How do I lower Stock Running boards
Discussion in 'General Tundra Discussion' started by Yobuddy, May 3, 2025 at 6:52 PM.
Would you lower stock running boards or trash em
This poll will close on May 24, 2025 at 6:54 PM.
  1. Lower stock
    0 vote(s)
    0.0%
  2. Trash em
    1 vote(s)
    100.0%
  1. May 3, 2025 at 6:52 PM
    Yobuddy
    Yobuddy [OP] New Member
    Yesterday
    2024 SR5 Tundra
    Running boards Spray liner Topper Leather seat covers
    I know that there is a wide variety of aftermarket running boards that I could substitute in for the stock ones
    however if it’s not broke, don’t trash it. Am I right
    so I was thinking about trying to lower the stock running boards, just a couple inches and I was wondering if anyone has done that . heard of it done ,tried doing it or looked into it at all?
    Any all tips appreciated thanks
  2. May 4, 2025 at 5:37 AM
    2mchfun
    How about a small lightweight step stool with a string attached for easy up/down? Step tubes with an added second step are available too. I just can't see sacrificing ground clearance, so I would use a step stool if I had issues. All of that said, one can always fabricate new mounting brackets to lower steps, but you might end up with a less pleasing appearance. This could be overcome by modifying the back or inner portion of step to fill the gap. A flat strip of narrow material with marker lights mounted might work well and also be functional. All depends on budget and or creativity/skills. Good luck!
    Hard to see, but I have amber marker lights mounted in the gap above my steps...
  3. May 4, 2025 at 5:45 AM
    2mchfun
