BILSTEIN vs EIBACH for the 2022 Tundra!!
Discussion in 'Suspension' started by offshore2005, Apr 26, 2025.
  1. Apr 26, 2025 at 6:56 PM
    offshore2005
    offshore2005 [OP] New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    I’m looking for some real-world feedback between these two brands. I had Bilsteins on my 2018 and really liked them, but I’ve been hearing a lot of good things about Eibach lately. Right now, I have a 1.75” Rough Country leveling kit installed, but I’m planning to take it off and replace it with either Bilstein or Eibach.
    Paul499 likes this.
  2. Apr 27, 2025 at 2:39 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Have eibach pro truck kit for few months now. Very happy with it as it irons out all of the potholes on the roads. If I go faster it makes speed bumps disappear.
    I heard that bilstein is a bit firmer ride than eibach which means it should improve handling little bit more. Maybe
    offshore2005[OP] likes this.
  3. May 1, 2025 at 6:05 PM
    offshore2005
    TEXAS
    What setting did your set yours at and do you have a photo?
  4. May 1, 2025 at 9:47 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I told the shop to make the height as low as possible as I need to drive into the garage. They recommended to lower it all the way and then go up one or two turns so the struts won't bottom out if hit any larger bumps... That's what they did and it's working very well for me. Rear aren't adjustable.
  5. May 1, 2025 at 10:18 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    go with eibach’s if you want everyday comfort ride quality
