PML Transmission Pan
Discussion in '2nd Gen Tundras (2007-2013)' started by cdub61, May 2, 2025.
  1. May 2, 2025 at 5:16 AM
    cdub61
    cdub61 [OP] New Member
    2007 Blue Tundra SR5 TRD 4.7L
    I just installed a new PML transmission pan on my 07 4.7L with the A750F transmission. Install was easy. It now holds 2 extra quarts of WS ATF. At 210000 miles the transmission is butter smooth and runs about 10 degrees cooler. And as a bonus, refill is now through the check hole. While expensive at $400.00, well worth it.
    https://yourcovers.com/pml-toyota-a750e-a750f-deep-transmission-pan.html.
    Black Wolf likes this.
  2. May 2, 2025 at 7:43 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not sure about refill through the check as it still needs to be at that level or a little bit higher. I'd be cautious using aftermarket filters that don't have a stock style pickup. We still fill and check as per the stock pan.
    A few of us on the supercharger thread have them and like them. Cruisers and Company has them for $355 and built valve bodies too.
    bflooks and reywcms like this.
