
    North Idaho
    Okay, finally got to installing this trans cooler today, want to thank those who shared here. Lots of good info.
    I went with the Hayden 679 cooler and *all rubber lines.*
    Spending $1200 for this job with factory hard lines etc, was all overkill imho, but kudos for those that go forth with that.
    I have exactly $265.63 and right at 2hrs. in this job including jacking, grille removal etc.
    Toyota OEM thermostat $149.63 -ebay
    Hayden 679 cooler $55.93 -Amazon
    16 feet of 3/8" trans hose $25.99 -Amazon
    Hayden univ, mounting kit $22.08 -Amazon
    I quart Transmission fluid $12.00 NAPA
    Some notes....The Hayden mounting kit @ $22 is a must-have for a sanitary job. The cooler is held at three points and very tight.
    When replacing the old factory trans 'brick' with the new hose-stubbed thermostat model, PRE-FIT the lines on the assembly and add/tighten the clamps. You'll thank me later.
    Route the rubber lines with zip ties every 12", up out of the thermostat area straight up past the coiled anti-lock brake lines--I zip tied to them. I ran forward and along the right fender slash shield and out under the power steering reservoir. The only 'intrusive' thing I did (purposely) was hole sawing a small spot in the grille filler plastic for the lines to enter the grille area. It looks factory and none of the lines has any kink, excessive heat, or stress anywhere. I DID NOT have to remover the factory TRD skid plate.
    The job looks sanitary and clean. I'll add 2/3 quart of fluid on Tuesday when my wife gets back in town. I need a a second set of hands to feed a tube from above down to the 24mm access plug.
  17. May 11, 2025 at 9:14 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    you can get the miller cat shield removal bit for $2 on Amazon or any hardware store it’s just that star bit number 9 if I remember but don’t quote me
    bulldog93 and Rakkasan[QUOTED] like this.
  18. May 11, 2025 at 9:25 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    dang I bought a Tacoma with a rusted out one and I wanted it gone so I called miller and they told me to go to any vato zone or Home Depot and buy the bit I ordered it on Amazon it was super soft and shitty (the bit) but held up enough to get the cat shield off
  19. May 11, 2025 at 9:41 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    I used blue “Loctite” on the security screws when I installed my Cat shields, that was my fault the previous screws didn’t work.
  20. May 12, 2025 at 8:16 AM
    mountaingroan
    Frank
    North Idaho
    Forgot to add one thing here...since I'm not replacing my fluid just yet (I'm at 39k miles and plan to do so around 50k) I'm *pinning* my thermostat open for the adding of about 2/3 qt. fluid. Lot of opinions about the fluid level in these '18-'21 trucks, some say they are overfilled from Toyota, but I figure that I've only lost about 3-4 oz in replacing the transmission block, and I'll add for the hoses and cooler which should be around 2/3-3/4 quart in total. The net gain should be zero in total. I'll pull the pin after adding fluid and running the truck to inspect for leaks etc. I'll let the thermostat do it's job moving forward.
    Damn shame what Toyota has done with this ridiculous dipstick-less system. Same could be said for Toyota going to a non-spinoff cartridge-style oil filter. Anything to dissuade owners from doing their own maintenance. :confused:
  21. May 12, 2025 at 10:59 AM
    yakeng
    yakeng 3URFE Apologist
    My install was a GCS also (great quality). I think when I got mine, it was ~800ish. I just had a kid and didn't have time to spent hunting all the parts (some on backorder), so I paid for the convenience. But at that price (1,400), I'd be piecing it together myself. The premium is a tough pill to swallow.
