Mud guards
Discussion in '3rd Gen Tundras (2022+)' started by bretto24, May 2, 2025.
  1. May 2, 2025 at 11:04 AM
    bretto24
    bretto24 [OP] New Member
    Brett
    2025 Silver Tundra Limited
    New 2025 Tundra owner. Previous owner of 3 Tacoma's. Picked up my Limited on Wednesday. 2 questions. Looking for mud guard (flap) suggestions. I was happy with the guards that came on the Tacoma but apparently, Toyota does not sell them for this generation Tundra? I do notice in the rear wheel well, it is kinda angled and not sure how that would affect the positioning of a mud guard. Any recommendations? WeatherTech sells a nice set but pricey.
    Also, I will be installing the dash cam I previously had in Tacoma. I was able to purchase a dash cam power kit that taps into the power from the rear view mirror rather than running a power cord to cigarette lighter. Much cleaner look. That is a 12 pin adapter and the connection is directly behind mirror. In a 2025 Tundra, you have to remove the overhead lights/glass holder compartment to get to the power. Does anybody know how many pins on that? I would rather know ahead of time before removing. Thanks for any help!
  2. May 2, 2025 at 11:13 AM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    Raven67 likes this.
  3. May 2, 2025 at 11:27 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  4. May 2, 2025 at 8:23 PM
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    I installed OEM mud flaps on my 2025 limited and have been very happy with my 33” K03s. Occasionally they come up for sale used.
  5. May 4, 2025 at 2:33 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Amazon, cheap and deadly.;) They are good.
  6. May 4, 2025 at 3:48 PM
    madonline
    madonline New Member
    2025 Tundre TRD Pro
  7. May 5, 2025 at 3:35 AM
    nodak67
    nodak67 New Member
    JR
    you can do a search and there is mudflap thread in here with pics of different kinds.
    from oem to a few aftermarkets.
  8. May 9, 2025 at 7:54 AM
    BdBoyitz
    BdBoyitz New Member
    Boyitz
    Maryland
    2025 Tundra Platinum CrewMax MGM 5.5
  9. May 9, 2025 at 9:43 AM
    bretto24
    Brett
    BdBoyitz
    Raven67 Thanks. I did purchase these but have not installed yet. Waiting on side steps and wheel well covers to be delivered so I can do all at once. Thanks for the replies.
    BdBoyitz likes this.
  10. May 31, 2025 at 1:08 PM
    osu1978
    osu1978 New Member
    I bought some Rok Blokz and installed them last night on my PRO. Seem quality and they provide 1/4" more tire clearance on my truck over the OEM which is great news for those running 35ish sized tires with a little rub. My wife's Bronco has Rek Gen mudguards which are also a nice option. They are thicker but not necessarily better than the Rok Blokz as its okay to have a little flex to deflect direct hits offroad. Rek Gens are very stiff at least on the Bronco.
  11. May 31, 2025 at 1:35 PM
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    I have a set of OEM's from my TRD Pro that just came off, needed to remove to fit 37's....
  12. May 31, 2025 at 2:05 PM
    Mossy Creek
    Mossy Creek New Member
    East Tennessee
    2024 WCP 1794
    I put Rok Blokz on my 24 Tundra. I plan to keep stock size tires and they were a little wider than I wanted, so I figured out how much I wanted to take off and put them on the table saw. A little sanding on the sawed edge and they looked like they were made that way. They protect the paint very well.
  13. May 31, 2025 at 2:47 PM
    RabidAxolotl
    RabidAxolotl New Member
    25 Lunar Rock Limited
    Much better looking than OEM flaps.
  14. May 31, 2025 at 7:58 PM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Hopefully within a couple of weeks I will know if the Rokblokz will fit with my 37. I really hope so as I drive on the job site and always get some splash. Got a wild hair and pick red Rokblokz!!
  15. Jun 7, 2025 at 7:55 PM
    Frank_TRD23
    Frank
  16. Jun 7, 2025 at 7:59 PM
    Frank_TRD23
    Frank
    Got my RB installed today. Did the front to check for rubbing. There is rubbing, that just cause my liner was cut off and is now missing to place the screw farthest inside the wheel well. Just now have to come up with some way to get a long screw to help with the rubbing and it's minor rubbing. Do wish they were better than just a Phillips ss screw. Maybe some type of torx screw.
  17. Jun 8, 2025 at 12:36 PM
    osu1978
    osu1978 New Member
    Adding some more caster should open up a little more room behind your front tires.
  18. Jun 15, 2025 at 6:24 PM
    Wraith
    Wraith New Member
    '25 Limited Crewmax
  19. Jun 15, 2025 at 8:14 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    You utilize existing factory holes, no puncturing nor drilling. But be careful to tighten the screws.
    Wraith[QUOTED] likes this.
  20. Jun 16, 2025 at 4:40 AM
    nodak67
    nodak67 New Member
    JR
    before and after oem and rekgen mudflaps
    2023 Tundra Mudflaps OEM Front 1.jpg 2023 Tundra Mudflaps Rekgen Front 1.jpg
  21. Jun 16, 2025 at 6:48 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Replaced my OEM flaps with RokBlokz after upsizing tires with some poke. Much better coverage now.
    I got the XL's and trimmed 2" from the fronts, (so basically back to the standard size) and left the rears long. Radiused the corners and deburred. Other than the logo is gone on the front ones, you can't tell that I modified them.
    Will throw some pics up later.
  22. Jun 18, 2025 at 9:31 AM
    BlackNBlu
    Rich
    MN
    Definitely a subjective statement, and I have them on my truck. I'll take big flaps over rock chips any day though.
    When you go big on tires and have any amount of poke, the stockers are puny and worthless.
    They (RokBlokz) are absolutely more functional and provide a ton of coverage.
