Bed Removal, and found these...
Discussion in '1st Gen Tundras (2000-2006)' started by 2004Ton, May 2, 2025.
  1. May 2, 2025 at 11:27 AM
    2004Ton
    2004Ton [OP] New Member
    Welp, I removed my bed this morning, (2004 Tundra Access Cab) and found 2 of these on the driveway. I've been looking online for a diagram, but nada. Any idea where they go?
    THANKS!
    G_unit3000 likes this.
  2. May 2, 2025 at 11:35 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    @shifty` I haven't seen you stumped before. You know this one?
    2004Ton[OP] likes this.
  3. May 2, 2025 at 11:38 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Those go towards the rear and are little spacers that sit between the bed and the frame. I removed my bed last weekend and left one of mine off because I was having trouble with it staying in place while I dropped the bed down.
  4. May 2, 2025 at 11:47 AM
    2004Ton
    Man... might you have any photo avail? I've been looking and looking on the frame line, but can't see the location.
    THANKS!
  5. May 2, 2025 at 11:53 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I'm afraid I don't. They sit very close to the rear-most bolt hole. They point upward. Hopefully that helps a little.
    If you can take a pic of your frame where that bolt hole is I can try and point it out. I don't think they're really necessary because my new bed didn't have them.
  6. May 2, 2025 at 12:05 PM
    2004Ton
    Right on, that might be enough. I'll know in 10 min! ; )
  7. May 2, 2025 at 12:23 PM
    2004Ton
    I gotta be blind as a bat... I can't see how these things fit between the bed and the frame! I looked at both front and rear bolts, all of these areas seem paper thin tight... Crazy stuff.
  8. May 2, 2025 at 1:50 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    There should be a hole on top of the frame in the area I circled in red. That's the end of the frame right?
  9. May 2, 2025 at 2:23 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I always get a little jealous when I see all of these perfectly rust free frames
  10. May 2, 2025 at 3:23 PM
    2004Ton
    I jacked up the bed, looked between the frame. No hole besides the bolt hole, and one that when I put the damn spacer into it, it makes the bed sit 1/4 too tall. I'm about to just bolt her up. I can't see these being urgent...
    Thanks for the suggestions.
  11. May 2, 2025 at 3:54 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Does it have a part number on the bottom? Even the plastic/rubber bits on a Toyota often have a part number somewhere. I found another mystery piece of rubber in my skid plate. Could not see where it came from. Then found a part number on it once I cleaned it up. That helped me find where it came from. Job done.
  12. May 2, 2025 at 4:51 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Agree and when it's come up before no reason was ever determined.
    The below pic is from an 04-06 LSC for CRC that came out in 2013.
    Whether at EPC or even Partsoug that I prefer, they both show driver side, fnt and back as the below drawing shows.
    shifty`, G_unit3000, abcinv and 2 others like this.
  13. May 2, 2025 at 4:58 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    The tapered locating dome dowls are exactly that, for locating the bed on the frame. There’s only two of them, and they’re both located on the driver side of the frame. Put’em back into place in order to help facilitate reinstalling the bed on the frame.
  14. May 2, 2025 at 5:08 PM
    2004Ton
    Ah... drivers side only! I do see these holes. WTF! Thanks for the info guys. I was able to easily align the bolts without them, but may put them back because I'm anal. Sweet, thanks!!!
  15. May 2, 2025 at 5:25 PM
    whodatschrome
    lots of dents
    I’m kinda suspecting they do two things. Obviously they make it super easy to line up the bed bolts in order to thread them into the frame. Perhaps since they’re only located on the left side, is that they slightly keep the bed elevated off the frame (if they aren’t indexed properly) so that the main wire harness doesn’t get crushed while trying to located the bed onto the frame? Just a theory there.
  16. May 2, 2025 at 7:55 PM
    2004Ton
    “Sometimes the questions are complicated and the answers are simple.”
    — Dr. Seuss
    shifty` likes this.
  17. May 2, 2025 at 8:31 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    That’s more than I thought. I thought mine fell off the passenger side. Thanks @whodatschrome for the insight and straightening mine out. I could swear it was on both sides. Sorry for the confusion OP. That explains why I left one side out.
    2004Ton[OP] and whodatschrome like this.
  18. May 2, 2025 at 10:29 PM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    Informative. Thx.
    I only see theback one...is the forward one in place?
    2004Ton[QUOTED][OP] likes this.
  19. May 3, 2025 at 3:29 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    I found one of those in my yard a while back. It must have been from when I replaced the bed on my 2006 RCLB. Never had any problem without it so I don't think I'll remove the bed to find a home for it.
  20. May 5, 2025 at 8:12 AM
    2004Ton
    Both of mine fell off, but the holes are there on the drivers side.
    Thanks again! :thumbsup:
