RSI Smart Cap
Discussion in 'Tonneau Covers, Caps and Shells' started by cook2kill, Nov 20, 2020.
  1. Apr 6, 2025 at 6:16 AM
    #451
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    RSI does not give discounts
  2. Apr 6, 2025 at 9:01 AM
    #452
    Mike's Custom Toys
    Mike's Custom Toys New Member
    We don't have tax and offer free shipping if that helps.
    OHwendTrd likes this.
  3. Apr 8, 2025 at 3:29 AM
    #453
    Kralln46
    Kralln46 New Member
    Nate
    2025 Metallic Gray Tundra Limited TRDOF
    I installed my smart cap about 5 or 6 weeks ago. Assembled myself and had 3 friends help me lift it in place. Overall a easy install process. I've only put a few hundred miles on since then as I have a work truck and never put a lot of mile on my personal truck. After about 100 miles I went over all bolts and torqued again to spec. Over all I am very pleased. Built tough and looks great. Yesterday we had rain all day and when I got gome from work I checked out the inside. Not flooded but more leaks then I'd like. As mentioned in previous posts, I had to trim the gasket for the auto tailgate to work. No leaks there. Main leaks I'm concerned with are the slide window in the side doors seems to leak. I found water droplets on some of the bolts for the vent plate. However the filter for dust was dry. Lastly, the seam between the front panel and the 3 roof panels leaks. The roof panel seams and rear panel seam all are good. My thinking is loosen the vent bills and add some silicone around them to seal. As for the front panel leak, bead of silicone across the top of the seam to seal? I use rtv sealant often for refrigerator repairs at work. Not sure how this would hold up to heat and outdoor elements though. Any recommendations on silicone that is black so it blends in better and will be durable? Any recommendations on the slide window leaks? Overall I really like this cap and just wanna work the small leaks out. 20250308_115754.jpg
    Taikowaza likes this.
  4. Apr 10, 2025 at 2:45 PM
    #454
    gesekee19
    gesekee19 New Member
    I see RSI has two widths for load bars. Is it the 55” or 48”. Taking delivery soon and trying to get load bars soon.
  5. Apr 10, 2025 at 3:37 PM
    #455
    Mike's Custom Toys
  6. Apr 10, 2025 at 4:03 PM
    #456
    gesekee19
  7. Apr 10, 2025 at 4:18 PM
    #457
    Mike's Custom Toys
    Just checked and we are out of that length but I can ship a set to you straight from front runner. Free shipping with code: SHIPPY250
  8. Apr 10, 2025 at 7:50 PM
    #458
    gesekee19
    cool I’ll take a look. Thanks!
  9. Apr 24, 2025 at 8:02 PM
    #459
    RITundra
    RITundra New Member
    Thursday
    Anyone have weird gasket overlap with the 3 piece roof?
    I just got an evo sport 5.5 ft bed and the center roof panel has gaskets on the sides that also wrap around the ends.
    The smaller side roof panels have gaskets at the sides that mate with the center panel but these are only at the ends of the panel and also wrap around the corners.This looks like it will create a gap even when everything is tightened down.
    Also none of the images or videos look the way this does.
    Thanks!
  10. Apr 25, 2025 at 12:34 PM
    #460
    Mike's Custom Toys
    As long as the gaskets don't end at a connector it will be fine.
  11. Apr 25, 2025 at 1:07 PM
    #461
    RITundra
    RITundra New Member
    Thursday
    Thanks.
    Do you mean like this?
    This is on the tailgate side.
  12. Apr 25, 2025 at 4:14 PM
    #462
    Mike's Custom Toys
    Exactly. That looks good.
  13. Apr 25, 2025 at 4:23 PM
    #463
    RITundra
    RITundra New Member
    Thursday
    Great!
    Thanks. None of the instructions or videos show no gasket on those parts.
  14. Apr 30, 2025 at 2:45 PM
    #464
    Mike's Custom Toys
  15. Apr 30, 2025 at 3:25 PM
    #465
    gesekee19
    I had my smartcap installed by GTFOverland. I was in a hurry and left after install but the rear camera glass was just touching, causing a creaking noise. When I had time, I loosened the clamps and shifted it away by maybe a cm or two and now it’s good. I tried following the instructions to fasten the clamps to 9lbs per feet but my torque wrench isn’t clicking and keeps spinning. Picked up another and the same. Anyone have a picture? How far out is the bolt protruding? Flush? Dont feel like driving back to the shop and don’t feel like picking up a digital gauge.
