Home Depot DIY Carrier Bearing Spacer?
Discussion in 'Suspension' started by FREEK, Mar 28, 2025.
  1. Mar 28, 2025 at 3:37 PM
    FREEK
    FREEK [OP] New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    Hey all,
    After a 3” rear lift I have a minor dreaded shudder upon accelerating from a stop.
    Many guys mentioned buying spacers from Home Depot, does anyone know what exactly I am looking for???
    I CERTAINLY don’t need this conversation:
    “Hi there. Finding everything you need today, sir?”
    “Uhhhh nope.”
    “What is it you’re looking for”
    “uhhh Carrier Bearing Drop Spacers for a 3” lift on a 2019 Tundra.”
    “Oh, yeah right. Try aisle 33 in Seasonal, next to the closeout Christmas trees and Quik-Mix cement”
    Red&03Taco likes this.
  2. Apr 30, 2025 at 9:31 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    lol i dont know how i ended here but just buy some thick nuts and use them as spacers for each side of the bolt. so the stack sequence would be something like factory threaded hole, 3-4 nuts as spacers on each side, carrier bearing ears/flaps, your bolt going through everything. hope this helps you visualize it.
