  1. May 3, 2025 at 6:55 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Finally managed to get some spring interior cleaning done, along with cleaning and conditioning the leather with Zymoil.
    Now I need the damn pollen to stop so I can do some exterior work.
    woods, BrandonL812 and HulkSmurf14 like this.
  2. May 3, 2025 at 7:21 PM
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    After T2S has to update the battery terminals. Decided to go with the Kaas. They seem to work well for now. One of my next projects is to clean up the wire rat nest.
    Corndog123, Florida AF, Mater and 5 others like this.
  3. May 3, 2025 at 7:25 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    I think I finished the last of the interior accent lighting. Wired in the VLEDS blue bar light with the dimmer I had leftover from the footwell install. Adds a nice touch and I can see the console and cup holders at night a bit easier now.
  4. May 3, 2025 at 7:26 PM
    AZTundra
    Paul
    Phoenix, AZ
    Overall a pretty easy install to do with minimal hand tools. Coverage is exceptional and the material feels to be good quality. I don’t see these flapping around and coming loose like the factory ones. I did trim just a bit around the abs wire by the upper control arms. The cable felt pretty snug against the shield and I didn’t want to have any rubbing as the control arms move up and down. Overall pretty pleased with them and a good upgrade for about $120.
  5. May 3, 2025 at 7:31 PM
    Azblue
    The Dirty T ( ^_^)_且
    This is how I imagine that project going:
    https://www.youtube.com/watch?v=4IFUYg9IUgI
  6. May 3, 2025 at 7:33 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :drool:
    Corndog123 and HulkSmurf14 like this.
  7. May 3, 2025 at 8:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Those look nice
    The wiring - not so much
  8. May 3, 2025 at 8:38 PM
    Tripleconpanna
    Just for the record, that thing we talked about.... mine's not that bad :cool:
  9. May 3, 2025 at 8:58 PM
    TNThunder
    TNThunder New Member
    Colten
    TN
    2017 Inferno SR5 Off-Road
    Went on a bit of exploration trip to Land Between The Lakes. Didn’t do anything too crazy because my wife just had some medical issues but a good time was had. Pulled out a 2nd gen after his 4x4 stopped working as well. IMG_1609.jpg IMG_4601.jpg IMG_4600.jpg IMG_1386.jpg IMG_1557.jpg
  10. May 3, 2025 at 9:07 PM
    RobertD
    Robert
    DFW, Texas
    Any pics of the bumper you installed?
    Corndog123 and Tripleconpanna like this.
  11. May 3, 2025 at 10:23 PM
    Fergie
    Fergie New Member
    I'm sure she appreciated getting out and about, and from ours to yours, hope she is recovering quickly.
    TNThunder[QUOTED] and Mater like this.
  12. May 3, 2025 at 10:29 PM
    Fergie
    Fergie New Member
    Had 4.88s done by an absolutely shite shop at 135k, sitting at 150k w this:
    Removed the 3rd member this afternoon, and Zuk says "never heard one make a noise like that..." He is doing the rewear to 5.29s. Anyone thinking that going numerically higher is bad, just dont....4.88s aren't worth it.
    For the shop that bent me over the barrel and had their way w me, well...this is your work:
    O-ring fell out on the PS, and you can see that state of it on the DS:
    Nobody likes the spicy magic fairy diff dust:
    The fluid, when drained, was so magical and glittery.
  13. May 3, 2025 at 11:00 PM
    Explorer
    Explorer New Member
    Battle Ground WA
    I know it's a mess. I have to shorten up all the trigger connectors and do a bit of rework. That is tomorrow's problem.
  14. May 3, 2025 at 11:01 PM
    Explorer
    Explorer New Member
    Battle Ground WA
  15. May 4, 2025 at 4:26 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Those look good. Thinking of getting them. I have rekgen. The passenger rear melted due to my exhaust. The micros should not have that problem.
    Dr3wski[QUOTED] likes this.
  16. May 4, 2025 at 4:41 AM
    RobertD
    Robert
    DFW, Texas
    Looks good!
    Explorer[QUOTED] likes this.
  17. May 4, 2025 at 8:10 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    LINK ??
  18. May 4, 2025 at 8:25 AM
    jackienguyener
    Jackie
    2016 Tundra 1794
  19. May 4, 2025 at 10:11 AM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Ya they are a solid poly type of plastic. Really rigid. Shouldn’t have any issues with deformation due to heat
    TacomaTRD4x402 likes this.
  20. May 4, 2025 at 11:34 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I had some knocking sounds coming from the supercharger, so I took it off and shipped it off to Harrop for them to look it over. I'm in the process of reinstalling the stock intake plenum so I can drive my truck this week and had to make some adjustments for the plenum to fit with my modifications. I had to adjust the fuel lines running behind the supercharger so the stock plenum would fit. I also had to move my electric fan thermo switch from the Harrop coolant crossover pipe to an adapter in the top radiator hose since there wasn't room to drill/tap 3/8npt into the stock coolant crossover pipe.
    Knocking starts about a minute after starting the engine
    https://youtu.be/y4cm_ln_lpk
    https://youtu.be/N-Pj-Nzic6M
  21. May 4, 2025 at 3:14 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Used the Cerakote Headlight restoration kit today and so far I'm impressed.The kit comes with wipes for oxidation,gloves,2000gr and 3000gr sand paper,sponge to hold the sandpaper discs and wipes with the sealant impregnated .I did use some 1200gr disc on my headlights first then followed up with the 2000/3000 all wet sanded.We'll see how long it lasts.Oh did the Yota emblem while I was at it:)
  22. May 4, 2025 at 3:18 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Looks good!
    BR73[QUOTED] likes this.
  23. May 4, 2025 at 3:21 PM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    I did the headlights on the 2002 Park Ave I was using as a commuter 2.5 years ago. They looked great for about 18 months but are getting a little hazy again. Not as bad a as before I did them but not great anymore.
    BR73 and bulldog93 like this.
  24. May 4, 2025 at 3:23 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  25. May 4, 2025 at 3:25 PM
    TacomaTRD4x402
    Southern California
    What's your wheel/tire set up? Are you running spacers? I'm in the market for tires right now so deciding what size I'll be able to squeeze in there after my lift. Do you have a front shot of your truck?
  26. May 4, 2025 at 4:43 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Vision 351 Flow 17x9 -12 Offset. Mickey Thompson Baja Boss A/T 285/70R17. King 2.5 at about 2” of lift. Not running any spacers
  27. May 4, 2025 at 4:45 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Super clean looking truck!
    ToyoMafia, BR73 and Dr3wski[QUOTED] like this.
  28. May 4, 2025 at 4:48 PM
    biebs96
    PA
    I used that kit about three years ago.
    started to show some oxidation on the top of the lenses about six months ago.
    Looks good, for the price it’s worth it!
    BR73[QUOTED] and bulldog93 like this.
  29. May 4, 2025 at 4:58 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Appreciate it!
  30. May 4, 2025 at 5:28 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    IMG_4125.jpg IMG_4126.jpg sprayed and installed RB30’s
