2007 TUNDRA ATF LIGHT
Discussion in '2nd Gen Tundras (2007-2013)' started by Paulb7743, May 2, 2025.
  1. May 2, 2025 at 11:14 AM
    Paulb7743
    Paulb7743 [OP] New Member
    Paul
    Toyota tundra
    Intake ( K& N )
    Hi guys , I have a 2007 Tundra 5.7 with just over 91K miles . Today I drove the truck about 20 minutes to an appointment , parked it for about 1/2 hr , then drove about 20 minutes back home , some stop and go but mostly highway . On the return trip , I noticed the blue ATF light on just a minute or 2 into the trip . I continued to drive slowly and in another minute or 2 the light went out - never came back on the rest of the way .
    No symptoms or any other light , like the check engine light ever came on .
    I know there's really no way to check the fluid , so any thoughts / ideas ??
    Thanks ,
    Paul B
  2. May 2, 2025 at 11:25 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Has a black Chevy Suburban with blacked out windows been following you? Maybe the truck is just trying to warn you to protect your dog. LOL.
  3. May 2, 2025 at 11:27 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Change the transmission fluid since it's probably never been done and is nearly 20 year old fluid. Drain and flush, then keep doing it every other oil change.
  4. May 2, 2025 at 12:16 PM
    EmergencyMaximum
    Well, the manual says it's sealed unit. If no heavy or extreme towing, fluid doesn't need to be changed for lifetime of the vehicle.:D having said that, mine started acting up with washbiard vibrations around 35-40mph and rumblestrip before downshift, so i changed mine. It was also in late 90's, k miles
  5. May 2, 2025 at 2:53 PM
    Paulb7743
    Paul
    Toyota tundra
    Intake ( K& N )
    Thanks guys . Going to try to find a reputable shop to get my fluid change done & see what happens ...
    EmergencyMaximum likes this.
