Creaking noise
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Idaho Purist, May 2, 2025.
  1. May 2, 2025 at 8:13 AM
    Idaho Purist
    Idaho Purist [OP] Tall
    james
    2020 Army Green TRD PRO
    Pedal Commander
    Finally souced and picked up a 2020 Army Green TRD PRO a few weeks ago and am in absolute heaven. Bone stock, two owners, non rust belt traveled and 50k miles. Definitely garaged for most of its short life. I've had two Sierra's and didnt really get this noise with those trucks.
    Not REALLY an issue... but when driving in a parking garage or backing out of the garage down the driveway there are fairly audible clicks and creaking noises coming from underneath the truck. Generally makes noise whenever theres some body flex or suspesnse is working. I'm assuming it's just the tight suspension but it's always on my mind that maybe it's something else? This normal?
    LR23 likes this.
  2. May 2, 2025 at 8:17 AM
    shadzima
    shadzima New Member
    2007 Toyota Tundra Double Cab Limited 5.7
    I have the same model and year, and it does the same thing. I was told it is the TRD skid plate. I read the solution is to add bushings or washers to the bolts on the skid plate, but I have not done this fix.
    vtl likes this.
  3. May 2, 2025 at 8:18 AM
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    I have a 21 TRD Pro and I have the same exact issue. From searching online I believe it's the skid plate rubbing in most cases. There are Youtube videos that record it pretty well. The last time I took mine in for routine service I mentioned it and they said they tightened a couple bolts on the skid plate and it seemed to help for a month or so, but then started up again. I have another service coming up soon so I'm going to ask about it again and hopefully they can figure out something to fix it long term. I'm not overly concerned about it, but it is annoying.
  4. May 2, 2025 at 8:18 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The skid plate it is.
  5. May 2, 2025 at 8:19 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    It is very likely the skid plate. They are very sensitive to the torque applied to the hardware.
    Get under there and torque the hardware to spec and it will likely go away.
    I would bet that the PO had removed the skid at some point.
  6. May 2, 2025 at 8:26 AM
    Idaho Purist
    james
    Pedal Commander
    Very interesting - had not thought about that piece. I haven't looked yet (its probably very easy to find), but since this thread is getting good traffic right now - what's the torque for the skid plate bolts? Does the owners manual contain torque ratings (doubtful but some do)?
  7. May 2, 2025 at 8:34 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    You may need to add a rubber washer or grommet of sorts between the skid and crossmember it's riding on to eliminate the noise. I've not experienced it in my, but from a bunch of other posts here.... that's more than likely your source of noise!!!
    Here's a bulletin that was sent out to Toyota's techs which has the various torque settings of the bolts involved....
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10181744-9999.pdf
    PS>>> Congrats on the new rig!!!
  8. May 2, 2025 at 8:40 AM
    Idaho Purist
    james
    Pedal Commander
    :hearteyes: Beautiful. Exactly what I would look for, thank you for the quick response and the perfect file.
  9. May 2, 2025 at 8:41 AM
    Tripleconpanna
    :hattip:
  10. May 2, 2025 at 9:01 AM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    I had the skid plate noise with my '21 Pro. I recall initially reading a few threads and I recall a number of options for eliminating the noise weather rubber washers, grommets, etc. I believe for my issue, the tech pulled the skid plate off and put some sort of weather stripping type material in the contact points and I haven't had an issue since. Here's an old thread I had bookmarked that might provide some information -
    https://www.tundras.com/threads/tundra-trd-pro-skid-plate-noise.53618/
  11. May 2, 2025 at 9:27 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Skid plate. If you use proper torque specs it will most likely go away. If not then soft bushings will for sure do it.
  12. May 2, 2025 at 10:11 AM
    Idaho Purist
    james
    Pedal Commander
    I have a bunch of random pieces from other car projects I have, I'll make something work. Looking forward to fixing this though as it turns heads when I'm driving - not in the good head turn kind of way either. They should be turning their heads, yelling GREEN! and closing their eyes to enjoy that pleasurable 5.7 growl.
  13. May 2, 2025 at 10:16 AM
    baron
    baron New Member
    Brett
    2021 TRD Pro
    As mentioned, it's the skid plate. I had mine "fixed" by Toyota only for the sound to return then I added rubber washers and the sound eventually came back. I pulled the plate off and made rubber gaskets for every area that has metal on metal contact. All noises gone. If you pull the skid plate, you'll easily see the witness marks.
  14. May 2, 2025 at 10:18 AM
    Idaho Purist
    james
    Pedal Commander
    When you added rubber gaskets - did you torque back to factory? I notice most times I add a gasket to things i tend to freaking annihilate it when i go to torque. I'll probably make a few extras in anticipation.
  15. May 2, 2025 at 10:23 AM
    baron
    baron New Member
    Brett
    2021 TRD Pro
    I did, but my recollection is the torque spec was pretty low. Just looked - I used 1/8" thick 65A rubber. It's durable stuff.
  16. May 2, 2025 at 12:43 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    ATV25 likes this.
  17. May 2, 2025 at 12:55 PM
    Idaho Purist
    james
    Pedal Commander
    i was in the middle of buying coffee filters from Amazon when i saw your message. added to the cart.
  18. May 4, 2025 at 4:46 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    I tried the new rubber bushings approach via the dealership as there is a TTB (or whatever the abbreviation is) and it worked for a minute - now I just use a good lubricant where my cat protectors and skid plate converge…
    good luck!
  19. May 8, 2025 at 7:52 PM
    Bran
    Bran New Member
    2020 Tundra TRD Pro
    I also have a 2020 TRD Pro and it has the same issue. I'm going to try that rubber cp44 mentioned.
  20. May 18, 2025 at 9:40 PM
    voodoobloo
    voodoobloo New Member
    What sort of lubricant are you using?
  21. May 19, 2025 at 8:00 AM
    TL TRDPro LR
    Troy
    SoCal/Idaho
