AMP Power Step problems. One side working One side not...need help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Steuby01, Oct 24, 2024.
  1. Oct 24, 2024 at 10:53 AM
    Steuby01
    Steuby01 [OP] New Member
    2014 Tundra 1794
    Lifted and supercharged
    I have a 2014 1794 and I bought it used with the AMP Research Power Steps. Both steps worked great when I bought it and about a year after the driver side stopped working. Before it stopped working all together, it was intermittent coming up and down while the door was open. I have replaced the control module and checked over the wiring. I have called the help desk for AMP, and I have followed all the troubleshooting suggestions they gave me. Nothing has worked.
    I have used a multimeter to check for voltage. I have no voltage signal going to the plug to the step motor. I have about a 5v signal from the door signal wires that run through the floorboard and is part of the AMP harness when I press and depress the door plunger. The steps will not come down when either the front or back driver side doors are opened or both opened together. The strange thing is, when I manually retract the steps into the down position using a screwdriver and turning the motor manually, I'll bring it all the way down and when I will pull the fuse at the battery and put the fuse back in, the driver side steps will go up to the stowed position on its own.
    Has anyone seen this or troubleshot this same scenario? I would rather fix the issue instead of taking the power steps off completely and using regular running boards.
    This is my last hope....hehe
  2. Oct 24, 2024 at 11:04 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Sounds like the control module, did it ever work after you replaced it? Maybe you got a bad replacement.
    I had my control module go out on mine a few months before the warranty expired and they sent me a new module. I remember their CS being pretty good, but took a while on hold to get to them.
    Steuby01[QUOTED][OP] likes this.
  3. Oct 24, 2024 at 12:36 PM
    Steuby01
    2014 Tundra 1794
    It did not work after I replaced the control module. I don't think they warranty replacement parts if it is unsure it is bad.
  4. Oct 24, 2024 at 1:01 PM
    Glockman2018
    Glockman2018 New Member
    On my amp steps the driver side motor went out a couple months after install, a few more months passenger side when out. The new motors seem to be holding up well, time will tell.
    Steuby01[OP] likes this.
  5. Oct 24, 2024 at 1:05 PM
    Steuby01
    2014 Tundra 1794
    True, understandable that there are bad parts out there. I'm on hold with the company that I ordered the control module for to see what kind of warranty that I can get for a possible bad part.
  6. Oct 24, 2024 at 5:54 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    Did amp confirm the control module is compatible with the motors? Might want to see if you're able to switch to the OBD plug. Wiring on that was really straight forward, 2 wires.
  7. Oct 25, 2024 at 8:18 AM
    Steuby01
    2014 Tundra 1794
    I could switch to the OBD Plug, but I'd need to buy a whole new harness. They aren't that expensive, but I'd like to not re-wire the whole thing. I bought the control module from Real Truck and their techs assured me that the module was the correct replacement for my model. Those control modules are pretty universal.
  8. Oct 25, 2024 at 10:56 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    I used this one.
  9. Oct 25, 2024 at 12:35 PM
    Steuby01
    2014 Tundra 1794
    Looking over my receipt, that is the one that I ordered and the one they sent me they sent to me.
  10. Oct 25, 2024 at 12:43 PM
    Steuby01
    2014 Tundra 1794
    This is the shipping details they sent me when I received my controller.
    Official Amp Research Shipping Center, ElectricStep<webmaster@electricstep.com>
    Fri, Mar 15, 12:16 PM
    tome
    Order ID #151273 - Shipment Completed
    Please Note: this shipment completes your order. According to our records, all products have been shipped and should arrive shortly (delivery time changes depending on the shipping option you selected when you placed your order). If you do not receive one or more of the items that you have ordered, please contact us.
    List of shipped product(s):
    ( STA ) 19-04280-STA Controller | A-04 / A-06 Replacement - Qty:1
    Package Information:
    Shipment Method:UPS: UPS Ground
    Tracking Number:
    Shipped Date:3/15/2024
    Tracking Link:
    Thank you for shopping at Official Amp Research Shipping Center, ElectricStep.
    our store|account login|contact us
    © 2019 ElectricStep. All rights reserved.
  11. Oct 25, 2024 at 1:10 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    That's all appears to be the same. I got mine second hand, had to end up replacing the motors because the gearbox portions were seized. You can disconnect the motors and put power to them to see if it would spin. You can also manually spin the gearbox to see if that's the issue. I ended replacing pretty much everything but the hinges and boards.
  12. Oct 25, 2024 at 4:33 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I had to replace my module under warranty and drivers side motor. Are the passenger side steps working ??
  13. Oct 26, 2024 at 1:30 PM
    Steuby01
    2014 Tundra 1794
    Yes, the passenger side steps are working.
  14. Apr 23, 2025 at 12:03 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Steuby - Did you ever get this resolved? I am having same issue - sgteps do not deploy and my LED step lights do not come on. I am going down the troubleshooting doc and am getting ready to conclude that the problem is the controller but your post bothered me....thx, Buckaroo
  15. Apr 23, 2025 at 2:41 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Which controller do you have?
    Is it the older A-06?
    If yes, do you have the toggle switch?
  16. Apr 23, 2025 at 2:47 PM
    Steuby01
    2014 Tundra 1794
    I ended up removing the steps and putting on regular static running boards. Just got tired of trying to troubleshoot the steps. They are cool when they work.
  17. Apr 23, 2025 at 3:35 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    I installed the steps in '17 on my 2017 Tundra. They have worked well but had to replace the motor on the driver side in '22. It was covered under warranty. Yes, I have the A-06 control module but I don't have the toggle switch. I need to do some more testing tomorrow but am getting ready to indict the control module and replace with the 19-04280-STA but don't plan on including the toggle switch. I talkled to Tech Support today and they also think the control module is likely the issue but I want to make sure before I order it. I asked if the new control module was more reliable but they said that actually the old module was better. So we will see how it goes.
  18. Apr 23, 2025 at 3:48 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    PM sent
  19. May 3, 2025 at 6:36 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    I did figure out my issue and wanted to provide some feedback regarding my findings...it was not the module. I had contacted Tech Support at Realtruck and they provided the attached Troubleshooting Guide. It was very helpful but, unfortunately, was written for the plug-n-play OBDII control option and mine are hardwired. I went through the steps and got to Test 2 on page 4. I have two small gauge wires coming from posi-taps that I had installed on the OEM wiring in the kick panel (light blue and gray) - these are the trigger wires that are hooked up to the two door switches (front and back) on the drivers side. When either of these wires are grounded, the steps should deploy and lights on both sides (drivers & passenger) come on. I grounded one and the steps did not deploy. I back probed the wire providing the voltage to the motor coming out of the module plug (orange with black stripe) and did not see 12v when the trigger wire was grounded. I concluded that the module was the problem and installed a replacement thanks to @1lowlife who provided an old used module that he had salvaged off his install when he removed it. And.....the drivers side steps still did not deploy. The problem was not the module.
    More testing ensued. The two trigger wires splice into a larger gauge green wire with black stripe that goes to the module plug. I disconnected the plug and tested the resistance from the green/black wire connector to the end of the trigger wire where it connects in the kick panel on the drivers side. There was continuity but the resistance was very high (Mega Ohms) meaning the grounded signal was not getting to the module. I traced the two trigger wires down under the carpet and out the rubber grommet in the bottom of the drivers side floorboard. They feed into the convoluted covered wiring harness and the splice with the green black wire was about a foot upstream towards the module accessible from the left front wheel well - had to pull down the small, triangular wheel well cover to get to it (3 plastic compression connectors). After peeling out the wires from the slit in the black plastic convoluted covering, I could see the splice was in a clear covering and inside - green corrosion. I cut it out, soldered the splice, sealed it up using two layers of shrink tubing and electrical tape. Steps and lights now worked.
    I think this could be a common problem on Tundra's as they age with this AMP Powerstep Kit (75137-01A) because the drivers side splice falls beside the wheel well where there is moisture and salt. My steps have been installed 7.5 years at this point. The splice should really fall downstream in the cabin, through the grommet and under the carpet. When I was talking to Tech Support, the guy was very helpful and we discussed the possibility of a wiring rather than a module problem. He said he rarely saw any wiring issues so I think this could be a unique Tundra problem with this kit.
