toyota 10.5'' differential
Discussion in 'Towing & Hauling' started by sabito29, May 1, 2025.
  1. May 1, 2025 at 5:32 PM
    sabito29
    sabito29 [OP] New Member
    anthony
    toyota hilux 1985 2wd 22r
    I want to get out of some didactic doubts, I don't know how many generations there are or is it the same but the drought and tundra some come with a 10.5 differential this is hard but not as resistant at the ends, maximum 2000 pounds and some series 70 come with a 9.5 floating differential but they resist according to the Toyota 2900 pounds, my personal opinion they resist without forcing it between 2900 and 3100, how many pounds could a 10.5 '' move by modifying its ends and some other improvement? What size is the Toyota Coaster annular gear? I searched and searched, I found its tooth pitch only, no sizes and through other research I found that its maximum weight would be 4000 pounds, it is floating. The Dana 70s are 10.5 and easily move at least double that, 8,000 pounds. My idea for a Toyota Coaster differential would be to compare it in size to a Dana 70, but according to Toyota, it would only be 4,000 pounds, and I'm missing another 4,000.
    ? So, should the ring gear be smaller, or not? A 10.5 Tundra with floating axles should easily move 10,000 pounds, obviously with a good engine that can move that weight. What I'm trying to get at with this is that I'm doing a study on the maximum weights supported without the material suffering too much and its cost being feasible, and I'm interested in Toyota mechanics.
  2. May 1, 2025 at 6:23 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Not entirely following everything you said. But the Toyota 10.5 AXLE is semi float, most certainly the limiting factor in what the axle can handle. This is why even though the diff is the same size or larger than many higher rated vehicles, the axle is not rated as high. If you're not aware (and if you are skip this part) a semi float axle has the axle shaft taking all the shear load (weight of the vehicle) as well as transmitting torque to the tire. A full float axle, which is what a Dana 60,70,80, and many others have, has a duplex bearing pair at the hub so the hub entirely reacts the shear and bending moment from the tire and weight of the vehicle. The axle shaft is "floating" meaning it's only transmitting torque to the hub and does not see any other loads. Because the Toyota axle is semi float, the axle shaft is multi-tasking and reacting all loads and is why the axle is rated at less capability.
    The DIFFERENTIAL however is a totally different story. I'm not sure of the specifics besides it's a 36 spline output so pretty good sized. The differential (3rd member) could be swapped into something else, like a custom housing, which is full float. That would be the strongest option and best of multiple worlds: you get a large differential, large output splines, a removable 3rd member, full float, etc. and many dedicated offroad vehicles do this. You can buy a housing from Front Range Off-road (called a Diamond Axle) that is custom built to what you want and will use a Toyota 10.5 differential.
    The Land Cruiser axles sometimes are or are not full float, depending on the model and year. For example a 91-94 80 series is semi float, but 95-97 is full float and because of that is much more desirable and capable even though it's the same 9.5" differential. Not sure if that answers any of your questions...
    des2mtn, equin, Avi8or and 6 others like this.
  3. May 1, 2025 at 6:36 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Now can we make that fabbed axle etc work with the abs/tone ring to maintain functional 4wheel drive lol
  4. May 1, 2025 at 8:06 PM
    blenton
    blenton New Member
    I seem to recall Front Range Off-road offering a full floater conversion kit. They have offerings for some of the smaller Toyota axles but didn’t/don’t show the 10.5 even when they offered it. I emailed them a couple of years ago about it; I think they retain everything. Might have to fire off another email. If they offer the kit or are willing to make a production run, I smell a group buy..
    reywcms[QUOTED] likes this.
  5. May 1, 2025 at 9:13 PM
    I'm not totally sure "why" you would want to do all this work for a vehicle that still can't carry this load.
    When people bring up Land Cruisers like the Series 70 trucks, a lot of those were rated at 1.25 ton vehicles...which is rather impressive.
    Corndog123 likes this.
  6. May 1, 2025 at 9:35 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I emailed them awhile back never heard back. I’m sure spidertrax could make something
  7. May 2, 2025 at 2:58 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
  8. May 2, 2025 at 3:22 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    91-92 were semi float, 93-97 were full float for the 80 series
  9. May 2, 2025 at 5:15 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    According to a Hino employee (they manufacture the axle), the actual design GAWR for the 10.5” axle is about 5500 lbs. For anyone that has disassembled one of these, it’s fairly easy to surmise, based on component size, that the supplied number is well within the realm of what it can carry.
    Coasters have a similar 10.5” differential (same diff to housing gasket), but the axle spline count is different. Coasters with the 10.5” are rated for a max gross vehicle weight of over 12000lbs. They have very heavy FF housings and big hubs.
  10. May 3, 2025 at 11:23 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Curious who Randy Slawson gets his axles from. Assuming Spidertrax. If I remember correctly, he was using Tundra-based axles in his play buggy a few years ago. Might look him up at Bomber Fabrication.
  11. May 4, 2025 at 6:25 AM
    snivilous
    SW UT
    A thread I saw not too long ago said he was running a Diamond housing when he was using the Tundra third.
    reywcms likes this.
  12. May 4, 2025 at 10:56 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Interesting. Figured he’d be all Spidertrax since that’s what they’re peddling. Nothing wrong with Diamond, just didn’t see that coming!
    Sorry for the hijack. Back to our regularly scheduled program.
    snivilous[QUOTED] likes this.
  13. May 4, 2025 at 10:59 AM
    snivilous
    SW UT
    Yea not sure the whole story, there were people talking about his diff failure this year and how when he was running the Tundra diff he didn't seem to have any issues before, and speculation why his axle setup has changed since then. If I remember I can ask him next weekend since I'll be codriving for his wife in Moab :D
    Chad D.[QUOTED] likes this.
  14. May 4, 2025 at 11:30 AM
    Js18tundra
    I’m waiting for a vender to make a ff kit for our trucks, I would buy it in a heartbeat.
  15. May 9, 2025 at 6:58 AM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Do you happen to recall the reference to this? Just curious.
  16. May 9, 2025 at 7:18 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Not much, unfortunately. It was on one of the other forums over 15 years ago. Someone had a family member that was employed by Hino.
  17. Jun 13, 2025 at 5:02 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Newby question here, what's a "coaster"? I figured we're not talking about the thing you put under cups......
  18. Jun 13, 2025 at 5:12 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
  19. Jun 13, 2025 at 5:18 AM
    Corndog123
    Sam
    Tennessee
    Oh no kidding? Oh wow. Man, if Yota can make this I still don't see why they can't make a HD TUNDRA. Oh well. Maybe someday. Lol
    Thank you for answering my question. :thumbsup:
    Jowett[QUOTED] likes this.
