Door actuator / key fob
Discussion in '2nd Gen Tundras (2007-2013)' started by TDAVI5027, Jan 21, 2025.
  1. Jan 21, 2025 at 6:29 AM
    TDAVI5027
    TDAVI5027 [OP] New Member
    Tom
    White 2011 Tundra X-SP
    2.5" Front Leveling Kit
    Key fob stopped unlocking. Locks fine but does not even try to unlock. First started giving problem months ago but could press remote hard and many times and finally worked. Lots of people suggest actuator but why would it not unlock the rest of the doors after it tried and failed to unlock driver door. Does it have to see driver door unlocked before signal to rest of the doors? Acts like it’s not even receiving unlock signal. Both remotes do exact same thing. Both remotes have brand new batteries.
    Thanks for info.
  2. Jan 22, 2025 at 12:38 PM
    SBGibson
    SBGibson New Member
    2011 Tundra 4 wheel drive
    Does the button in the cab lock and unlock all the doors when your inside ? Some of these rides won't unlock the door with the key when your battery dies, from what I've read.
  3. Feb 13, 2025 at 9:12 AM
    TDAVI5027
    Tom
    Yes. Locks fine in cab and from out side. Double turn off key in the lock will unload all doors and key fob has brand new battery. If I stand there long enough with button pressed it will eventually unlock
  4. Feb 13, 2025 at 12:24 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    You can get a new key fob shell and insert your fob circuit board into it. It's probably just your buttons are wore out.
  5. Feb 13, 2025 at 10:03 PM
    TDAVI5027
    Tom
    I’ve got two fobs and both do the same thing!
  6. Feb 14, 2025 at 6:50 AM
    82nd Airborne
    2012 SR5 DC
    If it were mine I would go to eBay and buy two identical fobs for less than $20 and swap in my circuit boards. It's possible your fob receiver module is flaking out but I doubt it.
    k0diak8o8 likes this.
  7. Feb 15, 2025 at 5:45 AM
    TDAVI5027
    Tom
    I took both fobs apart and just pressed the actual button. I also squirt penetrating fluid around all button switches. Maybe module is going out. Thanks for your help.
  8. Feb 15, 2025 at 7:40 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I’m not sure what you mean by penetrating fluid but sensitive electronics should be cleaned with something like this.
  9. Feb 15, 2025 at 8:46 AM
    82nd Airborne
    2012 SR5 DC
    I apologize. I didn't realize the fob has actual buttons on the circuit board. I'm used to fobs with contacts where swapping the shell can make it work like new again. Just swapping the shell wouldn't work for you.
    Does your truck have remote start? If so, does pressing lock 3 times start it?
  10. Feb 15, 2025 at 11:43 AM
    TDAVI5027
    Tom
    No remote start. Weird that it locks fine. As soon as you hit lock, it locks. Just doesn’t unlock… just went to get a time frame of how long it takes to unlock while holding button. Unlocked right away from 25 yards away! Hey. This is strange. I had a code pop up yesterday. Keep in mind. Unlock function has been messed up for ever. Yesterday a code with secondary air pump came up. Stuck open I believe. I installed Hewitt bypass maybe 2 years ago. I reset code this morning. Now my unlock is working. That makes no sense to me but I’ll take it!
  11. Feb 17, 2025 at 7:54 AM
    TDAVI5027
    Tom
    lol. Doesn’t work this morning. Hasn’t even got back in truck till this morning and it’s back to not working. Lock only!
  12. May 1, 2025 at 7:55 PM
    nlforeman04
    nlforeman04 New Member
    2010 Tundra
    @TDAVI5027 did you ever figure out what was wrong here. I am having i think the same problem. All doors will lock with the fob and the inside toggles, and when I hit 15 MPH, but ONLY my driver door will unlock. I can hit unlock on any door and all that will unlock is the driver door. I keep thinking I bumped into a button or something but I have searched and searched and no errant button found.
  13. May 3, 2025 at 5:48 AM
    TDAVI5027
    Tom
    Sorry but I did not. It started working somewhat. Have to start pushing it several times. Seems to help if I hit the lock button then hit unlock several times and then it will unlock.
