  1. Apr 29, 2025 at 11:12 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Correct, I spent a few hours researching, and dismantling my truck only to find that there was no hole in the reservoir, nor wiring for a sensor.
    The wiring didn't appear to be there for me, but that was a V6 example. V8's may have it. I damn sure haven't had time to dismantle crackie the way I did ole beaut.
    First link i found
    https://www.tundras.com/threads/warning-lights.115362/#post-2968347
    Gah damn, 2020
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-241#post-1880407
    Bingo, God damn what a long time ago it feels like
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-241#post-1880503
    shifty`[QUOTED] likes this.
  2. Apr 29, 2025 at 11:14 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    That looks solidly built, and can always add more to stack on top (hence their cleverly appropriate name I see).
    I just found this Plano--its currently out of stock but was still able to order and it'll be shipped as soon as it comes back in. Only $35 for this color and style variation. Seems like a hell of a buy especially for the 108qt with hinges and wheels.
    https://www.amazon.com/dp/B00TY4AMZQ
  3. Apr 29, 2025 at 11:19 AM
    I've got one of these. Sturdy despite it's lighter construction. Makes a great portable hunting chest.
    Dblock500[QUOTED] likes this.
  4. Apr 29, 2025 at 11:39 AM
    Hot damn, my brain worked again. Hard to believe that was near 5 years ago now. We been on here too long, man.
    Plano was my go-to for tackle boxes since forever, ever since I saw Bill Dance using Plano as a kid. But I gotta say, the quality of some of their products seems like it's declined in the last decade or two.
    I downsized a lot of my gear back around 2006-2008* and picked up a new dual-sized clear Plano tackle box and I know it was legit, I bought it in person at BPS. Damn interiors are warped, the cover doesn't shut right because it's warped... really a bummer. Largemouth is my normal go-to, and I'll say, at least my Culprit soft baits haven't managed to melt or warp the clear side covers, but I learned to keep most of them still in the bag many moons ago after other mishaps.
    I have one of these things right now, Plano 1373, was using it for small parts in our lab at work, before I had to close the site. Pretty flimsy also. The front door was the first to break off. I ended up harvesting the bins for misc bike parts. I currently have the carcass sitting behind me as I type.
    I've lost faith in their products at this point.
  5. Apr 29, 2025 at 1:57 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've heard this stuff can ruin washer fluid sensors. It'll also stain the washer fluid tanks. Second one isn't a big deal but I always worry about the first thing, even though I'm sure it's not very common.
  6. Apr 29, 2025 at 3:05 PM
    Dakillacore
    Georgia
    I've never had a problem or heard of that issue. I've been running it for years in multiple cars, even in my 98 Camry. The sensors still worked fine.
    NickB_01TRD[QUOTED] and MooreKen like this.
  7. Apr 30, 2025 at 2:18 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Update: I ordered mid day last Monday and UPS has my suspension arriving tomorrow. (It might even be here today). I’d say that’s fast turn around time for pre-assembled and I’m quite pleased. Josh had lot’s of good reviews from you guys and just add me to the list of thumbs up.
    oscardog86, bmf4069 and Dblock500 like this.
  8. Apr 30, 2025 at 3:25 AM
    Dblock500
    DMV
    Yeah I noticed some mixed reviews on durability, and a couple others here
    Contemplating doing the same, or 6112 up front with 5100 rears. My original coil springs are rusted up in the front fairly badly. Also getting vibration at 60mph and when letting off the gas i get a rumble before it stops. Just got a new alignment and balance. Brakes , rotors, and calipers all look ok too
    MooreKen[QUOTED] likes this.
  9. Apr 30, 2025 at 4:50 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I used to be a rain x guy, but now after ceramic coat it doesn’t even matter what I put the water doesn’t stick. Bug guts and bird shit still sticks but that ceramic coating is slickernshit
    bmf4069 and Dakillacore[QUOTED] like this.
  10. Apr 30, 2025 at 6:21 AM
    What’s that? My truck never came with a working one since new. Then again, I didn’t know it existed until 15 years later.
  11. Apr 30, 2025 at 6:51 AM
    Do this, do this!!
    6112 comes with springs, just need to either swap over your OEM top hats and isolators or buy a new set from KYB, so you can assemble outside the truck and make it a bolt-up experience.
    6112 has a fatter body than the 5100s, and should have all the adjustability you need to dial-out any Tundra Lean.
    bmf4069 and Dblock500[QUOTED] like this.
  12. Apr 30, 2025 at 7:56 AM
    Dblock500
    DMV
    Welp, I'm sold--would probably only want to do a 1" lift. Is a lift required for the 13wl brake upgrade?
    bmf4069 and oscardog86 like this.
  13. Apr 30, 2025 at 8:01 AM
    oscardog86
    oscardog86 New Member
    Southern California
    I dont think a lift makes a difference on the brake upgrade. Just a matter of your wheels clearing the bigger calipers and you might have to just trim the dust shield on the brake. I needed to just notch a little piece out to make the bigger calipers fit for my brakes
    Also, I have the 6112s up front and really like them. There really isnt any other shock that gives such a wide body for the price. Good bang for the buck for sure
    805Tundra and KNABORES like this.
  14. Apr 30, 2025 at 8:04 AM
    Dblock500
    DMV
    True, I have 16s--typically 13wl only fits 17's and up (without any trimming)?
  15. Apr 30, 2025 at 8:06 AM
    oscardog86
    Southern California
    I have 16s as well with the 13WL. Fits just fine but like i said, a little trimming on that dust shield.
    shifty` and Dblock500[QUOTED] like this.
  16. Apr 30, 2025 at 8:19 AM
    I have 16s with 13WLs as well. Dust shield trimming was all that was required to fit them. A few select 16" wheels will not clear them, most seem to.
    shifty`, Dblock500 and oscardog86 like this.
  17. Apr 30, 2025 at 8:21 AM
    NickB_01TRD
    KY
    Mine has the light present on the dash but I'm really good about keeping my washer fluid topped off in all my vehicles, so I'm not sure which ones the light works on anyway.
  18. Apr 30, 2025 at 8:37 AM
    Dblock500
    DMV
    Good to know, thank you.
    oscardog86[QUOTED] likes this.
  19. Apr 30, 2025 at 8:38 AM
    oscardog86
    Southern California
    Also, Ive had 4 different 16s on my truck since the 13WL upgrade and all have worked. Like @KNABORES said, most 16 wheels will probably clear the calipers
  20. Apr 30, 2025 at 8:40 AM
    All aftermarket, all OEM, mix of both? Just curious. Seems like the complaints with fitment were mainly from OEM, taken from non-Tundras
  21. Apr 30, 2025 at 8:44 AM
    oscardog86
    Southern California
    3 aftermarket 1 original factory steelies
  22. Apr 30, 2025 at 8:47 AM
    Ok, so we have confirmation now that both the Starfish and the OEM steelies (I expect all steel wheels will clear) work. I think there's only one other 16" wheel, alloy, that came with our trucks?
  23. Apr 30, 2025 at 8:52 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Just a side note on this, only1/8oz and 1/4oz static wheel weights on the 16s will clear the WL calipers. 1/2oz static will rub
  24. Apr 30, 2025 at 9:08 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Man I wish these would fit..
  25. Apr 30, 2025 at 9:09 AM
    oscardog86
    Southern California
    What size is that one?
  26. Apr 30, 2025 at 9:10 AM
    They do. In some situations....
  27. Apr 30, 2025 at 9:28 AM
    As long as you only drive straight they will be fine.
    BroHon, 805Tundra, bmf4069 and 3 others like this.
  28. Apr 30, 2025 at 9:30 AM
    And avoid potholes. Which will be tough if you can't turn the wheel to dodge them.
  29. Apr 30, 2025 at 10:04 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Balancing bead gang
    bmf4069 and KNABORES like this.
  30. Apr 30, 2025 at 10:05 AM
    Any experience with them? I hear mixed reviews for passenger car applications. Truckers love em.
    des2mtn[QUOTED] likes this.
