Siziom tow mirrors
Discussion in 'Electrical' started by Nbab23, May 1, 2025.
  1. May 1, 2025 at 11:45 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I picked up a really cheap set of brand new Siziom tow mirrors on MacBid at a ridiculously low price. Figured I’d give em a try and if they were garbage no big deal. They’re actually pretty decent and plug and play for the most part. The only issue is each mirror came with a long grey and white wire. I assumed it was similar to the boost auto mirrors, white was reverse and grey(blue for boost) was for running lights. I T tap’d the reverse wire on the driver side kick panel. Hooked in the white wires and no dice. Switched out for the grey to see and no luck there either. Anyone use these or similar lights before? Am I missing something?
  2. May 1, 2025 at 12:04 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Could it be the grey wires are a ground?
  3. May 1, 2025 at 12:09 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  4. May 1, 2025 at 12:57 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I did look in this post but didn’t see anything that quite fit since the conversation was more so surrounding connecting it to the cardio light. I’ll double check though.
  5. May 1, 2025 at 3:29 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Grey was ground! Decided I’d just give it a shot and hooked up the grey wires to a ground source and the reverse lights worked. At least this is here if anyone else runs into this problem down the road.
