Monitor trans temp during drain/fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by Robster80, May 1, 2025.
  1. May 1, 2025 at 6:40 PM
    Robster80
    Robster80 [OP] New Member
    Planning to do drain/fill on my 21 sr5. Ive never used a scan tool but you need one for this job right? Can someone point me in the right direction as to what i should use?
  2. May 1, 2025 at 7:12 PM
    The Veepeak OBD adapter and OBD Fusion app.
    BrandonL812 and reywcms like this.
  3. May 1, 2025 at 7:59 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    You can activate the transmission temp check mode through the drive selector sequence. Procedure in the attached .pdf
    The Dude, Corndog123 and BrandonL812 like this.
  4. May 1, 2025 at 8:22 PM
    Robster80
    I just have to purchase the techstream cable right?
  5. May 1, 2025 at 8:23 PM
    Retired...finally
    Have you used this method? My 21 didn't have the pins. I have a scan gauge but wanted the reduced idle quicker but since mine doesn't have the listed pins I wasn't able to put the truck in check mode. It will eventually idle down but takes longer.
  6. May 1, 2025 at 8:26 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    I was able to activate it in my ‘21 SR5
  7. May 1, 2025 at 8:27 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    No cable required
  8. May 2, 2025 at 4:06 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Andre21 likes this.
  9. May 2, 2025 at 4:28 AM
    Retired...finally
    Maybe I was looking at my OBDI port wrong. I was reluctant to poke a paperclip in the port unless I was absolutely sure what I was doing. The day before I did my first D&F I did a test to see if the idle settled before the pan temps reached check temps. It all worked out fine.
  10. May 2, 2025 at 4:41 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    OBD adapter and Fusion app with Toyota enhanced purchase. Worked perfect..
  11. May 2, 2025 at 5:04 AM
    Robster80
    This one?
  12. May 2, 2025 at 6:04 AM
    Yes
  13. May 2, 2025 at 6:44 AM
    BrandonL812
    Brandon
    Veekeak obd2 is totally worth it. Did drain and fill on 2 trucks and it went awesome. No paper clip method and shifting from N to D and back and forth. Just watch your phone for temp to rise, drain level bolt. Wait, torque back. Ready to go.
    snivilous and Robster80[OP] like this.
  14. May 2, 2025 at 1:38 PM
    agrestic1
    2016 CrewMax
    I used Elm 327 OBD adapter and Fusion app..worked fine. Also have Veepeek OBD adapter just in case.
