How do I lower Stock Running boards
Discussion in 'General Tundra Discussion' started by Yobuddy, May 3, 2025.
Would you lower stock running boards or trash em
Poll closed May 24, 2025.
  1. Lower stock
    0 vote(s)
    0.0%
  2. Trash em
    2 vote(s)
    100.0%
  1. May 3, 2025 at 6:52 PM
    Yobuddy
    Yobuddy [OP] New Member
    2024 SR5 Tundra
    Running boards Spray liner Topper Leather seat covers
    I know that there is a wide variety of aftermarket running boards that I could substitute in for the stock ones
    however if it’s not broke, don’t trash it. Am I right
    so I was thinking about trying to lower the stock running boards, just a couple inches and I was wondering if anyone has done that . heard of it done ,tried doing it or looked into it at all?
    Any all tips appreciated thanks
  2. May 4, 2025 at 5:37 AM
    2mchfun
    How about a small lightweight step stool with a string attached for easy up/down? Step tubes with an added second step are available too. I just can't see sacrificing ground clearance, so I would use a step stool if I had issues. All of that said, one can always fabricate new mounting brackets to lower steps, but you might end up with a less pleasing appearance. This could be overcome by modifying the back or inner portion of step to fill the gap. A flat strip of narrow material with marker lights mounted might work well and also be functional. All depends on budget and or creativity/skills. Good luck!
    Hard to see, but I have amber marker lights mounted in the gap above my steps...
  3. May 4, 2025 at 5:45 AM
    2mchfun
  4. Jun 16, 2025 at 7:44 AM
    FreemanHunter61
    FreemanHunter61 New Member
    2010 White Tundra DC
    Joying 10.1" audio added
    Hi, I have the same issue with the side step being hard for wife to use easily with both her knees have been worked on. Camper place that also sells steps suggested a welding place but the way the oem brackets look, it might lower it but also make it go inwards from the looks of it ? Don’t understand them being at the level they are anyway, if you get something figured out please post it and I’ll do the same if an answer comes up
    Thanks
