P2119 code...any ideas, thoughts, suggestions?
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Apr 27, 2025.
  1. Apr 27, 2025 at 1:35 PM
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    130k on the odo
    CEL
    P2119 code
    Is this part of the engine failure/recall? Or a separate issue?
    Does the new crate motor come with new throttle body or do they reuse the old one?
    Thanks yall
  2. Apr 27, 2025 at 1:44 PM
    Observer
    Observer New Member
    From what I can glean from searches the 35A replacement does not come with a new throttle body.
    Blufin likes this.
  3. Apr 27, 2025 at 2:38 PM
    Linesman
    Linesman New Member
    2023 Smoke Mesquite Tundra Double Cab limited
  4. Apr 27, 2025 at 2:56 PM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Here's what I found,and by you having 130K on the clock I'd say this may be accurate.
    P2119 - Throttle Actuator Control Throttle
    Body Range/Performance
    This means the Engine Control Module
    (ECM) has detected that the throttle
    actuator is not operating within the
    expected range. More specifically, it
    suggests a problem with the electronic
    throttle control system=possibly the
    throtle body, throtle position sensor, or the
    actuator motor
    Common Causes:
    • Carbon buildup in the throttle body
    s Faulty throttle body assembly
    • Faulty throttle position sensor
    • Wiring issues or poor electrical
    connections
    • Failed ECM (less common)
  5. Apr 27, 2025 at 3:13 PM
    Observer
    Observer New Member
  6. Apr 28, 2025 at 4:08 AM
    Oregona
    2022 TRD OR
    Nada
    Thanks for this....good info
    Do yall think rodents could cause this problem?
  7. Apr 28, 2025 at 4:17 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Rodents didn't put 130k on the truck...hopefully a good cleaning and reset will do the trick. Possible but not probable.
    Blufin and 389 24/7[OP] like this.
  8. Apr 28, 2025 at 5:36 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Only you can answer this,and I agreed with Jettster, the throttle assembly just needs a good dooshing.
  9. Apr 29, 2025 at 2:33 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    by any chance did you recently disconnect your battery?
  10. Apr 29, 2025 at 5:19 PM
    Oregona
    2022 TRD OR
    Nada
    Nope
