Added 37s. Truck only runs at full lock on the sway bar
Discussion in '3rd Gen Tundras (2022+)' started by WrapCO, Mar 3, 2024.
  1. Mar 3, 2024 at 2:45 PM
    WrapCO
    WrapCO [OP] New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    So I just installed 37s on 17” Methods with +25mm offset. Currently only runs at full lock on the sway bar. So what are my options to eliminate?!
    Thinking either remove the sway bar or swap for 1/4” wheel spacers.
    For those running 37s without rubbing… what’s your offset?
  2. Mar 3, 2024 at 5:49 PM
    Hella Krusty
    Hella Krusty New Member
    No answer for your question....but would love a picture of it!
  3. Mar 3, 2024 at 5:50 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    I’ve got the same setup. I also rubbed my sway bar. I pulled the bar off and it drives fantastic.
    WrapCO[QUOTED][OP] likes this.
  4. Mar 3, 2024 at 6:03 PM
    WrapCO
    Eagle , CO
    1/4” spacer is out of the question as of right now.
  5. Mar 3, 2024 at 6:20 PM
    TT YOTA
    TT YOTA New Member
    Shane
    Phx az
    2022 tundra sr5
    Trd pro bbs wheels Trd pro fox shocks Wescott level kit
    Really digging the wrap that's definitely something I do to my tundra!
  6. Mar 3, 2024 at 6:33 PM
    WrapCO
    Eagle , CO
    Thanks! :yay:
  7. Mar 3, 2024 at 9:35 PM
    Hella Krusty
    Those look great. Well Done!!
  8. Mar 4, 2024 at 5:08 AM
    WrapCO
    Eagle , CO
    How’s it drive at 90mph (on the speedo) on windy roads? Asking for a friend. :cool:
    Jackstraw likes this.
  9. Mar 4, 2024 at 5:28 AM
    WrapCO
    Eagle , CO
    Come on now, you can afford 37s and a 3" lift, I KNOW you can afford to get 8mpg.....
    I'm going to test this for sure. The 37s alone, especially on 17s, make for much more roll in corners than the 35's w/ 0 offset. It'd do me a service to have to slow down.
  10. Mar 5, 2024 at 4:34 AM
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    I run 37” with Kings 3.0 at 1.5” of lift
    Methods +35 offset. No rubbing at all.
  11. Mar 5, 2024 at 4:57 AM
    WrapCO
    Eagle , CO
    I’m thinking that 1.5” of lift has something to do with it.
  12. Apr 25, 2025 at 5:25 AM
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    17x8.5 or 17x9?
  13. Apr 25, 2025 at 9:27 AM
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    Share some pics of this setup! Thanks
  14. Apr 25, 2025 at 10:27 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Tack weld something to the steering stop on the LCA?
  15. Apr 25, 2025 at 4:36 PM
    virgilus11
  16. Apr 30, 2025 at 5:12 PM
    virgilus11
    chrisgibbs707 likes this.
