Phoenix Android Radio HU for 2014-2021 Tundra Demo - Teams call Friday 11/29/24 11am EST
Discussion in 'Audio & Video' started by Cthulhu, Nov 24, 2024.
  1. Apr 30, 2025 at 7:28 PM
    PadreMC
    PadreMC New Member
    2021 Tundra 4x4 Limited CrewMax Nightshade Edition MGM
    Yes, the reset is on the little center cluster window, but there are maintenance messages on the head unit. You can also adjust various settings such as door lock settings, headlight settings (auto on sensitivity, auto off timer, DRLs on/off), interior light settings auto/off. Not much but would like to know if I can still get to those.
    Cthulhu[OP] likes this.
  2. Apr 30, 2025 at 7:57 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Ahh yeah, totally forgot about those settings
  3. Apr 30, 2025 at 9:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    yes and no...
    it WILL cause your instrument cluster page for navigation to be blank. And, depending on your replacement HU, it may not show as much information in the page for music.
    As for all of the random maintenance things that you can enter (and set reminders) in the factory HU - those are part of the HU and are not maintained by this android HU (or by any Maestro-compatible units either).
    The basic door lock and light settings should be maintained though.
  4. May 1, 2025 at 4:01 AM
    Cthulhu
    Cthulhu [OP] The White and Black Goat of the Woods
    Gotcha, still not sure about the maintenance, but YES to all of the above I quoted, there is a screen that addresses them. I'll send you a screenshot later today. :thumbsup:
    bulldog93 likes this.
  5. May 1, 2025 at 6:24 AM
    Cthulhu
    Here you go, lots of scrolling through the options, so multiple screenshots:
  6. May 1, 2025 at 6:55 AM
    PadreMC
    PadreMC New Member
    I'd say that definitely covers it and then some. Thanks for taking the time to upload those screenshots.
  7. May 1, 2025 at 7:29 AM
    Cthulhu
    No problem. Full disclosure, I’m a nerd and not skeered of tinkering with tech settings, and as others have mentioned, you have to hunt some for all the various options. If you’re looking for something highly intuitive, this might not be your jam. It helps to be familiar with the Android interface. :thumbsup:
  8. May 1, 2025 at 7:51 AM
    PadreMC
    PadreMC New Member
    No worries there. Very familiar with Android as it's been my daily driver for years in its many iterations. I appreciate the advice.
  9. May 1, 2025 at 9:23 AM
    Hazman23
    Hazman23 New Member
    Northern Ca
    2017 Tundra
    Does this unit also perform the temperature control as well? Looks as though the HU covers the stock temp and fan knobs. Thanks!!
  10. May 1, 2025 at 1:37 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    It does perform all of the controls below the factory HU. The factory HVAC piece comes out.
    Hazman23[QUOTED] likes this.
  11. May 1, 2025 at 1:56 PM
    PadreMC
    PadreMC New Member
    I think @Hazman23 might be asking if the Phoenix HU managers dual zone climate control vs the standard temp and fan speed knobs depending on which option came with a particular Tundra trim.
  12. May 1, 2025 at 2:00 PM
    Hazman23
    Hazman23 New Member
    Northern Ca
    2017 Tundra
    I don't have the dual zone climate. This looks like a pretty slick set up!!!
  13. May 1, 2025 at 3:45 PM
    PadreMC
    PadreMC New Member
    @Cthulhu, do you prefer to use the radio with car play/android auto connected to your phone or the radio as a standalone device?
  14. May 1, 2025 at 3:52 PM
    Cthulhu
    Yes, climate control is handled by the HU, regardless of trim level. So if you have dual climate zones, you’ll have dual climate zones on this HU. Some don’t like the fact that you remove the factory HVAC knobs; perfectly fine for me. :thumbsup:
  15. May 1, 2025 at 3:55 PM
    Cthulhu
    I definitely use wireless CarPlay, and run Waze on the HU.
  16. May 1, 2025 at 4:02 PM
    PadreMC
    PadreMC New Member
    Ok, just a couple more questions, and I think I'm covered. Did you add a SIM, and is there any loss in audio quality going from stock to this HU?
  17. May 1, 2025 at 4:22 PM
    Cthulhu
    No SIM.
    Regarding audio quality, plenty of adjustment options, including an equalizer, and, this HU allows you to adjust the gain to the factory JBL amp, which is is awesome since the factory HU has no gain control, and weak max volume from the factory JBL amp. It makes the factory JBL amp come alive with more volume, and even though the factory speakers aren’t high quality, they sound better with more volume. You just don’t want to add too much gain as it will introduce distortion which can damage the speakers. I imagine the ability to adjust the gain would be beneficial with the factory non-JBL amp as well.
  18. May 1, 2025 at 4:36 PM
    PadreMC
    PadreMC New Member
    I've got the non-JBL so hopefully there is improvement there as well like you indicated with the JBL. Thanks again for all the info. Greatly appreciated.
