93 octane impressions
Discussion in '3rd Gen Tundras (2022+)' started by ARB1977, Apr 29, 2025 at 5:06 PM.
  1. Apr 29, 2025 at 5:06 PM
    ARB1977
    ARB1977 [OP] New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Is it just me or is my truck really driving better? I just filled up today and I know it’s going to take a few tanks but it seems more responsive. It ran fine on 87 top tier…at least I thought. I was getting 19-20 consistently. Highest trip average was 24.5. Maybe I won’t see much or no change in mpgs on 93.
    Metro14536 and Corndog123 like this.
  2. Apr 29, 2025 at 5:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Toyota says the truck can run on 87. They never said it runs optimally using 87. The ecu just pulls timing to prevent knock. But that’s not going to provide optimal power that comes with higher timing tables using 93. Even in my 5.7, the truck runs noticeably smoother with less hesitation with 93 than lower octanes.
  3. Apr 29, 2025 at 5:15 PM
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Not me. But the difference you're seeing might be related to seasonal gas blend changes.
    savage24x and Corndog123 like this.
  4. Apr 29, 2025 at 5:23 PM
    ARB1977
    Anthony
    DFW
    Glad it’s not in my head, lol.
    Corndog123 likes this.
  5. Apr 29, 2025 at 5:25 PM
    ARB1977
    Anthony
    DFW
    Where in the summer blends across the board. Granted it’s 80 cents more per gallon and considering I have the 23 gallon tank. It’s not terrible as far as cost goes.
  6. Apr 29, 2025 at 5:39 PM
    Daedalus
    Daedalus New Member
    Any turbo car/truck I’ve ever had I’ve run 93 in.
    not necessarily for a performance improvement, but for predetonation protection.
    Even with the improvement in the air to water charge cooler, IATs on a hot day are not anything to play with.
  7. Apr 29, 2025 at 5:49 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I find mid grade is the most bang of the buck if you will
  8. Apr 29, 2025 at 5:50 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Agree with @Daedalus I've never run anything other than 93 in my truck, or anything that has any form of forced induction.
  9. Apr 29, 2025 at 5:57 PM
    Daedalus
    Daedalus New Member
    On a 4cyl, you’re going to hit about 400whp before you reach 93octs knock limit.
    I had to bump to e30 to push harder in my GTI.
  10. Apr 29, 2025 at 5:58 PM
    Daedalus
    Daedalus New Member
    I say that, to say this engine if it could hold together and had adequate fueling should do 600hp on pump gas.
    SWB Tundra and ARB1977[OP] like this.
  11. Apr 29, 2025 at 6:38 PM
    ARB1977
    Anthony
    DFW
    This is my first turbo.
  12. Apr 29, 2025 at 6:51 PM
    Daedalus
    Daedalus New Member
    If you can afford it, 93 is good insurance IMO.
  13. Apr 29, 2025 at 6:55 PM
    ARB1977
    Anthony
    DFW
    It’s 80 cents more per gallon . than 87.
  14. Apr 29, 2025 at 7:00 PM
    Danman34
    Danman34 New Member
    Danny
    Dang. I’m in south Louisiana. 93 is 25 cents more than 87.
    ARB1977[QUOTED][OP] likes this.
  15. Apr 29, 2025 at 11:39 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Our local Costco’s 87 tank is out of commission so they’ve been selling Premium at the Regular unleaded price for over 2 months. My mpg and performance haven’t changed a bit that I can tell.
    TundraDan723, kirkb and ARB1977[OP] like this.
  16. Apr 30, 2025 at 2:42 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I had a 2017 Tacoma limited that loved 93. You could tell a difference not a lot, but I could feel it in the way it ran. My tundra, I cannot tell any difference at all. But I put some in anyway. I never let it get under a 1/2 of a tank. I dump 93in it every other tank.
    kirkb, Retroboy1989 and ARB1977[OP] like this.
  17. Apr 30, 2025 at 3:44 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Any modern performance vehicle with either high compression or forced induction or both will benefit power wise and longevity wise from top tier 93. The Motor Oil Geek tested and confirmed that the quality of your fuel matters as the top piston ring gets additional lubrication from fuel. But at $1 extra a gallon if you're just driving the truck and aren't worried about the next guy since you sell or trade under 100k miles maybe hard to justify.
    Actually mid grade is the biggest rip off at most stations, usually only 10 to 25 cents cheaper than 93 at most stations at 89. Basically the pump mixes 2 parts 87 to one part 93. You either care or you don't.
    ARB1977[OP], BlackNBlu and Daedalus like this.
  18. Apr 30, 2025 at 3:45 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Yep
  19. Apr 30, 2025 at 3:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Compression rings get enough lubrication from crankcase ventilation and leaking valve stem seals ;)
    ARB1977[OP] and Corndog123 like this.
  20. Apr 30, 2025 at 4:49 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Waste of money.
    If engine is tuned for 87 it runs great on 87.
    Tons of work trucks out there with a zillion miles on them running 87
  21. Apr 30, 2025 at 4:54 AM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    No its just you
  22. Apr 30, 2025 at 5:03 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    "Tuned" by whom? Toyota?
    It RUNS on 87. Just fine. Does it make all the power it can on 87? No way.
    Is the ECU pulling timing every time you're hard on the throttle or towing so it doesn't rattle? Yep.
    Metro14536, Rcflyersd and ansel123 like this.
  23. Apr 30, 2025 at 5:06 AM
    BlackNBlu
    Rich
    MN
    This. All day.
    ARB1977[OP], Metro14536 and Rcflyersd like this.
  24. Apr 30, 2025 at 5:08 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    It is in your head, 87 is fine. Now if you are doing road race track days and have the engine roasting hot and constantly in high boost maybe use 93. But who races Tundras??
  25. Apr 30, 2025 at 5:10 AM
    BlackNBlu
    Rich
    MN
    No, I don't race my Tundra.
    But I do tow, during summer heat and occasionally pretty heavy. Engine load is engine load, it doesn't know the difference.
    So, agree to disagree.
    ARB1977[OP], raylo and Daedalus like this.
  26. Apr 30, 2025 at 5:13 AM
    raylo
    Frederick, MD
    Agree if you are towing hard. Sure. I was talking about the 90% of us who are just or mostly DDing. Like the OP getting 20+ MPG on 87. He ain't towing.
    PNW Tundra Mike and ARB1977[OP] like this.
  27. Apr 30, 2025 at 5:16 AM
    Your premium fuel cost what our midgrade does. :rofl:
    I run octane boost in my Mustang too. Being boosted is bad ass but comes at a price.
  28. Apr 30, 2025 at 5:18 AM
    Daedalus
    Daedalus New Member
  29. Apr 30, 2025 at 5:28 AM
  30. Apr 30, 2025 at 5:35 AM
    Daedalus
    Daedalus New Member
    NOTE, it will coat your plugs and 02 sensor with a reddish film. Will 100% clog a cat. BUT it truly does do what they advertise it to. Alternative is TORCO...also legti.
    Jettster and ColoradoTJ[QUOTED] like this.
