One dome light out
Discussion in 'General Tundra Discussion' started by TundraTRD08, May 3, 2025.
  1. May 3, 2025 at 7:52 PM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Okay, so my 2008 crewmax has working dome lights, but my passenger front bulb will not come on with the door lights. The bulb turns on when you click the light on manually, but not with the door. Again, it’s only this one bulb doing this. Any help is appreciated!!
  2. May 3, 2025 at 8:01 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That is odd since both bulbs share the same feed.
    Did you try another bulb?
    I know those contacts can be a little tricky at times..
    It would seem more likely to happen the other way, come on wiutht he doors but not with the switch.:confused:
    Perhaps taking the console down and cleaning the switch and bulb contacts with contact cleaner.
    Inspect the circuit board as well..
    2mchfun likes this.
